Cooling upgrade on refrigerator. If it works, it ain't stupid!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    I had this refrigerator at my old folks which I noticed I would put my beer or soda in and take it out warmer than I'd brought it from the store.
    Now, I don't know much about refrigerators or HVAC but to me it seemed like we have a problem. I threw a thermometer in... 20 deg C in the fridge. WHAT THE... Freezer worked fine with temperatures way below zero, as it should, and it has only one compressor for both sides so it got me scratching my head for a while.
    Only other things that seemed a bit odd was that the heatsink on the back was barely warm and the compressor was very, very quiet. Hmm.
    I read around for a bit and saw that no frost refrigerators have a fan in the freezer which blows air in the refrigerator compartment. I looked for it, nope. Didn't find one, nor did I find a service manual for this. Just the user manual. However, in the user manual of another model a fan was mentioned, in this one, no, so maybe it doesn't have one.
    Last night I went to grab a bite and noticed the compressor louder than usual, the heatsink hot to the touch and *gasp* the fridge was cold inside this time and condensation started forming inside on the rear, as it should. The past couple days had brought colder weather... Hmm.
    I remembered that the compressor has a "Thermally protected" label on it. Could they have put a PTC thermistor on it? That would explain everything. YES, they did.
    Today the sun was up and I had 20 Celsius in the fridge again. So, without further ranting, my hunch turned out to be correct and I present to you the redneck solution to an overheating compressor. Now my beer is cold again all day long.
    A working TV? How boring!
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Cooling upgrade on refrigerator. If it works, it ain't stupid!
    One more reason not to toss out all of those old ATX PSUs.
    Wonder how long that solution would last, though. Well, now with autumn/fall and colder temperatures coming, maybe that won't be such an issue soon.
    BTW, the REAL redneck way to cool your beer would have been to put it all in the sink and let it sit under slow running water.
    Same method was/still is used in these parts of the world for large items like water melon too.
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      i cant figure our what you did
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        It took me a while to see "it" / the "fix" , too ... but I won't spoil it. Just look carefully at the 1st photo.
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          ah yes i see it now
          • ron350
            • Feb 2014
            • 296
            I like that fix.
            Is there a reason why compressors don't have aluminum heat sinks glued all over them?
            • CapLeaker
              Leaking Member
              • 8161
              Sweet fix! Dirt@$$ cheap and effective!
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                • Romania
                Originally posted by ron350
                I like that fix.
                Commercial and outdoor units have a fan bolted on the side of the compressor.
                This one is way past its warranty, and there was another problem which probably led to the current situation: the white tray on top of the compressor collects the condensed water from the fridge compartment, which the heat rising from the compressor evaporates. That tray had fallen off and the water had been dripping behind the fridge for a long time.
                Now, it's a small amount of water so it wasn't noticed except when I pulled it away from the wall and saw the mess it made. However, I have a hunch that the cold water getting collected in the tray to be evaporated also aided in the cooling of the compressor, and it running for so long without the tray on top made it go out of spec.
                There will be more drunken engineering tomorrow, I'm cooking up a replacement temperature probe. It now works reasonably well, but I believe there is a single temp sensor and it's in the freezer, as the temperature variations in the fridge between compressor ON and OFF are quite large. It's still a lot better than having the compressor run all the time and not manage to cool down anything though.
                • R_J
                  • 9535
                  Check if the compressor uses one of these type of PTC start relay/thermistor They are cheep and easy to replace, usually located under a cover
                    • 31028
                    you should put a splash of concentrated disinfectant in that or mold can grow in it.
                      • Jul 2011
                      • 6039
                      If it has a coil on the other side of the fan that you put make sure that it is also clean because this can cause the compressor to overheat
                      • redwire
                        • 3910
                        I would check the power consumption with an energy meter.
                        PZ75E1B compressor is 140-200W apparently and seems to use a PTC start relay.
                        Fridges are made so cheap, pennies saved. They couldn't give the compressor some fan cooling? I'd power the fan off the switched power.
                        Mold control is TSP trisodium phosphate, I imagine it also kills bacteria like Legionnella that likes warm wet places air conditioners. If your tray looks scary.
                        I find the condensor coils are always full of dust.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Thank you. There is a small black box to the left of the compressor, where the power cable goes in and from there the cables split going to the compressor and the control inside the fridge.
                          I'm going to take it apart and see what's inside.
                            • 31028
                            i dont think anything is inside that box - there wasnt on the last 2 i stripped.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Thanks, saves me some time. Weather has been getting significantly cooler today, and so far, so good. 3 degrees C on the topmost shelf.
                              Someone else suggested another thing to check, there should be a valve between the freezer and fridge compartments which may be getting stuck closed. That's on my to-do list along with replacing the PTC.
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                wrap your beer in tissue paper and soak with water and put in the freezer for 30 minutes ,,
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  That's what I had been doing until I fixed it.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Also fridges made for built-in applications that have the heat-exchanging fins on the bottom and a fan on the back, pulling air through those fins and exhausting it out the back. The fan also helps cool the compressor too, like you noted.
                                    ^ Common to a lot of older US fridges, including the 30 YO Kenmore at my parents' house.
                                    Actually, I think the tray on top is not so much for helping to cool the compressor as it is for heat rising from the compressor to help with evaporating the water quicker.
                                    I thought about suggesting that... but if it was a stuck valve, I don't see how adding the fan could have fixed it / made it work.
                                    Otherwise, valves getting stuck or blower fan between freezer and fridge going bad is not too uncommon, at least for fridges that take cold air from the freezer and pipe it into the fridge. In fact, my sister's fridge developed that fault (stuck valve) last year... except the valve got stuck open instead of closed, and the fridge was basically a 2nd freezer. Fridge was a Bosch and not even 3 years old when this happened. Goes to show the quality of modern stuff. Didn't help that Bosch used a specialty-made stepper motor that wasn't available anywhere. Since it was one of those built-in kitchen fridges (with the cabinets) and not a very standard size either, my sis wasn't eager to replace it. The repair took over 3 months (close to 4), since the guy that was repairing it couldn't get a replacement stepper motor anywhere with the listed specs and had to custom-order it. Not only that, but he had to custom-order a bunch of them, due to factory MOQ... and they dude only had a small repair shop, so he wasn't eager to do that either. But then he eventually ran into a number of other customers with fridges with the same fault and same stepper motor failed, so after a few months of waiting, he finally ordered a bunch of these custom stepper motors and got the fridge running.
                                    ... and then people ask me why I don't want to switch over my 30 Y.O. appliances to these newer shiny & "much more efficient / green" stainless steel appliances. Yeah, no thanks, but I rather keep my old, ozone/climate-"unfriendly" R12 fridge going as long as it can.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      "ozone unfriendly R12" is a misnomer, as long as it works (meaning it's not leaking) it's not unfriendly.
                                      It's unfriendly if it stops working and you need to recharge...
                                      Reminds me about that other thread I posted, curious how often refrigerant leaks and compressor failures (and anything else that would require discharging of refrigerant to repair) -- I'd be happy to work around thermostat failures!
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Exactly!
                                        In the 30 years we've had that fridge, it's never needed a repair. Well, the door switch for the light bulb went out some 20 years ago and it didn't seem easy to take apart, so I've dealt with it without a lightbulb for 20 years... but no biggie. I know what (food) I put in my refrigerator at all times and where, so I don't need a light bulb at all.
                                        From what I've seen from regular browsing though Craigslist in the last 10 years, I've seen quite a few fridges given out for free due to being diagnosed with a bad compressor or low on refrigerant (though also a lot of good working ones too, but just too old and/or dirty.) The broken ones tend to fall either in the very new category ("high-efficiency" fridges running at high pressures for their "eco-friendly" refrigerants) or very old category (like my fridge, but never cleaned or maintained or likely abused, and thus more of a compressor failure at their age.) Of course, there are also quite a few in between these two categories too. But the ones that are regularly low on refrigerant tend to be newer (under 10 YO) fridges.
                                        • Ace Perception
                                          Samsung R530 Bremen motherboard cooling
                                          by Ace Perception
                                          I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
                                          I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
                                          So I went in pursuit of...
                                          07-21-2020, 03:05 PM
                                        • Hondaman
                                          Liquid cooling?
                                          by Hondaman
                                          I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
                                          (After previous generation hardware [Gigabyte] didn't...
                                          05-08-2025, 09:37 PM
                                        • unimatrix93
                                          LG fridge compressor not starting
                                          by unimatrix93
                                          Hello everyone, my old but loved LG GR-642 stopped cooling and frosting all together.
                                          The display shows everything as normal, the focused cooling activated when I open the doors but the compressor wont start.
                                          First I measured the terminals on the compressor at the back of the fridge. 0 volts.
                                          Now I disconnected the compressor and measured resistance on its leads: around 8 ohms.
                                          I dissassembled the main powerboard, couldn't find anything suspicious but I noticed that the comps relay wont send voltage to the pin, while Fan H and fan L is indeed at 230V....
                                          11-22-2024, 03:27 AM
                                        • bigbily09
                                          eureka dsr c60 not cooling moist only
                                          by bigbily09
                                          my refrigerator model eureka dsr c60 is not cooling only moist, but the light is turn on and compressor is sounds too loud this is what i checked
                                          1.relay - ok continuity
                                          2.overload - ok continuity
                                          3.thermostat - ok continuity
                                          4.evaporator when i touch it is cold
                                          5.condenser not warm / filter not warm
                                          6.i hear running like water sounds on evaporator
                                          do you think it is a compressor problem?? please help
                                          09-02-2022, 06:52 AM
                                        • mikey5791
                                          Help repair Panasonic fridge not cooling
                                          by mikey5791
                                          Hi all forum members,
                                          Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
                                          After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
                                          07-16-2025, 02:01 AM
