Electrolux EUO9GREEN Vacuum Cleaner doesn't start
  • Henke
    • Oct 2022
    • 41
    • Sweden
    I have a vacuum cleaner that won't start. I have desoldered 2 capacitors with low value. But i don't know if they can cause that kind of problem. Someone here with any thoughts and inputs?
    I marked the capacitors on the pcb picture with red and blue dots. The big one marked with 334 K measures 216 nF and the other one marked 224 K measures 109 nF.
    • 31187
    replace them, one may be part of the psu supplying that microcontroller
    which brings up my second point - why the hell does a motor need a microcontroller?
    • Henke
      Henke commented
      Editing a comment
      Now it's working. I changed them plus the electrolytic one. Thank you very much.
  • wamund
    • Jun 2024
    • Sverige
    I am struggling with one of these cards.
    Thunderstorm while the vacuum cleaner was connected to the outlet. After that it wouldn't start.
    Checked for faulty components (some out of circuit) but nothing obvious.
    Connected the card and works!
    Disconnected the card, reconnected it again - not working…
    Further inspection. Connected the card and works!
    When it was working I measured TP4 (printed 5V) in the circuit. I got 2.95V, which seems to be the reference voltage for the voltage regulator TL431AC. When it is not working it reads 0.8V.
    Filter caps also read low for me, so I will replace them to see what happens…
    • wamund
      • Jun 2024
      • Sverige
      Now replaced the two filter caps and the varistor. Works like a charm!
      By the way, voltage at TP4 still reads 2.95V.
      • Henke
        • Oct 2022
        • 41
        • Sweden
        Nice fixed👍 I am pretty sure that my tp4 neither measured 5V. I thought that was strange, but I can’t remember the exact value though . But it’s still working fine 😃
        • Crystaleyes
          Electrolux ERG22 vacuum cleaner pcb fault
          by Crystaleyes
          So, I have this Electrolux vacuum which had the batteries revently replaced and now it won't work.
          The voltage from the batteries is arriving to the board without problem (+/- 12v) @ CN4 & CN6.
          The motor works fine when voltage is applied to FM+1 & FM-1. The switching on and off is made in the negative line between CN6 and FM-1, and all components have been tested as fine apart from a FET.
          The problem appears to be that the PHD71NQ FET (Q18) isn't switching when the power button is pressed.
          I say this as when I started to connect my component...
          09-09-2023, 06:08 PM
        • AlexVG
          Replacing the WiFi module on a vacuum cleaner iROBOT i7
          by AlexVG
          I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
          I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
          (This board does not respond, only the LEDs light up in a circle.
          The liquid damage is catastrophic and restoration is impractical).
          (I bought this board to get the WiFi module and camera).
          The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
          If...
          10-22-2024, 07:20 AM
        • Tyroonis
          Identify component - QPF Chip from Eufy Robovac L70 Hybrid Vacuum Cleaner
          by Tyroonis
          I have a robot vacuum cleaner here.
          An Eufy Robovac L70 Hybrid.
          A chip has burst due to a short circuit.
          The following is legible on the chip:
          Mpsm44
          m2612
          883138
          I'm not sure if there is another number after m2612, as that's exactly where the hole is.
          Can anyone help me identify what this component is?
          Unfortunately, I couldn't find anything.
          I also don't have any plans or board views of the...
          08-14-2025, 02:32 PM
        • Babbar
          Electrolux Ultrasilencer and UltraOne vacuum cleaners not starting
          by Babbar
          Hi all!
          New to the forums, this is my first time posting so hoping to do a good enough job making sense.
          I have two vacuum cleaners having the same issue of not being able to start on their own but when they get going (by manually shorting power to the motor on the internal PCB) they will keep running and also allow me to switch on and off again for a while using the power switch until the issue returns.
          The models are below and i will attempt to attach pictures of both sides of the PCB from one of the machines (they look basically identical).
          11-26-2023, 01:21 PM
        • rtstorm
          Xiaomi Vacuum Cleaner Charger PSU
          by rtstorm
          Hello my vacuum cleaner dock died, 0V on output. I replace the caps but still no voltage. I found out that this resistor is broken (showing 0 Ohm) do know the value of this? Is this really 0 Ohm resistor?...
          05-24-2024, 10:07 AM
