Vacuum Cleaner Speed Controller issues...
  • Hagis2k
    • Jul 2006
    • 66
    Hi folks i own a Volta U6820 (same as electrolux 6820) it as some weird ass speed regulator i talked to the local electrolux service department and they told me i needed to "re-calibrate" the speed controller?!
    Problem started with that on level 4-5(max) it starts to go up and down a lot in speed so now i played with it as the technician told me two outcomes so far 0-30% ish and 20-100% and lol i can not turn it of in the last but i also noticed in the last setup the triac/thyristor turns on and off all the time at higher speeds makes me believe that there might be an electronic problem too
    Any suggestions are welcome!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Vacuum Cleaner Speed Controller issues...
    That is a very simple circuit found in most vacuum cleaners. I would try to take apart and clean the knob that adjusts the speed. If a significant amount of dust gets into it, it can cause the pot to become intermittent, which would give behaviors like you are experiencing.
    A working TV? How boring!
      • 31281
      go resolder some joints.
      also, the zener diode on top looks cracked - is it? or is it the camera angle?
      • Hagis2k
        • Jul 2006
        • 66
        So tried to resolder some joints, and it still acts up like it is power cycling i wonder if the controller ic is faulty?
        Tried to upload some real high resolution macro photos of the pcb but the size was way to big so here they are:
        http://i.imgur.com/vxJoQlY.jpg
        http://i.imgur.com/wuDjADc.jpg
        http://i.imgur.com/jjwr4U3.jpg
        I tried a few times more to turn the pot for full dc voltage and plug it in then to put the pot to gnd and then plug it what confuses me is when i have it in the lowest then the motor is running in full speed without dropping any speed
        can the micro controller be faulty anyway shall call the service center and double check the "calibration" procedure.
        • R_J
          • Jun 2012
          • 9623
          The larger of the Yellow capacitors looks like it may be bulged a bit at the bottom (near D1), I would check it, sometimes they go open and don't look bad.
          And it is off the center of the pot through R1
          I found this also, Hows your Polish?
          http://www.elektroda.pl/rtvforum/topic2559147.html
          and this (similar schematic I think)
          http://www.ebastlirna.cz/modules.php...wtopic&t=65192
          • Hagis2k
            • Jul 2006
            • 66
            Yes i was looking at that one for a while (C2) it says 474/250V 470nF i guess but my component tester says 154nF ESR=8 or so i assume its bad the other (C1) 334 330nF measures 261.nF ESR=3.2 so thats true.
            And no im not that good with polish even if it is close to me haha
            Saw that polish site too seems like MQD4C is a microcontroller?
            Try to source some capacitors then
            • Hagis2k
              • Jul 2006
              • 66
              Thank you RJ!!! i was looking at that capacitor C2 before and its was that MKT capacitor that was bad now it responds up to full speed but it still needs a calibration and now it makes sense
              • Hagis2k
                • Jul 2006
                • 66
                So a final update everything now works and if someone ever would run it to the same problems with similar devices:
                The circuitboard has this partnumber: 2193995111
                the regulator ic: MC9S08QD4C
                Triac: BTB16-600
                And to avoid problems before you do like me, here is a small tip:
                Take a pen and draw a line where off and max speed corresponds to the potentiometer angle and please do not bring it outside those boundaries when you test make sure it is in "off" state...
                Otherwise a time consuming re-calibration is needed and this drove me mad, imagine the potentiometer in midpoint is "90 degrees" then -135 is the lowest and then you shall keep it there then plug the machine in.
                It will start and sound like a tornado, do not worry about that then turn the potentiometer to max then back to min now unplug the the vacuum cleaner.
                Now we have the last step to set the off state in the right position on the pot and on state too (must start with potentiometer at max +135 degrees from midpoint) then try to look at the axle where like full speed is on the pot and where off should be then set it where like full speed should be and a few degrees extra counter clock-wise and plut it in now it should be in max speed now take a small insulated screwdriver and turn the pot clock-wise until it turns off with a bit of luck that will match the angle of the axle of the pot.
                Otherwise you need to repeat the reset and set again.
                • babas48
                  • Jul 2015
                  • FRANCE
                  Hello for french people Ive found it and it works.
                  Little tip for the reinitialisation procedure, do not go to stop completely.
                  You'll find reinit. procedure in french with pictures.
                  • Umbreon
                    • Oct 2016
                    • 5
                    • australia
                    The diode seems misplaces somehow. I had similar problem with my vacuum cleaner, then I bought a crazysales robot vacuum cleaner. It works fine, and the circuit board is compact and simpler than manual one. The speed and cleaning routine can be set on the panel and it will do the job accordingly. Really saves me time. And till now, nothing wrong happens.
                    • Umbreon
                      • Oct 2016
                      • 5
                      • australia
                      It starts then stops immediately, or just spins in place. It can be suggested that a person should clean the robot’s cliffbrushes and sensor, and brush bearings during these moments. Use compressed air, especially throughout the wheels and beneath the bumper, or tap the bumper in your hand. Another suggestion is to give the vacuum a firm push on top, directly above where the center wheel is situated, if this does not solve the problem. The challenge can be which the center wheel at the front of a unit is simply not in the proper recessed position because the wheel is adaptable. This Roomba repair method worked for several.
                      • Umbreon
                        • Oct 2016
                        • 5
                        • australia
                        Even so the new crazysales robot vacuum cleaner are meant to concentrate on different surfaces, it is actually still easy for the drive wheel for being stuck. Turn the unit backwards and inspect the wheels if you see the unit trying to move but not being able to. Try to get dirt, hair and other material which can find yourself in trouble concerning the wheels and the body. Clean this out and allow the Roomba go. This vacuum cleaner repair must be able to have your little guy running again.
                        • spencermoseley
                          I also faced this issue.
                          • Jackoo
                            • Apr 2017
                            • 8
                            • Pakistan
                            Is robot vacuum good enough that you don't ever need to manually vacuum? Please describe your floor situation (hard wood, carpet, etc), as well.
                            • Chungalin
                              • Jul 2014
                              • 423
                              • Spain
                              Very interesting. A friend reported me that he has a Electrolux/AEG vacuum cleaner that is showing this symptom (speed rises and falls by itself).
                              But even more interesting is that calibration method that babas48 reports. I've recalled my brief experience with cooking robot Thermomix TM21:
                              https://www.badcaps.net/forum/showthread.php?t=58675
                              I realized that some sort of calibration of Speed and Temperature potentiometers was stored in a EEPROM. And the potentiometers were exactly of the same type than this vacuum cleaner. Perhaps that calibration is done in the same way that is explained in that french PDF.
                              • petehall347
                                • Jan 2015
                                • 4448
                                i have the solution ....
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  i have the solution ....[/IMG]
                                  Nah, all you gotta do is rip that Confuser out and put on of these in its place.
                                  As a bonus you also get a 10v overclock setting for those high-pile carpets!
                                  Follow the white rabbit.
                                  • are
                                    • May 2017
                                    • Estonia
                                    Thanks, it was very useful. I sought it whole day. Saved me 30 euros .
                                    • geneerobins
                                      • Jul 2017
                                      Move your vacuum cleaner in a forward and backward movement slowly.
                                      • vexzg
                                        • Apr 2017
                                        • Sweden
                                        Has anybody else tested this?
                                        Can you describe the method to recalibrate again in your own words?
                                        I'm trying to follow the instructions, but It seems I am unable to calibrate the max speed to correspond to the correct max turning angle of the speed knob.
                                        Turn off and start on with minimum speed works, but turning the pot towards max speed only gets me some perhaps 50% of available speed. I need to turn the pot manually to get to 100%
                                        I am probably doing something wrong but after spending hours reading the french and Hagis2k guide I am stuck
                                        please somebody explain the procedure in their own words.
                                        • Henke
                                          Electrolux EUO9GREEN Vacuum Cleaner doesn't start
                                          by Henke
                                          I have a vacuum cleaner that won't start. I have desoldered 2 capacitors with low value. But i don't know if they can cause that kind of problem. Someone here with any thoughts and inputs?
                                          I marked the capacitors on the pcb picture with red and blue dots. The big one marked with 334 K measures 216 nF and the other one marked 224 K measures 109 nF.
                                          01-08-2024, 11:37 AM
                                        • Crystaleyes
                                          Electrolux ERG22 vacuum cleaner pcb fault
                                          by Crystaleyes
                                          So, I have this Electrolux vacuum which had the batteries revently replaced and now it won't work.
                                          The voltage from the batteries is arriving to the board without problem (+/- 12v) @ CN4 & CN6.
                                          The motor works fine when voltage is applied to FM+1 & FM-1. The switching on and off is made in the negative line between CN6 and FM-1, and all components have been tested as fine apart from a FET.
                                          The problem appears to be that the PHD71NQ FET (Q18) isn't switching when the power button is pressed.
                                          I say this as when I started to connect my component...
                                          09-09-2023, 06:08 PM
                                        • AlexVG
                                          Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                          by AlexVG
                                          I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                          I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                          (This board does not respond, only the LEDs light up in a circle.
                                          The liquid damage is catastrophic and restoration is impractical).
                                          (I bought this board to get the WiFi module and camera).
                                          The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                          If...
                                          10-22-2024, 07:20 AM
                                        • Tyroonis
                                          Identify component - QPF Chip from Eufy Robovac L70 Hybrid Vacuum Cleaner
                                          by Tyroonis
                                          I have a robot vacuum cleaner here.
                                          An Eufy Robovac L70 Hybrid.
                                          A chip has burst due to a short circuit.
                                          The following is legible on the chip:
                                          Mpsm44
                                          m2612
                                          883138
                                          I'm not sure if there is another number after m2612, as that's exactly where the hole is.
                                          Can anyone help me identify what this component is?
                                          Unfortunately, I couldn't find anything.
                                          I also don't have any plans or board views of the...
                                          08-14-2025, 02:32 PM
                                          Arduino Nano Controller with a 15 watt Laser hook up issues
                                          This project that I am working on the Engraving Machine has been a challenge to make everything to work together
                                          The information on the internet is hit and miss for the most part
                                          It is a good thing that I know how and what it takes to hook up most micro controllers yes each model is a little bit different but for the most part they are the same
                                          The BIGGEST problem has been the markings on these Arduino Nano Controller boards not all are the same some board are marked better than others
                                          You see how I have to hook up the laser and Nano Controller...
                                          09-13-2020, 04:37 PM
