SG - what does it stand for?
  • Behemot
    • 4845
    • CZ
    I found some metal components inside glass, labeled "SG" on PCB from old display, what's that?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: SG - what does it stand for?
    spark gap.
    • Behemot
      • 4845
      • CZ
      Another interesting component labeled PTCU. There are two coin-like pieces of metal inside...
      What's that?
      • malmal
        • May 2008
        Photon Torpedo Control Unit #1
        There are two of them in any StarFleet Attack Runabouts.
        • Huckfinn
          • Jan 2009
          • 43
          Malmal's answer is funny, but not quite correct, electronically speaking. The component you have is a positive temperature coefficient resistor/thermistor unit, and these are used for current limiting tasks.
          Huck
          • Toasty
            • Jul 2007
            • 4171
            I liked malmal's answer better...
            I have them in my runabout...
            veritas odium parit
              • 31278
              lol
              it's called a ptc, it's used to power the degausing coil for a few seconds at power up.
              after a few seconds the thing is so hot that the resistance increases & cuts power to the coil.
              heres a tip - they do fail.
              if you desolder one and it rattles - it's fucked.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                It's supposed to have a cover.
                Mann-Made Global Warming.
                - Dr Seuss
                • japlytic
                  • Oct 2005
                  • 2086
                  Sometimes, spark gaps (SG) are called air gaps (AG).
                  Some may exist as exposed PCB traces.
                  • Behemot
                    • 4845
                    • CZ
                    Yeah I have it somewhere...
                    Thanks for the answers...
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • DXseekerMO
                      Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                      by DXseekerMO
                      Hello everyone!
                      Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                      Symptoms:
                      1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                      2) TV does not appear to turn on
                      3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                      4) "Power on" terminal on Power Supply has 3.26v
                      5) "A13V" terminals have 12.9v
                      6) Stand-by test jumper on Power Supply has 12.9V
                      7) Optical audio jack on Main Board illuminates
                      8) With stand-by...
                      06-09-2021, 12:19 AM
                    • questore
                      nvme and wifi error after liquid metal spill
                      by questore
                      Someone brought me a liquid metal damaged motherboard.
                      First I have removed alll liquid metal from the board.
                      0,75V_ALW was burned, and had to be removed and I have separated the layers until no short was on the VIN (B+) line and the output is no longer shorted.
                      Applying 0,77V on the output with my lab PSU make the laptop caming on and i running windows from USB drive SSD
                      There are 2 things that not working.
                      1. The WIFI card keeps turning off and on with an error code 43 and 10 abouth every 10 seconds
                      2. nvme devices are not detected on either of the 2 slots....
                      11-11-2025, 01:16 AM
                    • silver60618
                      How to clean Liquid Metal from under CPU?
                      by silver60618
                      Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
                      The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
                      Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
                      07-11-2025, 01:47 PM
                    • FriedFred
                      Schenker VIA 15 PRO, PF 4NU1F V1.0, P/N: MBPPF4NU18-F310 - 36mA in stand-by
                      by FriedFred
                      Hello, everyone!
                      I have here a Schenker VIA 15 PRO, with this numbers on the board: PF 4NU1F V1.0 and P/N: MBPPF4NU18-F310 .
                      I took out the memory and the battery and the SSD.
                      So, in stand-by, only the board, takes 36mA. No power-button pressed at all, I can measure 1.8V, 3.3V, 5V. All coils present voltages except the two power rails for the CPU. The CPU is a AMD Ryzen 5 4600H.
                      After pressing the power-button, the current raises to 500mA and the two power rails for the CPU show up with 0.8V.
                      After several seconds, the fans switch-off and the board keeps powered...
                      03-08-2025, 04:45 AM
