Hotpoint FFA47X Fridge Freezer
    • 31055
    Re: Hotpoint FFA47X Fridge Freezer
    in series - yes.
    but with both contacts.
    • Rhothgar
      • May 2015
      • 109
      #142
      WOW! Now I'm confused.
      I'll take some more detailed photos of the board. Part or whole? That is the question.
      I had a fright earlier and am concerned I am wasting my time and everyone else's.
      The wiring from the PCB to the display had broken through. I repaired this temporarily and bought a replacement.
      I need to check chronology of when that cable arrived. I'll explain why.
      I ordered the wrong cable and it didn't fit. It's s bit difficult to order the correct parts when you don't have a parts diagram. As of yesterday, I now have a parts diagram.
      I therefore needed to do a more permanent repair in the PCB to display cable.
      I plugged in the cable today and realised it was the wrong way around.
      The worry now is did I actually blow the display when the PCB exploded.
      I've got it plugged in now and the fans aren't working. Did I perhaps not Okug it in correctly before?
      When I say plugged in wrong I mean the colours at intermediate connector is wrong. Perhaps it makes no difference.
      If the triacs power the fans, and the fans aren't working, why?
      At what point do I throw the towel in and give up?
      • Rhothgar
        • May 2015
        • 109
        #143
        I am just checked over all the lead type resistors in the board and they are all fine.
        Just noticed that the reed switch appears closed. Reading back through the topic stj states it should be open. This may be why the fans and lights are now not coming on perhaps?
        EDIT: reed switch fine continuity when magnet near and loses continuity when magnet removed.
          • 31055
          what is the part number on the 8pin eeprom on the top of the board?
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Originally posted by Rhothgar
            It's good to know that the wiring may be unaffected but I take it you didn't look back at Post 71 as previously suggested!!!
            I did take a look at that why do you ask?
              "EDIT: reed switch fine continuity when magnet near and loses continuity when magnet removed." That is fine.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                I would concentrate on when you blew out the land on the board. Where does the run go to on the top side of the board. Instead of reading through all this post . Can you state the first problem you had before you blew you the land? When you blew out the land any component attached to that land could of been taken out. It would be dependent on what is the weakest point of the design.
                • Rhothgar
                  • May 2015
                  • 109
                  #148
                  What's a land please?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #149
                    The copper trace you have bridged with wire is my guess.
                      • 31055
                      eeprom part number?
                      i need to get the pinout so we can check for the vcc supply.
                      • Rhothgar
                        • May 2015
                        • 109
                        #151
                        Sorry stj. Been out most of the day.
                          • 31055
                          thanks.
                          look at the datasheet, it shows the pin functions.
                          if you can safely do it, meter the voltage between VCC and GND
                          lets see if the chips are actually getting power!
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            Yes that is correct.
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              Originally posted by stj
                              thanks.
                              Good place to start.
                              • Rhothgar
                                • May 2015
                                • 109
                                #155
                                thanks.
                                Cool. OK. Tell me where a ground is on the board.
                                If I out my wellies on, am I right in saying I cannot get a shock providing I do not lean on fridge casing with another part of my body?
                                Board is high up so I'll need to stand on a chair (wooden by the way).
                                Presumably meter on 600VAC. Touch ground first when I know where it is then probe chips.
                                As I say if you can tell me where a suitable ground is then I'm good to go.
                                Also, need to be careful not to blow EEPROM as I obviously won't be able to reprogramme it!
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #156
                                  i would use ground on the chip its self says in the pdf just be really carefull probes dont slip just wait for someone else to confirm though.
                                  • Rhothgar
                                    • May 2015
                                    • 109
                                    #157
                                    Indeed. I was thinking I could use GND on the chip but I don't want to blow this chip up. I've no idea if I can use that ground.
                                    Also looking at the data sheet this chip doesn't appear to match. The PDIP chip has a semi-circular indent in one edge but my chip has a semi-circular indent AND a circle indent too!
                                    Check ST website and found an M93C86W ( that's a 33 page manual so not sure if this matters. Same voltage range though).
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #158
                                      im sure stj will be along to advise shortly.
                                      • Rhothgar
                                        • May 2015
                                        • 109
                                        #159
                                        Got to be said, you guys are genii.
                                          • 31055
                                          notches, circle in the corner etc are the same, just different makers using different markings.
                                          meter both pins on the chip, and set the meter to 10vdc
                                          i'm expecting (hoping) for either 3.3v or 5v
                                          you WONT get a shock from the chip even if you stuck your finger on it.
                                          • CG2
                                            Liebherr Fridge Freezer KGT 3456 not working
                                            by CG2
                                            To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
                                            01-25-2023, 02:12 PM
                                          • mikey5791
                                            Help repair Panasonic fridge not cooling
                                            by mikey5791
                                            Hi all forum members,
                                            Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                                            After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                                            07-16-2025, 02:01 AM
                                          • tmcw
                                            Fridge - Gram
                                            by tmcw
                                            Have this fridge, laboratory grade unit, not working fully.
                                            It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
                                            The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
                                            10-10-2023, 05:00 AM
                                          • unimatrix93
                                            Replacement transformer for Samsung fridge
                                            by unimatrix93
                                            Dear forum
                                            My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                            No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                            The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                            My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                            07-14-2025, 02:16 AM
                                          • lapfix
                                            Dell latitude 5320 South peak 13 not power on.
                                            by lapfix
                                            Hello friends
                                            Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
                                            motherboard south peak 13 mb 213252-1
                                            i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
                                            i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
                                            As i undestand from many topic here ,...
                                            04-29-2025, 06:22 AM
