people with parts connections, help
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    so. A lady came in today with a broken flash drive. she just needs the data off it.
    the USB controller chip broke off (with some of the legs too), but if I can grip it down hard enough, it contacts enough to detect and see ONE flash chip (the one without the FAT)
    so, what I need is a replacement controller chip so I can clamp it down and get her data off the chips, which from what I can tell, are still good
    Its a SM3251L-BB. I get almost no luck with google searches, and apart from asking silicon motion myself for one freaking chip, which they will probably charge me up the 4$$ for, maybe one of you can help me get a working one?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: people with parts connections, help
    well, i hate to say it, but i think you are screwed here... th controller would be very difficult to find, not to mention desoldering and resoldering pins that small would be very difficult.
    this should be a lesson in why you must backup important stuff...
    you need a sticker for it that says:
    sigpic
    (Insert witty quote here)
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      I don't need to 'resolder' it. the legs are bottom contacted, so all I have to do is keep the chip held down tight, keeping them contacted, and I can probably pull the data off it. Its easy to do, if 5 of the legs weren't torn off the chip
      • Scenic
        o.O
        • Sep 2007
        • 2640
        pics?
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          I don't know if pics are possible, this is tiiiny. i'll try, but no guarantee
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            well I used my camera behind my magnifier, here it is. it came with the chip detached, then she took it to our electronics guy who took it off the rest of the way before discovering some of the legs were broken off
            • Toasty
              • Jul 2007
              • 4171
              >>...and apart from asking silicon motion myself for one freaking chip, which they will probably charge me up the 4$$ for...<<
              ...and the data is worth how much to her? If she is unwilling to cough up the bucks to fix it, why bother?
              Either do as you said and get another controller from SM, or obtain another drive off eBay and swap chips. Either way, she's looking at a fairly expensive investment, unless you're doing this as a favor.
              Curiosity: Whose make & model drive is it?
              Does your "electronics guy" have the ability/equipment to do the swap?
              Best of Luck with this!
              Toast
              veritas odium parit
              • Scenic
                o.O
                • Sep 2007
                • 2640
                easiest solution would be to get the same stick from ebay, confirm its working and then swap the flash-chips..
                i did that before when i accidentally walked on my own stick.. bent PCB with ripped-off traces.. argh..
                just dont mix up the chips... upper side chip has to go in the same place on the "new-old" stick..
                • MXM
                  • 430
                  • Unknown
                  ^ Agreed.
                  We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                  • kc8adu
                    • Nov 2003
                    • 8829
                    • U.S.A!
                    easy job.
                    just need a donor stick.
                    that is if you do ok with smd stuff.
                    • kaniki
                      • 514
                      just a thought, but if you can make contact by holding it tight, then maybe try putting something around it (like a tight rubber band) to hold it together to get the info off.. or if you can lay it down, use some kind of vise-grips or a clamp to gently hold it together to to make the contact.. but if you do that, just make sure that you dont put too much pressure so you dont damage any parts and make sure to put something like some rubber or plastic under the clamp to make sure you dont short anything out.. that is what i would try at least. and doing that, you would have a steady constant connection that you would not have to worry about loosing connection because you hand moved a bit..
                      just a thought
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        there are like 5 legs that are broken off too far to even hold it down
                        • NxB
                          • Feb 2009
                          • 1595
                          Its probably easier to get a donor drive and swap the flash chips with a hot air gun.
                          *Just looked at your pics. Some of the pads are torn off, a new chip will do squat.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            I'm pretty sure all I have to do is take my Iron and push some solder over where those pads were
                            • Toasty
                              • Jul 2007
                              • 4171
                              Where'd the pics go???
                              veritas odium parit
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                I remember something about tc 'moving to a new server' last night, he probably forgot to copy that folder
                                • Pyr0Beast
                                  • Feb 2009
                                  • 406
                                  Swap the memory chips, they are not BGA so it should be easy.
                                  • Th3_uN1Qu3
                                    Believe in
                                    • Jul 2010
                                    • 6031
                                    • Romania
                                    Yup, i even did that without a hot air station a few times. Cover all pins on one side in solder, prop a thin screwdriver under that side, and push on it while heating the mass of solder. Repeat for the other side, use braid to get the solder off afterwards.
                                    A working TV? How boring!
                                    • Uranium-235
                                      Comrade Glimmer
                                      • Aug 2007
                                      • 5042
                                      • US
                                      thanks for the tips everybody, but the boss made me give the stick back to the owner, saying it would 'not be worth the trouble'
                                      • acedogblast
                                        by acedogblast
                                        11-02-2024, 05:13 PM
                                      • Troystain
                                        Help EZP2023+ updated chip database for w25q256jveq?
                                        by Troystain
                                        Hello, anyone here have updated ezp2023+ chip database in .dat file format.
                                        I need to add w25q256jveq chip but I do not know what data should I type.
                                        I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
                                        The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
                                        11-25-2024, 12:53 AM
                                      • inck243
                                        Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                                        by inck243
                                        Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                                        The BIOS...
                                        07-25-2024, 09:17 AM
                                      • thxd43
                                        Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                                        by thxd43
                                        Hello, first of all, excuse me, I am using the translator, English is not my native language.
                                        I have a Lenovo ideapad 330S - 14IKB laptop.
                                        The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                                        02-23-2023, 08:37 PM
                                        by SMDFlea
                                        Bad...
                                        09-02-2021, 04:40 PM
