Here is a good used source for 18650 batteries
    • Jul 2011
    • 6070
    Re: Here is a good used source for 18650 batteries
    Here are the battery pins that I mentioned above
    https://www.ebay.com/itm/18520310170...3ABFBMuJaYocJh
    Yea I know that you are going to say that they are expensive if you have a lot of battery pins but I was showing you how could use this with the cutting board that I also mentioned above
    These are good quality pins I used them before on my battery testing machine I have not bought pins from this seller BTW
      • Jul 2011
      • 6070
      Here is the link for 4.2 volt @ 26 amp hour battery packs that I mentioned above
      I bought the amount that I need and there are still some left
      https://batteryhookup.com/products/new-7-2v-30ah
      I have tested one battery pack it does test at a little bit over 26 amp load test parameters are 4.2 volts down to 2.5 volts
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        LOL dummy cells in center! Was it for heat distribution or just a lower rank sku?
        • redwire
          • 3912
          They look like a really good deal.
          Say 2.6A/cell so 26A (2s10p) I think the pack is near the (interconnect) limit, you would go up to 3S or 4S if you wanted to pull more power.
          The missing middle cells, it's the best place because they would otherwise be surrounded by cells and see the highest heat which is not good.
          It would be interesting to calculate the heat, using ESR value to see how many W the cells dissipate during high drain. The Boeing 787 lithium battery fires they added room and ceramic spacers and did not stay with 3x3 packing where a cell is surrounded by others on all sides.
            • 31267
            the 787 thing was suspicious - i'm not sure it was the batteries.
            a lot of special cargo was on that plane.
            you would think they would have done tests with the batteries and charging system out of the plane to determine what happened, but no.
            it reminds me of when the u.s. navy shot down another boeing and then caused untold costs and problems for the industry by making up some fiction about an alleged fuel tank explosion.
            even while the canteen area had clear signs of being almost cut in half by an expanding-rod warhead.
              • Jul 2011
              • 6070
              No there two blank spaces nothing there and I would not be surprised if that is the reason they are blank for heat dissipation would be my guess but I like the idea of this though because they are not sandwiched tightly together
              There is space between the two groups of battery cells as well
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                well have to think about it this way too, with more cells there, each cell would produce less heat (because it's shared!) ... so it's totally the consumer that dictates how much heat the cells generate. If you draw less (per cell -- if it come to it), the cells would heat up less.
                I'd imagine there's a better way to place cells to give each cell more space between each of them than just putting two dummies in the center. Alas it's an easy solution.
                  • Jul 2011
                  • 6070
                  This battery pack does have a BMS protection board I going to see if it useable when I receive the other 5 battery packs I have to decide how I going to use them but I kind-a thinking that I might cut them up so that there 5S and make a battery pack like this but I quite sure yet on the details yet
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    yeah form factor of the pack is annoying. mower pack is a big block, but that doesn't work for transportation packs which tend to be long and thin.
                    to choose between 3S, 6S, or 4S(which I have several bms boards for)... argh. Well, at least for things like 10P I can use lm324 to design a bms/balancer where in a 1P it'd waste too much power...
                    • ChaosLegionnaire
                      HC Overclocker
                      • Jul 2012
                      • 3266
                      • Singapore
                      #250
                      Originally posted by eccerr0r
                      Damn.
                      I got a "21.4V" 4Ah pack "new RMA" pack for $1 from the returns processor. Seemed a bit too light and small for 4Ah but anyway...
                      When I opened it... It was a 6S1P Li-ion... and 2AH 18650 cells in it!
                      Grr.
                      Add insult to injury, 3 of the 6 cells were shorted, 2 were at 3.5v, and the 6th was at 2.5V.
                      Oh well, $1 for 3 18650-2Ah cells...not great, and who knows what the true capacity of the cells are, will need to test them further...
                      fake capacity cheap china cells strike again! on aliexpress, they have 9ah 18650 cells and li-po cells flying around the place. russians bought them and were not amused about the overpromised, exaggerated capacity. lol!
                      whats the whole complete part number of those cells? it doesnt say. are they samsung sdi icr18650-26j m flat-top cells? max discharge current according to the datasheet is 5.2a continuous? there is also a review of the batteries at this link: https://lygte-info.dk/review/batteri...(Pink) UK.html
                      apparently, u can "overclock" this model of 18650 cell up till 7a max discharge current continuous without capacity loss! very nice! i intend to rebuild a laptop battery pack that has 75% wear level on the cells so high discharge current cells would work well for this purpose. not sure if 7a max discharge is enough for e-cig smoking and vaping usage... hehehe! im getting more adventurous during my lithium battery playtime! pray-tell i dont self-immolate like eccerr0r said and end up on the news for the wrong reasons. lol!!
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        oh here's the 6S1P BMS for the "4AH" pack...
                        only connections to the 6 batteries are the B+ B4 B2 and B- terminals.
                        Though it appears to have temperature sensing, there's no balancing that I can see, but does have protection. and probably fuel gauge capability. hmm. what can I salvage from the board....the mosfet? :\
                          • Jul 2011
                          • 6070
                          You could use it as is just remove the battery terminals off the board and use wires instead of metal terminal posts if you need a 24 volt battery power supply that way you can use the temperature sensor on the battery pack
                          The easiest way to remove the metal battery terminals from the board is to put new low temperature solder on it and heat the solder until it flows and remove it from the board while it still flowing
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8706
                            but it's a garbage bms because it does not check some interstitial nodes! Need to find one that checks all interstitials.
                              • Jul 2011
                              • 6070
                              What is the meaning of the words in red I googled it but the word meaning comes back as medical term unless it is misspelled
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8706
                                read the wikipedia page and replace cell...with cell.
                                BTW: note that 6S has how many connections, and how many battery connections are there on the BMS board I have (hint: there are 4). Should be real easy to figure out what interstitial means in this case.
                                  • Jul 2011
                                  • 6070
                                  Did you mean this word instead “ Interconnects”
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8706
                                    No... though in some cases it can be synonymous.
                                      • Jul 2011
                                      • 6070
                                      They are running a sale on Samsung battery that are made for power tools for a limited time
                                      https://www.18650batterystore.com/pr...sung-25r-18650
                                      There other models and brands that are also on sale I get there new letters this where I bought the 21700 a few months ago they are not fakes
                                        • Jul 2011
                                        • 6070
                                        These battery are testing new they must not have been cycle very many times the discharge looks excellent and well worth the money
                                          • Jul 2011
                                          • 6070
                                          Originally posted by ChaosLegionnaire
                                          I intend to rebuild a laptop battery pack that has 75% wear level on the cells so high discharge current cells would work well for this purpose.
                                          One thing you should consider and know is that on some laptops battery packs when you go to put new battery cells in them if they have micro controller in them it locks the BMS board and will not function properly anymore
                                          From what I understand if you keep power on the battery terminals supposedly you can keep it from locking up but I have not tried this myself so I can not tell you if it works or not
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • flat-earther
                                            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                            by flat-earther
                                            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                            I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                            The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                            So I need to connect another battery in...
                                            06-08-2025, 02:00 AM
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
                                            by sam_sam_sam
                                            I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
                                            I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
                                            06-18-2023, 05:48 PM
