Re: Meters and Microamps
The KTK-R-1 is even faster acting than the KTK-1 I have used both before and if I was going to use a fuse for my Fluke meter I would recommend using the KTK-R-1 they cost about $20 to $25 each depending where you buy them the only issue is that the KTK-R- series does not have as many selections to choose from as the KTK- series does ( but I would use either one and limit the amount of voltage I would check to 480 volts with this fuse )
I send “ Siba ” and email for some samples of there 1000 volt 1 amp fuses and asked them where I can buy them from ( I will post there respond in general when I get a response )
I have in the past ordered from Element 14 Great Britain before which has them in stock but it’s a small issue about doing it
Originally posted by redwire
View Post
