Computer SMPS has voltages from a moment and then disapear
  • Francesc V.
    Tempus fugit
    • Nov 2022
    • 231
    • Catalonia
    Hi:
    I am trying to repair a 1000W cheap power supply, but so far, with no much success.
    The ATX has stable 5V STBY.
    When shortening PsuON to ground, it triggers all voltages for a fraction of a second and then disapear (I see the leds flashing for a moment from the ATX tester)
    - I removed and tested the capacitors. They are OK.
    - Removed and tested the Output rectifiers from the secondary.
    - Removed and tested the Mosfets from the primary.
    - Outputs are not shorted.
    - Overakk review of the solder joins.
    How you would try to troubleshoot the problem? Any idea how to isolate the problem? Not sure if it's the primary side or the secondary side that is faulty.
    ​Just opening the post to gather some ideas.
    I will post some pictures tomorrow.
    Regards,
    Francesc.
  • hobostove
    • May 2023
    • 73
    What's the model of the power supply?
    • Francesc V.
      Tempus fugit
      • Nov 2022
      • 231
      • Catalonia
      It's model YL ATX-0200. You can get it in Alibaba :-)
        • 31158
        you got F'd
        thats a traditional 250-350w psu design.
        • Francesc V.
          Tempus fugit
          • Nov 2022
          • 231
          • Catalonia
          Originally posted by stj
          you got F'd
          Sure..........never rely on Chinese Watts :-)
          I scanned the PCB, just for reference. On the secondary side, the channel supervisor IC it's a GR8313. On the primary side, the PFC IC chip it's the CM6800.
          Vcc (pin13 on CM6800) has no voltage.....only the first moment it seems it has, but then the capacitor gets discharged, I guess.
          Regards,
          Francesc.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8292
            In what state is the FPO pin on the supervisor? Check the main filter capacitors capacitance too.
              master hoarder
              • May 2008
              • 12175
              Before anything else, first always try power supplies with a proper load. An old worthless Pentium 4 / Core 2 motherboard is usually good for this... though if you don't have that, a few 12V auto/car incandescent bulbs (20-40 Watt ratings) on the 12V and 5V rails are usually good enough too. The reason I suggest this is because I have seen this quite a few times where some PSUs won't start without a proper load. They simply "twitch the fans" and turn off.
              So try the PSU with a proper load and let us know what happens then. If still the same symptoms, put your multimeter on the 12V rail and try powering on the PSU, with the load still connected. Does the 12V rail go up and to what value? Do the same test for the 5V, 3.3V, and -12V rails, then post the results here. We want to see if perhaps some rail is not outputting any voltage (perhaps due to a bad solder joint or open-circuit somewhere on the PCB - I've seen it happen usually at either the rectifier leads or the output toroids.
              As for the PSU itself... indeed it is not a 1000W PSU, but by the looks of it, might be capable of providing 400-500 Watts if the Chinese designed it right. All in all, it's a relatively modern forward-converter design with APFC. Speaking of which, if this PSU came to you as *used*, remove and check the primary cap for proper capacitance and ESR. On PSUs with APFC, especially those that come with non-Japanese brands of primary caps and have been in use for a while, the primary cap should always be checked if you encounter issues with the PSU not wanting to power up or shutting down under higher loads.
              • Francesc V.
                Tempus fugit
                • Nov 2022
                • 231
                • Catalonia
                FPO pin goes high when powering on the SMPS (4.3V) and remains the same (maybe decreases some milivolts) when pressing PSON to switch on the SMPS.
                I put loads in every rail (3.3, 5V, 12V). 40W bulb with a switch.
                Momentary voltages when switching on are 4.3, 3 and 11............... so I guess that for some reason there is over-voltage in the 3.3 rail and the supervisor protects the SMPS (I measure 4.3V, then decreasing in pin 5 from GR8313)
                Regards,
                Francesc.
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8292
                  O.k. So you are getting weird voltages on the secondary and the supervisor is shutting that PSU down. How many volts are you getting across the main filter cap in the primary during that short blip? Is the PFC working? You can disable that supervisor by grounding out the FPO pin.
                  • Francesc V.
                    Tempus fugit
                    • Nov 2022
                    • 231
                    • Catalonia
                    Thanks!!! That was the most valuable tip so far :-) I will write it somewhere........shorten FPO to turn on smps whatever it takes :-)
                    By grounding FPO pin to GND (shorted pins 2-3 in the supervisor) the SMPS turns on.
                    I had just time to measure secondary voltages before my wife started shouting, however I see secondary STABLE voltages (stable but wrong).
                    In the 3.3 rail I have a stable but WRONG 9.2 V
                    5V, -12V and 12V rails are stable and with the RIGHT voltage.
                    With a secondary stable voltages, I guess there is nothing wrong in the primary..........who knows.
                    Now I have more idea where to look at.........a faulty 431? wrong reference resistor in that 431? faulty optocoupler in the 3.3 rail?
                    (in the PCB I am counting up to 3 431s).
                    Regards,
                    Francesc.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8292
                      With that established, pay attention how the 3.3v, 5v and 12v is built on the secondary. Squiggle a rough schematic together. Again, make sure you are getting BOOSTED voltage from the PFC first, even so you are getting correct 12v.
                      Is the 3.3v made through a DC-DC converter maybe? Otherwise it doesn't make any sense to me right now how you get 9.2v out of a 3.3v rail. I couldn’t find anything with that model number of the PSU.
                      • Francesc V.
                        Tempus fugit
                        • Nov 2022
                        • 231
                        • Catalonia
                        Finally!!!!, I discovered and fixed the problem.
                        I was getting a stable 370V in the primary cap, so PFC was working.
                        Then I started measuring the REF voltage for each of the 431 that are on the PCB. One of them had no voltage in pin1, others 2.5 stable volts.
                        Then following up neighbors I realized that pin1 was directly connected to a resistor that it should be 820 ohms, but I was getting K ohms............so I've replaced and auto-magically I started getting the expected 3.3V.
                        Joint between pin 2-3 removed and SMPS switches on normally.
                        Big thank you for all your feedback!!.
                        Regards,
                        Francesc.
                        • Capacitorial
                          Powersupply has all the voltages - Monitor still no power
                          by Capacitorial
                          Hello guys,
                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                          The weird thing is, that the Power LED is powered over the TCON board.
                          On The TCON...
                          12-28-2024, 02:12 PM
                        • beetle1303
                          Wine Chiller - SMPS issue - fluctuating voltages
                          by beetle1303
                          My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                          Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                          Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                          Checking further on the primary side: Incoming line input to bridge...
                          09-04-2023, 10:33 AM
                        • madan1
                          Mackie Th15 SMPS low Vout
                          by madan1
                          I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                          It is basically a smps with amp and some dsp.
                          The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                          Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                          By the way, the ferrite core of L10 is broken,...
                          02-16-2025, 04:15 PM
                        • jord4231
                          Megmeet MLT666T lcd smps
                          by jord4231
                          Hi All,
                          I have an old 2006 ish TV that after the last storm we had would fail to come out of standby. We had a few outages on off on off etc
                          I am only repairing this as a challenge and to improve my skills.
                          Firstly I would like to mention I am no stranger to working with high voltages and understand the dangers of the high voltages present in SMPS, I have repaired a few before but this one is a little more challenging.
                          The board is a Megmeet MLT666T REV: 1.2a
                          The symptoms. TV has standby power, when turned on the power led will...
                          02-13-2022, 08:54 PM
                        • dariolana
                          ATX PSU Cooler Master RS-700-pcaa-e3 shutting off after 5 seconds
                          by dariolana
                          Got this from my kid with a fault on primary side. Main power supply here is AC 220V. All caps were Ok, testing with 2 series lamp of 70W each, got a bright lamp . Checked main heatsink one by one with my component tester and found one 3 leg buddy MDP18N50 that passed away. Got same replacement after a week, tested, short was gone, now I got 310V on primary.
                          Happy as a dog, added one case fan for some load and the fan of the PSU. Tested purple wire, got 5.1V, great!. Shorted green and black, fan spins and after about 5 seconds shuts down. I was able to measure doing several iterations...
                          02-26-2024, 07:47 PM
