do you have this: AS358M-E1
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    does anyone have this IC: as358m?
    since there are other signs on the 821410 and the ones i find have different signs +a month wait time for delivery. very grateful if anyone has it and wants to help
    • 31141
    Re: do you have this: AS358M-E1
    maybe it's an LM358 using a manufacturers prefix
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      how to know ?
        • 31141
        https://www.diodes.com/part/view/AS358/
        looks like a match
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          please which of them would fit? They don't have the same ending? maybe it doesn't matter? https://www.diodes.com/part/view/AS3...product-option
          Do you have one for me?These are in Honk Kong at least a month wait time
            • Jul 2011
            • 6057
            It is the part number in the first line plus the second line is what you are interested nothing else would else is need because the rest of it is date code and or plant location
            Which the data shows what you have it is the first one on the list
            AS358M-E1 The only thing that is not on the ic chip is the “-“ which does not make a difference
            The “E1” just means that it lead free
            You are just going to have to wait there is a global ic chip shortage and there is no cure for this type crap issue but just wait
            This company you are lucky that you were able to find the data sheet for this part number because a lot of there ic chip are not on the internet and find somewhere to find there chips are extremely hard to find
            • lti
              • May 2011
              • 2555
              That's an SO-8 package, so you want the AS358MTR-G1. You could probably substitute an LM358 or BA10358 in the same package if they're easier to find.
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                thanks for the information
                  • Jul 2011
                  • 6057
                  The only question I have will this ic chip operated the same exact way or would have to modify the circuit for it work correctly
                  • bohaboha
                    • Nov 2012
                    • 1017
                    • sweden
                    if it can be replaced with one of the ones you mentioned then maybe it will be easier to find in those circuit boards that I have
                      • Jul 2011
                      • 6057
                      Is charger something special or is it that you just like it features
                        • 31141
                        it's a very common chip, if you have scrap boards of any type you will probably find a few.
                        • bohaboha
                          • Nov 2012
                          • 1017
                          • sweden
                          No it's an ic in a power supply to a tv Voxicon K550WDC2 for which I've opened a thread here in tv repair but no one wanted to help and as I think this part is broken
                          • bohaboha
                            • Nov 2012
                            • 1017
                            • sweden
                            that's exactly what i was thinking when lti said:
                            It's an SO-8 package, so you want the AS358MTR-G1. You could probably substitute an LM358 or BA10358 in the same package if they're easier to find.
                              • Jul 2011
                              • 6057
                              I do not go to the tv repair section very often so that is why I did not see it
                              • PeteS in CA
                                • Aug 2005
                                • 3581
                                • USA, Unsure of Planet
                                Probably any company's __358 in the correct package should be OK. The LM356 has been around since the 1970s. There may also be an LM358A still on the market, an improved version, but the original is good enough that the improved version didn't displace it.
                                PeteS in CA
                                • bohaboha
                                  • Nov 2012
                                  • 1017
                                  • sweden
                                  please how will I know the "right package" if you could enlighten? so a LM 358A would fit?
                                  • davidk35
                                    Lenovo ThinkBook 15 G2 ITL, some little signs of life
                                    by davidk35
                                    So i got above mentioned laptop. Which shows only some little signs of life.
                                    When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                                    What ive already done:
                                    -Flashed both bios chips 16 and 8 mb.
                                    -Tried adding another stick of ram
                                    -Check if backlight is faulty.
                                    So any ideas?
                                    Thank you
                                    09-03-2025, 06:34 AM
                                  • KYBOSH
                                    Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                    by KYBOSH
                                    I picked this one up today.
                                    Previous owner says no signs of life.
                                    TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                    Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                    The TV model is QN65LS03BAFXZA - version: CB06
                                    The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                    I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                    Will keep you all...
                                    04-05-2025, 08:32 PM
                                  • tranquility
                                    HP EliteBook 850 G5 without signs of life
                                    by tranquility
                                    hello, i have a problem with HP EliteBook 850 G5
                                    shoring no signs of life. led near charging port and on/off button are off.
                                    board it taking just a few mA..i think it was 10mA
                                    i measured some things but i don´t find anything
                                    the ACOK ? pin 24 FRWPG (pin 24) am ISL9538h is low with 0V
                                    but i dont know why
                                    i cant really understand what the mosfets in the pictures are doing for crazy things.
                                    i measuered voltage on coils....but now on mosfets near the coils too and they all had more than 10v i think one was there with 8v or something....so...
                                    12-02-2024, 05:57 AM
                                  • KYBOSH
                                    Trying to Save - Samsung UN40MU6300 - No Signs of Life
                                    by KYBOSH
                                    Picked this one up today.
                                    No signs of life whatsoever. No red led light from the IR module.
                                    Disconnected the mainboard to see if PSU was working and it was (LED backlights lit up).
                                    Checked the power button for continuity when buttons were pressed and I got readings.
                                    Disconnected various components (speaker, wifi module) with no difference.
                                    Checked mainboard's fuses (found 3) and they were all good.
                                    I looked on shopjimmy to see what components I may have been missing and I saw that they were selling EEPROMs.
                                    Then it dawned...
                                    10-12-2024, 11:20 PM
                                  • ongobongo
                                    Asus Rog Strix starts but no screen or other signs of life
                                    by ongobongo
                                    Hi Guys,
                                    I'm trying to repair this Asus ROG Strix notebook for a longer while now.
                                    Mainboard is G531GW rev. r1.6
                                    When attaching power notebook straight up turns on but no picture or similar signs of life. Voltages are all there (VCCCORE, VCCSA, NVVDD, 1.05V, 1.2V, 5V, 3V, 12V …. Only VCCGT is missing, but that is ok as far as I read), no obvious shorts on any rails. CPU gets hot quickly without heatsink, GPU gets moderately warm and PCH gets warm as well. EC should be good: power button responds to a long press and after a while the CPU fan kicks in.
                                    What I have found out...
                                    08-06-2024, 01:13 PM
