Hotpoint FFA47X Fridge Freezer
  • Rhothgar
    • May 2015
    • 109
    #61
    Re: Hotpoint FFA47X Fridge Freezer
    I prefer skiing. It's actually something like a holiday mode to reduce cycling on the compressor I think.
    • trebo
      • 514
      • Wales, UK
      #62
      Originally posted by Rhothgar
      That's telling me that I deserve a holiday after learning so much about electronics in the last two weeks!
      nice one fella, good job
      • Behemot
        • 4845
        • CZ
        #63
        When they are out of circuit you can re-read their values but I think we already established that several of the small ones were bad…
        • Rhothgar
          • May 2015
          • 109
          #64
          Now all I have to work out is why a frost-free appliance needs regular defrosting.
          Actually, if you read the reviews online for this fridge freezer, it clearly had a design fault.
          Not sure it is worth spending lots of money are buying the revised parts to then find it probably still doesn't keep itself frost free.
            • 31086
            "frost-free" is bullshit.
            if you put unsealed wet items or items with moisture on them in a fridge the water will condense and freeze on the coolling element - that's just physics.
            some equipment can detect the buildup and shut down for a while so the ice melts and drains out - in theory.
            but they often dont work well.
            • Rhothgar
              • May 2015
              • 109
              #66
              Tell me about it. I have just been reading an article on frost-free and how technically complex they are.
              Well since yesterday the fridge is beeping again saying I need to eat all the freezer contents in 24 hours!
              At least I have a working LCD where I can cancel the beeping now.
              Not intending to be sexist and I apologise in advance if it offends any ladies that may be on here (very clever ones if they are into electronics) but just asked the other half if she noticed that the compressor doesn't appear to be kicking in anymore and when since has that happened?
              Obviously drew a blank expression!
              I've defrosted the fan at the rear of the freezer and compressor still not kicking in so onto diagnosing that now!!!
              The article I read said frost-free are notoriously difficult to diagnose and repair.
              Might start with the thermistor.
              Anyone know any decent fridge makers these days without all the technological crap in them? Time for a simple fridge methinks.
              • Behemot
                • 4845
                • CZ
                #67
                Fridge or freezer? If fridge than you may try to look after absorption one. They still exist west from us and thanks to technological advancement are bigger and consume less. But if you have very hot there during summer without AC than it probably wont handle that.
                ADD// seems that there are also combined freezers/fridges, but in general do not count on deep freezing with ABS, it is not capable of such low temperatures. About -10 °C is the best you can get, good for storing food for couple weeks, surely not for half a year.
                • Rhothgar
                  • May 2015
                  • 109
                  #68
                  Oh Behemot! The United Kingdom is never very hot!!!! At least, not like mainland Europe.
                  • Behemot
                    • 4845
                    • CZ
                    #69
                    Good for you than, so check those. Absorption fridge has no compressor, no moving parts, it is absolutely noiseless and as long as you don't loose working medium, it is immortal. It cools constantly, on the other hand it may have somewhat higher consumption than similar compressor units. But nto sure abotu this, I only encountered 20-40 years old models. Yep, some of those soviet models were still kicking
                    • Rhothgar
                      • May 2015
                      • 109
                      #70
                      The fun continues.
                      Got the compressor working but I've blown something up! Hopefully a capacitor!
                      I thought I would test the fan and the defrost Resistor wire which is supposed to keep gutter clear.
                      I had no continuity sound in my DMM so I thought it would be a good idea to use a jumper wire in the defrost resistor terminal block in the back of the freezer.
                      Connected a wire (quite thick copper) and switched on.
                      Display came up! Compressor kicked in then BANG... Display now dead.
                      At least the compressor is still running!!!!
                      Problem now is whether to continue unplugging components and testing or leave alone and see if it freezes up.
                      I suppose with fan now working. The cold air is not going to transfer to fridge section.
                      • Rhothgar
                        • May 2015
                        • 109
                        #71
                        Spot the difference!
                        Not sure if it is recoverable. It's blown holes in a couple of components and it was all going so well.
                        • Rhothgar
                          • May 2015
                          • 109
                          #72
                          It appears to have vaporised a copper track!
                          Can I rebuild the track using flux and solder or is that TOO ambitious or just plain stupid?
                            • 31086
                            clean the soot and oxide off it and take another foto with better lighting.
                            it looks like you just blew a transistor/triac/fet and vaporised the track between it and the connector.
                            if that is the case, a new part and a jumpwire and your sorted.
                            • Rhothgar
                              • May 2015
                              • 109
                              #74
                              You beat me to it stj. You're a star and you're bang on the money.
                                • 31086
                                btw, try to read what's written on that black part, and it goes through a resistor on the other side - R95.
                                check that isnt burned or anything.
                                tell me the colours of the stripes.
                                • Rhothgar
                                  • May 2015
                                  • 109
                                  #76
                                  R95 is red, lilac, brown, gold.
                                  The triac or whatever it is is blown to smithereens! Is it safe to assume that it will be the same as the other two on the board which are
                                  A logo (ST or similar) followed by YCN
                                  D2NC6
                                  0
                                  6HD421
                                  I don't think it is safe to assume.
                                  It start ST then
                                  ????????SL2
                                  ?????????7S
                                  ??????????2
                                  Other one next to N is:-
                                  ST E
                                  ACS
                                  108
                                  5S
                                  Y424
                                  That is cracked in half
                                  I've looked back at original pictures but impossible to read.
                                    • 31086
                                    r95 is 270 ohms - or it should be, check it.
                                    i suspect the bad part is a high commutation triac.
                                    so you have a split part too? damn.
                                    must have got spiked by an arc from the vapor.
                                      • 31086
                                      http://www.st.com/web/catalog/sense_.../SC477/PF62670
                                      that's one of them
                                        • 31086
                                        so this may be the other!
                                        http://www.st.com/web/catalog/sense_.../SC477/PF66524
                                        • Rhothgar
                                          • May 2015
                                          • 109
                                          #80
                                          Amazing. I was struggling to find anything.
                                          I found the ST website and their eStore but it just had developmental equipment.
                                          I couldn't find an ACS108-5S though. Do you think the ACS108-6S would be OK. There's probably too many variables, is there not, to know which exact model to choose?
                                          What other devices are likely to use these components as I have a lot of broken electronics kicking around?
                                          • CG2
                                            Liebherr Fridge Freezer KGT 3456 not working
                                            by CG2
                                            To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
                                            01-25-2023, 02:12 PM
                                          • mikey5791
                                            Help repair Panasonic fridge not cooling
                                            by mikey5791
                                            Hi all forum members,
                                            Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                                            After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                                            07-16-2025, 02:01 AM
                                          • tmcw
                                            Fridge - Gram
                                            by tmcw
                                            Have this fridge, laboratory grade unit, not working fully.
                                            It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
                                            The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
                                            10-10-2023, 05:00 AM
                                          • unimatrix93
                                            Replacement transformer for Samsung fridge
                                            by unimatrix93
                                            Dear forum
                                            My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
                                            No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
                                            The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
                                            My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4...
                                            07-14-2025, 02:16 AM
                                          • lapfix
                                            Dell latitude 5320 South peak 13 not power on.
                                            by lapfix
                                            Hello friends
                                            Got this laptop dell 5320 not power on , just a fast and a dim blink amber light at the power on led indicator.
                                            motherboard south peak 13 mb 213252-1
                                            i'm using schema and Bvd similair to this motherboard. https://www.badcaps.net/forum/troubl...-latitude-5320
                                            i don't have a type-c meter for the moment , so i m taking the voltage using his original charger.
                                            As i undestand from many topic here ,...
                                            04-29-2025, 06:22 AM
