Wine Chiller - SMPS issue - fluctuating voltages
  • beetle1303
    • Jul 2019
    • 279
    • Singapore
    Re: Wine Chiller - SMPS issue - fluctuating voltages
    I am curious about this primary side of transformer pin - +329V from bridge rectifier to middle 2 pins, and -ve to ground pin on the right.
    The left most pin has 0V - is this correct, and why if this is so?
    • R_J
      • 9601
      Look at the schematic in post #17, the connections in your picture are from left to right:
      feedback winding
      Primary B+ supply
      Primary mosfet Drain
      Primary hot ground for feedback winding
      You MUST HAVE about 30v VIN before the ic will operate, Once it starts it will produce its own 16v vcc from the feedback winding. The ic's internal vcc clamping circuit is likely damaged or shorted.
      • beetle1303
        • Jul 2019
        • 279
        • Singapore
        feedback winding
        Primary B+ supply
        Thank you for these information, it super helpful for my education.
        And for my further education:
        1) B+ and Drain both read 329v from the bridge rectifier. If the IC is working, how does the feedback winding gets its 16v?
        2) Vin must be 30v: but the only feed I see is from B+ through R17 & R18, and reads 3.6v, is the 30v generated internally to get started?
        In fact, I would extremely thankful if you could briefly describe the sequence of events leading to the startup and normal operations of this IC, so that I can see the complete big picture.
        Thank you.
        • redwire
          • 3912
          R17, R18 are the startup resistors that power the IC on pin 3 only until it starts oscillating. Then only a few blips the transformer takes over powering the IC. The aux winding generates around 16VDC from D4/R13 to run the IC.
          But pulling the SBD20C rectifier out, a BAD idea because the PSU would go to max. (PW) output, because it was getting no feedback voltage. OUCH! This would burn R13 and must have damaged the IC now.
          • beetle1303
            • Jul 2019
            • 279
            • Singapore
            A small price for ignorance, but a very valuable knowledge gained! Now it clearly explained why pulling out all other components changes nothing, until this unfortunate SBD20C...
            Hmm... after restoring R13, and eventually a new AP8269 IC, I would most likely be back to square one then - a fluctuating voltages on the secondary side?
              • 31246
              maybe not - if the ic was failing
              • beetle1303
                • Jul 2019
                • 279
                • Singapore
                #27
                Noted - eagerly waiting for online purchase delivery.
                • R_J
                  • 9601
                  It is very likely the power supply was working properly, the fluctuating voltage was likely due to a light or no load on the 12v. and the ic was in burst mode (green mode)
                  Green Mode Operation
                  At light load or no load condition, the switch loss become the major loss of the power supply, to reduce the
                  power wasted in light and no load condition, based on a special designed voltage controlled oscillator, green
                  mode operation of the power supply can be achieved by using AP8269. The controller will judge the load
                  condition base on the voltage of CMP pin. In light load the CMP voltage will decrease, when VCMP is lower
                  than a set threshold voltage, a CMP depending time (TR2) will be generated by the oscillator and decrease
                  the operating frequency of the power supply, the minimum frequency is set about 22KHZ.
                  When VCMP decrease further, the power supply will enter into burst mode operation to decrease the power
                  consumed at no load condition. Besides there is no audible noise in any load condition
                  I had a closer look at your picture and it looks like the vcc pin (solder splash) may be shorting to ground, or is that just a reflection of the light?
                  • beetle1303
                    • Jul 2019
                    • 279
                    • Singapore
                    #29
                    It is the reflection of camera light. To be sure I just tested with DMM and there's no short.
                    This chiller has dual zone. In its original operating condition:
                    - 5V supply to both zone control panel are good, but light button is not functional, and internal fans are not spinning either.
                    - Lights and Fans are all connected to 12v sockets on this board.
                    I am not knowledgeable about fluctuating voltages is the reason lights and fans are not functioning. Guess now it's no point to install it back to the chiller to check since there's no output completely..
                    • R_J
                      • 9601
                      The lights and fans are also controlled by the large ic on the power supply board, This ic switches the small transistors Q303, Q304, Q305 etc. I would have checked base of the transistors to see if they were getting turned on, If they were getting turned on I would think the fan would have tried to spin and lights would have been pulsing to the fluctuating voltage.
                      I suspect the original problem may have been a weak CD7 capacitor, or maybe a weak secondary capacitor.
                      I hope you ordered a few AP8269's
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        #31
                        Originally posted by beetle1303
                        My joy was short-lived unfortunately...
                        After soldered in a 22ohm resister, powered up - still exactly the same status: there is still 3.6v input to Pin #3 Vin, but still no voltage output at Pin#7 Vcc, and the CD7 capacitor still 0v...
                        Looks like PWM IC still not switching, probably dead..., and I've just placed online order the this replacement IC.
                        If anyone has any clue to possibility of secondary side shorted somewhere, I would be pleased to investigate fully.
                        Likely just failure of controller IC due to bad primary side HVDC capacitor. The resistor opened because of excess draw of the controller chip. You are unlikely to run into any other trouble once the replacement IC arrives.
                        A working TV? How boring!
                        • CapLeaker
                          Leaking Member
                          • 8339
                          Originally posted by th3_un1qu3
                          likely just failure of controller ic due to bad primary side hvdc capacitor. The resistor opened because of excess draw of the controller chip. You are unlikely to run into any other trouble once the replacement ic arrives.
                          +1
                          • beetle1303
                            • Jul 2019
                            • 279
                            • Singapore
                            #33
                            Yes, I have ordered 5pcs of AP8269, anticipating damages on for couple of attempts..
                            So yes, will follow the input and do test cases depending on the outcome of this IC replacement.
                            • beetle1303
                              • Jul 2019
                              • 279
                              • Singapore
                              #34
                              I am now very optimistic with your confidence, knowing that all the capacitors are now replaced. Thank you.
                              • beetle1303
                                • Jul 2019
                                • 279
                                • Singapore
                                #35
                                AP8269 pwm ic finally arrived after 2 weeks. Not very good at SMD component replacement, but managed to get it working after 2 tries.
                                Tested bare board - working!!! No more fluctuating voltages at both primary and secondary sides.
                                Installed beck to the chiller - fully functional with fans and lights, and chill to set temperatures much faster.
                                Here' the summary of this project:
                                1) Original fluctuating voltages must be due to 1 or more of the electrolytic capacitors bad/weak as mentioned by R_J. Replaced all of them works well now.
                                2) Removing the SBD20 Schottky Rectifier probably killed the R13 resistor and the pwm ic AP8269 as mentioned by Redwire. Lesson well learnt.
                                3) Replaced AP8269 and R13 resistor, everything in working order.
                                A big thank you to everyone shared your experience and advised the next steps. A great learning journey for me.
                                Thank you, thank you.
                                • Francesc V.
                                  Computer SMPS has voltages from a moment and then disapear
                                  by Francesc V.
                                  Hi:
                                  I am trying to repair a 1000W cheap power supply, but so far, with no much success.
                                  The ATX has stable 5V STBY.
                                  When shortening PsuON to ground, it triggers all voltages for a fraction of a second and then disapear (I see the leds flashing for a moment from the ATX tester)
                                  - I removed and tested the capacitors. They are OK.
                                  - Removed and tested the Output rectifiers from the secondary.
                                  - Removed and tested the Mosfets from the primary.
                                  - Outputs are not shorted.
                                  - Overakk review of the solder joins.
                                  04-15-2025, 01:54 PM
                                • beetle1303
                                  Vintec V160SGB wine chiller - thermostat replacement
                                  by beetle1303
                                  My vintage wine chiller, Vintec model# S160SGB, mechanical thermostat failed (not cutting off compressor at set temperature anymore).
                                  After some initial research, this is a Dasfoss 25T65 EN 60730-2 part number.
                                  While this part is generally still available in some online portal, it is fairly expensive. There are many digital thermostat available with some simple rewiring, but I am hoping to preserve it with a with a less expensive mechanical equivalent part.
                                  Anyone familiar can recommend some less expensive equivalent?...
                                  11-06-2023, 06:57 AM
                                • Capacitorial
                                  Powersupply has all the voltages - Monitor still no power
                                  by Capacitorial
                                  Hello guys,
                                  I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                  I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                  On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                  The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                  The weird thing is, that the Power LED is powered over the TCON board.
                                  On The TCON...
                                  12-28-2024, 02:12 PM
                                • Cemal Odabasioglu
                                  MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                  by Cemal Odabasioglu
                                  I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                  Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                  Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                  Observations...
                                  01-14-2025, 03:54 PM
                                • dkneyle
                                  Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                                  by dkneyle
                                  This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                                  Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                                  02-01-2022, 02:08 AM
