Meters and Microamps
    • Jul 2011
    • 6057
    Re: Meters and Microamps
    Originally posted by redwire
    There are Fluke multimeters for sale where someone bridged the fuse... really common with automotive techs on 12V systems... the shunt and bridge rectifier get burned badly, tons of smoke.
    Siba are excellent fuses but too they're snobby to have distribution in North America.
    I wonder if HiFi-Tuning fuses would work? Gold-plated, none of this ugly overpriced Bussmann stuff. The diode symbol contains the electrons.
    "ceramic casing, rather than glass, for better resonance characteristics"
    "-196ºC cryogenic immersion bath treated for maximum clarity"
    Same price as the Bussmann
    The KTK-R-1 is even faster acting than the KTK-1 I have used both before and if I was going to use a fuse for my Fluke meter I would recommend using the KTK-R-1 they cost about $20 to $25 each depending where you buy them the only issue is that the KTK-R- series does not have as many selections to choose from as the KTK- series does ( but I would use either one and limit the amount of voltage I would check to 480 volts with this fuse )
    I send “ Siba ” and email for some samples of there 1000 volt 1 amp fuses and asked them where I can buy them from ( I will post there respond in general when I get a response )
    I have in the past ordered from Element 14 Great Britain before which has them in stock but it’s a small issue about doing it
      • Jul 2011
      • 6057
      I did get a response from them for a vendor that not very far from where I live
      So when I am ready to buy some of there fuses I will give them a call and probably would have to order them I doubt that vendor would have them in stock
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        The KTK-R series has a diode in it ...
        So much for making holders that rejects anything but specific fuses, but yeah it looks like the KTK-R will blow at rated current even, after a little while. The KTK fuse without R will pass the rated current indefinitely.
        • redwire
          • 3912
          KTK-R have the end bump (spring inside?) 600VAC 200kA fast interrupting capacity. USD $27
          The curves look better, the 10A blows at 20A just under 1 second and carries 15A forever. What you'd expect.
          The multimeter fuses are 1,000V but so slow.
            • Jul 2011
            • 6057
            So you for a fuse that carry the current you are looking but find one that blows at the current you want to protect it from
            But only use those charts as a guide because what they have is not exactly right because I had an issue with a VFD drive that I wanted fast acting fuses in it and I tried to use that chart and found that it would blow some what sooner than I expect them to ( this was because of the inrush current not being exactly the same each time the motor would start
            For this type of application for a multi meter it might be more accurate but some testing would be in order to make sure that the results you get you expect
              • 31157
              i could never pay 2digit numbers for a fucking fuse.
              i would rather change the clips from 10mm to 6.3mm or even try to gut a 10mm fuse to see if the internal diameter is enough to slot a 6.3mm fuse inside it!!
                • Jul 2011
                • 6057
                When you do this please post some pictures of this modification I would be interested in what you come up with
                  • 31157
                  i was just thinking of ripping an endcap off and putting a spring in it to tension the shorter fuse.
                  i got the idea because i'v had fuse endcaps pull off by accident in the past.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Please include carnage from trying to pass 100kA and it fails to rupture
                    TBH I had a unshrouded clip type ¼x1¼ fuse holder (one that's on a small hard piece of plastic with faston connectors on both sides) and the outside diameter of the clips perfectly fits inside the 10mm. Perfect jury rig!
                    (and it would happily pass 100kA until the smoke comes out...)
                      • 31157
                      if you really need a 1000v fuse that can break the output from a power station then your probably using the wrong meter for the job.
                      go buy a Hioki with the seperate current-clamp!
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Fuse stuffers! ... like cap stuffers!
                        Was seeing if this old burned buss fuse's caps would come off easily... nope...ugh.
                        BTW it doesn't sound like this 4A one I'm playing with right now is sand filled, and it's 10kA IR.
                          • 31157
                          new plan:
                          drill the endcaps and poke a length of fusewire through it - then solder the ends
                          • redwire
                            • 3912
                            I could not find much for "fuse adapters". The really old appliance/house screw-in glass fuses, guess who came up with a custom socket size? Good ole Bussmann. He seemed hell bent on making fuses tamper-proof... and proprietary.
                            I'm not sure how the end-caps are attached on ceramic fuses, it must be heat but that would melt the element. Melamine uses a hard crimp.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              I'm not sure I want to throw out the rotten caviar (the burned out fuse) yet... what else can I do with it before it goes into the round file?
                                • 31157
                                drill it
                                • redwire
                                  • 3912
                                  If you drill a hole, that assumes the new fuse-wire can be soldered, and I'm not sure if it's some low temp alloy.
                                  It looks like heating up fuse endcap with a soldering iron or on a stovetop element can free it up. Wearing safety glasses. There's no glue because that can't take 1,000C high temperatures.
                                  https://www.instructables.com/commun...ll-glass-fuse/
                                  I see many fuses made with the end-wire just folded over the ends.
                                  Apparently as long as the wire passes through the tube diagonally so the sand can quench the middle portion.
                                  The crimped Melamine fuses, I think they would not be something you can diassemble, I have to look at Voltlog videos see how he did it.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    I would think glass needs to be glued, maybe with CA glue and hence heat will free it up. The running temperature of fuses doesn't need to be 1000°C all the time like a light bulb, so that should be fine. Can't be crimped as the glass will not like it. I've seen some where it has two caps that have holes in them - and the fuse wire really is simply soldered in place.
                                    These caviar fuses are melamine or something like that and most people I see has cut off the cap, which defeats the purpose *sigh*
                                      • 31157
                                      glass fuses are glued with that brown stuff they use to hold the cap on lamp bulbs.
                                      ceramic fuses are press-fit or they have kind-of crimped the inner edge probably by spining it between some rollers.
                                      the fiberglass ones are crimped into the glass-mat and you wont get one open without cutting the end off the cap.
                                      not that you have anything to lose doing that.
                                        • 31157
                                        btw, i see fluke charges about $150 for a 320x240 monochrome lcd display for their high-end meters.
                                        keeping in mind a 320x240 colour IPS display of similar size from china is about $8 they are clearly just out to fuck meter owners at every opertunity.
                                        • eccerr0r
                                          lowest current galvanometer/analog meter (passively powered!)
                                          by eccerr0r
                                          Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                          On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                          04-16-2025, 12:41 AM
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                          Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
                                          by sam_sam_sam
                                          I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
                                          https://www.aliexpress.us/item/32568...yAdapt=glo2usa
                                          What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
                                          03-30-2025, 11:05 AM
