Here is a good used source for 18650 batteries
    • Jul 2011
    • 6033
    Re: Here is a good used source for 18650 batteries
    Quantity 10 = $16.65 shipping to my address
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8696
      hmm...shipping kills the deal...
        • Jul 2011
        • 6033
        Just how much are you willing to pay for shipping just curious
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8696
          well if I wanted to buy $16 worth of batteries (or even more) and had to pay $16 shipping, well, it doubled the cost of the batteries...
          I'll have to see how much batteries I really want... and since these are perishable I really don't want to overbuy.
            • Jul 2011
            • 6033
            What I can tell you is if they are brand name batteries they last at lease 3 to 5 years that much I can tell you
            You just got to check them every so often to make sure that they have not gone below a certain voltage which I have not been very responsive to so I have had some go bad because of my own laziness
            But I would agree you about over buying them but I am going to build low voltage power high amp hour battery for my tablets I just have to finish testing a lot of batteries but the first project that I need to finish is the battery pack for the battery operated air compressor that I need to finish testing the batteries and I hope that I have enough of the same milliamperes hours rating that are close enough to each other and then make a 12 volt jumper battery pack out of some of them that use a PWM controller to being with then switch to a boost converter control the amperage to the vehicle battery until the vehicle battery can start the vehicle or least is the plan ( which I have to test this concept to see if it is doable )
            I have seen some people on YouTube that have used this type of battery to start a car with the only issue is over charging the batteries that is the only reason I have not tried this yet but I have even thought of using 4 battery cells instead of 3 batteries but then you have an issue of the batteries not getting fully charged so I am not sure what the solution to this problem is
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8696
              yes craptacular life. Should just get LiFePO4 cells and do away with the LiCo/LiMn cells...
              Yep need to stop it from charging when done, though technically speaking they have protection boards that work for drones that pull large fractions of a horsepower. Starter motors are only like 4 horsepower max... and could work with more of the same circuit in parallel.
                • Jul 2011
                • 6033
                I have started testing the batteries in this battery pack and I am not real impressed with the results so far
                The rating for these battery are supposedly over 8 amp hours however it falling just short of 8 hours more like 7.2 amp hour not real bad but would be better if it were over 8 amp hours
                But now let’s see if the majority of them test close to each other if they do this would be great
                https://batteryhookup.com/products/2...41044571062434
                The description of this battery pack its says that it is 7s3p and 21 batteries but 7s 2p and there 28 batteries instead of 21 batteries so I suspect that the watt hours are not correct either
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8696
                  Hmm... picked up a 4S 40Wh laptop battery for $1... Unknown condition, theoretically fresh off boat... Wonder how bad this pack is...
                    • Jul 2011
                    • 6033
                    From EBay or some where else or from that surplus place that you mentioned earlier
                      • Jul 2011
                      • 6033
                      But now let's see if the majority of them test close to each other if they do this would be great
                      The description turns out to be correct very strange the way this battery pack was put together
                        • Jul 2011
                        • 6033
                        Here is a super nice battery pack it tested way better than it is saying in the description
                        https://batteryhookup.com/products/2...-6-4a-299-99wh
                        I tested half of the battery pack because I split it in half which is very easily done just take the buss bar off and remove a few screws and now you two 28.6 volt battery packs when fully charged and 21 volt when discharged
                        Now I going to test the other half of this complete battery pack before I split in half
                        1.5X4=6 amps hours what the battery specifications are I got 8182 milliamperes hours
                        I just got to find a low watt pure sign wave inverter and the solar controller that someone talked about in a post I recently read
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8696
                          It was the local store, alas there was only one.
                          I need to dispose of the cells I destroyed by overdischarging by accident. Probably holding around 500mAh now
                          How do you split a 13S pack in half?
                            • Jul 2011
                            • 6033
                            It is really a 13s I was confused about this at first but if you take a volt meter you figure out that it one pack has 6 cells and the other one has 7 cells
                            I slightly over charged the the 6 cell side to 4.66 volts this is reason I such high milliamperes hours rating and the funny thing is that it did not over heat which was a good thing ( but it is a good thing that I was only charging it at one amp so each cell was only getting about 250 milliamperes it did get a little warm but nothing terrible to be concerned about )
                            The other side I did not fully charge I will have to redo it to get a more accurate milliamperes hours rating of this battery pack
                            Actually I need to retest the first battery pack again for a real milliamperes hour reading
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8696
                              at least it didn't immolate...
                              Charging that high probably cuts some cycle life...
                              What will you do with the 6S vs the 7S halves?
                                • Jul 2011
                                • 6033
                                I going to buy a couple of more of them and pair them up so that I the same exact number of cells for each side
                                Although the 7 cells one is a little odd 29.5 volt battery pack right now I do have anything that I use it on with out putting some kind-a of regular on it
                                I have a use for a 8 cell battery packs but not 7 cells
                                I have uses for a 6 cell battery packs but not 7 cells
                                Oh by the way I will not be charging it that way anymore I thought they were the same on both sides but they are not
                                It might have but I think it would be worse if you continuously over charging it which do not plan on doing
                                  • Jul 2011
                                  • 6033
                                  Maybe not try this before you throw them out
                                  Put them on a very slow charge over night and see if they will come back ( like 100 milliamperes or less and just keep an eye on them )
                                  I have also done this in the past and sometimes they will come back but one cell at a time not a bunch of them together
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8696
                                    Oh they charge fine, got them back up to 4.2V and they don't warm up...just doesn't hold as much energy as they used to.
                                    BTW I overdischarged them to like 1V or so. Not down to 0 but well below the 2.5V typical low voltage. They were running 2S with a fairly substantial load, and were still producing electricity when I stopped it, but they have not behaved the same since.
                                      • Jul 2011
                                      • 6033
                                      This is weird what brand are these batteries
                                      You are not using a BMS protection board
                                      I will test batteries with out a BMS protection but not use them with out one
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8696
                                        I was trying to balance them outside of the BMS balancing... with the other two that are weaker but ended up killing them instead....uuggh.
                                        They are panasonic IIRC.
                                          • Jul 2011
                                          • 6033
                                          Unfortunately I have seen this also but this seems to happen to certain series of them but not all them
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • flat-earther
                                            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                            by flat-earther
                                            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                            I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                            The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                            So I need to connect another battery in...
                                            06-08-2025, 02:00 AM
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
                                            by sam_sam_sam
                                            I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
                                            I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
                                            06-18-2023, 05:48 PM
