LED Project ... LARGE SCALE
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Have a friend who bought a 48 foot 5th wheel and he's had a lot of experience driving these things all over the country and he wants to have a large and NOTICABLE LED display that lets drivers know when he's changing lanes, turning etc. because he says people are stupid and don't pay attention...
    I took his idea and I created these pictures to see if we're on the same page and he liked what I showed him...
    But now ... my problem is ... how to BUILD such a thing ... I'm thinking that it could be constructed with led Panels but I don't know where to source them. Does anyone know of any good sources for fairly large LED panels of different colors?
    Thanks,
    sigpic
  • redwire
    • Dec 2010
    • 3912
    Re: LED Project ... LARGE SCALE
    Trailer lighting has regulations and standards, from DOT, NHTSA, SAE, Federal etc.
    They dictate colour, brightness, axis and location etc. based on trailer size.
    It's to prevent the Wild West of LED vehicle lighting and people getting sued for confusing the sheep.
    I would get confused if it's looking like a signal light, but up high on a vehicle - just like roadway barriers. I should move over a lane? verses the truck is turning. And it's amber but the tail light is red.
    The 5th wheel would better use additional side markers (as turn signal lights), just like semi trailers. Otherwise very hard to tell when you're alongside if the signal light is on. Up so high may be missing the point.
    I would look at what is already out there for LED lights because it's gotta have the right viewing angle (and aimed down), be waterproof, sunlight UV proof etc and kinda hard to design all that.
    Didn't see any spec between an arrow and solid lamp, I only see that on fire trucks and ambulances and Ford Mustangs. It's not as good doing the sequential flashing, hard to see the flashing from a distance IMHO.
    I did some car brake light designs with mcore pcb and Cree XP-E and also some chinese 3W bead LED's so it can be done.
      • 31137
      you can already get light bars that do all that and more for breakdown trucks and emergency vehicles.
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        Where?
        sigpic
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          That link to the federal regulations ... IS ONE FUCKING HUMONGOUS DOCUMENT!
          Almost 200 pages when printed to a PDF file.
          sigpic
          • diif
            • Feb 2014
            • 6978
            • England
            Does the trailer being towed have lights and indicators on it?
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              Not sure yet what it's got, here are some pictures of it taken yesterday when they went and picked it up ... it's a BEAST!
              sigpic
                • 31137
                how does the pickup supply the trailer brakes??
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  There's a device in the cab of the truck called a brake controller and it sends signaling electronically to the 5th wheel and a receiving controller then applies brakes proportional to how far down the brake pedal is pressed in the truck. Kinda cool tech I suppose... It has to be calibrated because each brake pedal is s little different in their throw.
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    I think towing something that long would really kinda suck ... think about making a right turn at a standard intersection ... you would have to start wide ... and here's where the lighting comes into play ... dumb asses who don't pay attention see the gap on the right side and worm their way into that area when all you're trying to do is make a right turn. So having really bright, attention-grabbing lighting on the back that tells people what you're doing would most definitely serve their best interest as well as yours.
                    sigpic
                    • eccerr0r
                      Sell or Shim Solar panels?
                      by eccerr0r
                      Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                      However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                      So now what to do with these small panels?
                      I could sell them...
                      Or I could shim them....
                      03-29-2025, 01:07 AM
                    • earz
                      Removing large LCD panels
                      by earz
                      I'm curious what techniques everyone uses to remove/move/lift large LCD TV panels when doing backlight repairs. I typically use two large suction cups, but lifting a 65" panel off a LG a month ago and I got a little too close to the wall and accidentally crammed the corner of the panel into the wall (gouged the drywall even) which resulted in a single crack all the way across the panel. Thankfully I just do this as a hobby on TV's that I scrounge up to repair and sell, so I didn't have to make a dreaded phone call to a customer.
                      That incident got me thinking about making some...
                      05-19-2021, 10:42 PM
                    • AJ847.63e
                      BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                      by AJ847.63e
                      Hi All.
                      Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                      The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                      09-18-2023, 06:42 PM
                    • Grouickman
                      Hofmann geodyna 6300 Wheel balancer
                      by Grouickman
                      Hi there,
                      First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
                      Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
                      I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
                      I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
                      03-31-2025, 05:29 AM
                    • BOSCHNJAK
                      by BOSCHNJAK
                      ABOUT ME INTRODUCTION FILE
                      2
                      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                      2022 BEV, PROJECT ?
                      2021 BEV, PROJECT ?
                      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                      12-28-2023, 02:09 PM
