Here is a good used source for 18650 batteries
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8697
    Re: Here is a good used source for 18650 batteries
    mmm... need to start getting/building packs that approach to the kilowatt-hour mark...
    Them again, starting to collect too many bad cells too, in laptops I still use... ugh.
      • Jul 2011
      • 6037
      I have the same problem I have a collection of bad cells that I need to figure out what to do with them but I going to wait until I have finished building some of these battery packs before I deal with this issue
      Battery Hookup had some brand new batteries for sale about a month ago that had never been used but there was a catch that they were being prepared for welding them together however there laser machine that would be used malfunction so company sold batteries surplus but use some type of glue on the negative side of the battery that need to be cleaned off to be able to used them which took some time to do but I have tested some of them and they are 3 amp hour batteries from Panasonic and these batteries were $1.00 each and came in a box of 30 but they did not last long for sale I bought 3 boxes of them I still have to clean only one more box of them but this set of them have some type of soft glue that get everything glue-e and I have not figured out how to clean them with out getting the glue everywhere
      And the reason for why these were sold for a dollar each
      You need to clean the glue off and
      You need to put heat shrink tubing on them because they come natural with only the metal housing showing
      But Battery Hookup supply you with the heat shrink tubing already cut to the correct size and the fish paper for the positive side of the battery terminal
      You have to test them for current capability to make sure that all battery cells are testing good before being used
      I do not mind having to process batteries in this condition yes it some work to do this before you can test them and before you can use them but they are brand new and have not been welded on which is a plus for me
      These batteries are going to be used in a battery housing that I bought on eBay that is for 12 volts at 18 amp hour which can hold 48 batteries in it ( 3s@16p ) and still have enough room for the BMS protection board in the case I just need to make sure that the BMS protection board that I have with fit into the housing
      Unless I want to pay $75.00 for a BMS balancing protection board that has Bluetooth capability for being able to watch the battery on charge and being discharging while being in use I am thinking about buying it but have not completely decided on this yet
      https://www.ebay.com/itm/23386178568...0AAOSwrDRhXXSO
      Which if my calculations are correct this would be a 48 amp hour battery pack wow
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8697
        Damn. It's an off-brand battery pack so who knows what's in it, was meant to be a clone of a name brand tool of some sort.
        But I got an OK from the shopkeeper to bring in a contraption to test it. A multimeter isn't enough IMHO (BTW, the LED fuel gauge reads "full"), I need to load test. now I need to design and build a test circuit of some sort that I can carry into the shop...and hope it doesn't get sold to someone else...
          • Jul 2011
          • 6037
          All you would need is a couple of automotive type headlights as a load and use the fuel gauge on the battery pack this will tell you that the batteries can take a load it just would not tell you for how long it would run the load unless you could stand there for a few minutes with the load hooked to the battery pack but it might let you know if you had bad battery cells or not
          This would be better than not testing it at all
          If you can test it for several minutes and it does not dim down much and the price is right I would take my chances on them
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8697
            Minimum I'd have to have two identical headlamps in series and a multimeter I suppose. but I don't have two headlight bulbs. Actually maybe I do but they're halogen capsules that are kind of dangerous to operate outside of encapsulation. Ugh, don't think I should do that.
            This is 0.125kWh/pack. The hope is that it can light two headlight bulbs in series without voltage depression.
            Alas still not close to target capacity, but it is ~ 10Wh/$1 ...
              • Jul 2011
              • 6037
              You could also use so MR16 50 watt one if you do want use the automotive type head lights
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8697
                yeah at least those are safer than bringing two bare 9004 bulbs which I do have...
                The only MR16's I have are a 20W and LED MR16s but LEDs aren't a sufficient load.
                I have one 10Ω 50W resistor. That's the best I have for a safe load for now, but that too is insufficient. Else I have a lot of TO3 transistors that I'd have to tune the load for, but those I surely need a heat sink for. I suppose I need to shoot for 1C load so that's around 150W, that's a lot of heat.
                If only I had what you just bought...
                  • Jul 2011
                  • 6037
                  Here is an update on these battery packs that I bought
                  This battery pack does give me 7800 milliamperes hours like it suppose to and the BMS protection board does work correctly this battery pack will be used as it for my LED yard light
                  Here are the exact results 7739 milliamperes hours @ 27.001 volts which is close enough to 7800 milliamperes hours in my book
                    • Jul 2011
                    • 6037
                    Here is something that you might be interested in
                    https://www.ebay.com/itm/27470971681....c100290.m3507
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8697
                      Well... measurement won't be a problem, I have to collect this data for my GTI anyway so having it separate is kind of superfluous... again getting the batteries is the hard part
                        • Jul 2011
                        • 6037
                        You might be interested in item that Battery Hookup has these back in stock again these are very good batteries you might receive them very - very discharged but they will charge back up with no issues and they will have very close to the rated milliamperes hour rating that they claim to have I have tested several different packs and I just bought 4 more of them to have enough for a project that I have in mind
                        https://batteryhookup.com/products/8...-cells-ibh9100
                        If you want to buy some do not wait very long because they will be out of them again
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8697
                          3.8 * 3.2 * 8 for $8 = 12Wh/$
                          BH also has those 3.75V 5AH used packs 19 for $25 = 14Wh/$
                          Also need to +shipping... how much do they charge?
                          Think there are more options there... just tough to choose...
                            • Jul 2011
                            • 6037
                            for $25 = 14Wh/$
                            I have not tried these battery packs because they pouch battery packs and I am not a big fan of them
                            Because they have two different types of metal for the battery terminals and unless you have a certain type of battery stud welder they become useless one terminal you can solder to but not the other terminal if you happen to tear off the soldering tab you can not solder to the remaining terminal
                            it starts at $16.00 based on weight once you go beyond a certain amount of weight then the cost goes up
                            From time to time they have modern battery pack this is a good option if you do not mind a little bit of work to open them up but they have been out of stock for a while now ( but the problem is that you do not know what brand of batteries you are going to get this is the reason I do not mention them as an option )
                            They have an option for 10 pound ( power tool battery packs ) for a certain amount of money I do not recommend this option because most of them will be bad cells not worth the cost nor the time to see if there are batteries that could be salvaged there are nicad battery packs in this mix I bought this one time never again
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8697
                              ouch $16 shipping means to reduce shipping to less than 10% need to order $150... hmm...
                              still wondering about that other pack available locally - no shipping... but cell quality is questionable...
                                • Jul 2011
                                • 6037
                                Well here is the data on all four battery packs
                                One was 7400 milliamperes hours after cycling them several times before it reaches this point each battery cell 2100 tested separately charging and discharging curves look not very good but battery still can be used in other devices
                                Two were at 7600 after two cycles at 24 volts cutoff
                                One was 7800 was at after only one ( rechecked results) cycle at 24 volts cutoff voltage best performance battery out of the 4 battery packs that I bought
                                  • Jul 2011
                                  • 6037
                                  Here is something you might be interested in
                                  https://batteryhookup.com/products/2...-cells-molicel
                                    • Jul 2011
                                    • 6037
                                    Here is something new at BH
                                    https://batteryhookup.com/products/p...ah-18650-cells
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8697
                                      hmm... dang... need to know exact shipping costs...
                                        • Jul 2011
                                        • 6037
                                        Here is how you do this put the items in your cart and go to the screen for shipping and it tell you what the cost is and I have never have been charged for more than what it has been shown
                                        Or tell me what item you are interested in and how many you want and your zip code and good fictional address near you and I can tell you what the shipping cost will be
                                        The most that I have been charged for shipping is $22.00 for 30 pounds this is why they use FedEx and not UPS
                                        For this item
                                        https://batteryhookup.com/products/2...v-power-module
                                        One note if your total is more than $100.00 you have to sign for this order
                                        I will caution you that if you do this more than 2 times on different items and you do not sign out of your account it gets confused and will not give you the correct shipping cost just wait a few minutes and go back to what you are interested in and put it in your cart but it will give you an error message that it can not calculate correctly
                                        One other note be aware that when it gives you a delivery date do not be surprised if it does not change at least one or more times if it tells you Saturday or Sunday it might be Monday unless it says that it is out for delivery this is one reason I am not a big fan of FedEx delivery service but they are cheaper than UPS but they are more reliable than FedEx most of time when it comes to telling you when to expect your delivery
                                          • Jul 2011
                                          • 6037
                                          Quantity 2 = $16.65 shipping to my address
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • flat-earther
                                            Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                            by flat-earther
                                            I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                            To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                            I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                            The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                            So I need to connect another battery in...
                                            06-08-2025, 02:00 AM
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                            Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
                                            by sam_sam_sam
                                            I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
                                            I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
                                            06-18-2023, 05:48 PM
