Honeywell quartz clock component
  • sofTest
    • Aug 2008
    • 361
    This quartz clock is increasingly slowing. The capacitors (one removed in picture), resistors and diodes tests OK. I'm suspecting the 4194.304 kHz quartz crystal, but don't have any tools to test it. The clock is about 20 years old, and the oscillation might be failing.
    I'm wondering if anyone can identify the component I've ringed on the picture. There are no markings on the board.
    I'll probably order a new crystal at DigiKey next time I've got something more to order. Does anyone know how much importance the Load Capacitance has on a crystal? I can't find a datasheet on the original ITT 1385 part.
    Thanks for any help.
    Be a mensch
    • 31095
    Re: Honeywell quartz clock component
    that looks a lot like a fuse.
      • 31095
      btw, the green ajuster on the right is a variable capacitor to fine-tune the crystal - maybe it's contaminated (fucked)
      • sofTest
        • Aug 2008
        • 361
        Thanks for the input.
        I've enclosed a picture of the trace side of the board. If the brown component were on the power input, I would have thought it was a fuse also. Also there is no continuity across the legs of the component. The clock does work (slowly), so I knew there was no broken fuse. So I just did something I didn't think of before, measured the capacitance. Bingo, 122.2 uF. So, the brown component is some kind of 100 uF 10v capacitor (ESR 0.75).
        I thought the green component was a variable resistor, but wouldn't bet on it. I can measure resistance, but no capacitance, in circuit.
        Be a mensch
          • 31095
          is the thing in the yellow paper sleeve a backup battery?
          the brown thing looks like a fuse 2a if the foto was better i'd bet it had a voltage printed too.
          the green variable capacitor wont show on most meters - it's in the pf range.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            looks like that dammed brown glue on the trimmer.
            likely the problem.
            cusses and resumes digging the stuff from a ts-440 vco......
              • 31095
              you do RF work?
              rather you than me!
              • Radio Fox
                • Jan 2010
                • 281
                Originally posted by sofTest
                This quartz clock is increasingly slowing...
                What kind of error are you getting?
                As stj says, the green component is a low value (2 - 22pF ?) trimmer capacitor. It's purpose is to trim the crystal so that it oscillates on it's correct frequency.
                Adjust it slightly to see if it makes any difference to the accuracy of the clock. I have found that those trimmers tend to stick, so give it one complete revolution first, to free it up.
                ________________________________________________
                Invisible airwaves crackle with life
                Bright antennae bristle with the energy
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  that board looks awful burnt...
                  sigpic
                  (Insert witty quote here)
                  • Radio Fox
                    • Jan 2010
                    • 281
                    Originally posted by stj
                    ...the brown thing looks like a fuse 2a if the foto was better i'd bet it had a voltage printed too...
                    Looking at the tracks on the back of the board, that component is in series with the clock mechanism, so if it was a blown fuse, the clock wouldn't be working at all.
                    • sofTest
                      • Aug 2008
                      • 361
                      The yellow thing might be a battery, but dead now. No markings on it. Just a metal can under the yellow paper. There are +/- markings on the trace side of the board for it. Could a failed battery cause this? The circuit doesn't seem to depend on it.
                      As I said in my last post, the brown thing is a capacitor of some type.
                      Among the ranges my meter do, is 0-500 nF, lowest 0.01 nF, so it should measure from 10pF and up.
                      likely the problem.
                      No glue on this board.
                      The time on the clock slowed increasingly. Around Christmas at a rate of 16 hours a week, until I replaced it last Tuesday it slowed 48 hours of the past 72 hours. So the problem was accelerating. That leads me to think of a failing component, not an adjustment being off.
                      The trimmer doesn't stick. I've tried to find information on failure of trimmers, but have not found anything. What are their failure modes?
                      No, not burnt at all. Old type circuit board.
                      Thanks all.
                      Be a mensch
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        I thought in a clock of this vintage they would use a synchronous motor.
                        I have a GE radio / clock from the 80s and it uses a synchronous motor with 50 or 60 Hz capability. Nothings a cheaper timing pulse than line frequency.
                        That yellow thing does look like some type of battery probably a nicad rechargeable. A battery backup perhaps? If that's what it is there is no need to replace it.
                        I would check the trimmer cap it's possible that it's intermittent. There is no reason for a static setting to suddenly change without a drift or fault in some component.
                          • 31095
                          it's not burned, it's made from Paxoline.
                          something before your time.
                            • 31095
                            how wide & deep is that brown thing?
                            it's either a 100uf 10v electrolytic - ancient type.
                            or a fuse like this:
                            http://www.littelfuse.com/products/F...831200000.html
                            • sofTest
                              • Aug 2008
                              • 361
                              I'm not sure if I understand you correctly, but surely the crystal is the timer in a quartz clock like this? Or do you mean in general? There are several variants of this clock; at least 18V, 24V and 230V. So I'm guessing one design, with minor alterations.
                              If the trimmer is meant to fine tune the crystal, would a fault in that cause a drift of 48 hours out of 72 hours? Doesn't sound like a fine tune. Also, wouldn't the crystal be as likely a candidate?
                              If the trimmer is in the range below 10 pF (as it seem to, if it's working), I've got no way of testing it. I could remove it, to see if that gives a stable drift.
                              Be a mensch
                              • sofTest
                                • Aug 2008
                                • 361
                                It's definitely a capacitor, as it got a capacitance of 122.2 uF. 11 mm wide x 13 mm high.
                                The weird thing, is that there is a modern type electrolytic of 16v 10uF there (removed on the picture).
                                Be a mensch
                                • Krankshaft
                                  • Jan 2007
                                  • 2328
                                  No I was talking in general. Synchronous motors don't need crystals their rotation is synced to line frequency no crystal is required. Since line frequency is stable it's a good time reference.
                                  Quartz crystals are very fragile it doesn't take much to damage them. One drop to the floor and you've got a 50-50 chance of a damaged one. The synthetic quartz is a tissue thin wafer. They also can become damaged or intermittent with age.
                                  The only way to check it is with a crystal checker hooked up to a frequency counter. Or a scope to eyeball it to see if it's outputting a stable frequency.
                                  Of course since this clock is line run (I don't see a transformer) if you had a scope you'd need to hook the clock up to an isolation transformer.
                                  I'd replace the crystal first and go from there. I thought the clock was just a little bit off if it's lagging as much as you say. Then the crystal which is the reference for the clock circuit would be the first suspect.
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    variable capacitor is open circuit and yes that can change the tuning so much. Replace it with similar from a old clock. Not rare.
                                    The type of components design tells me this is far older than 20. Looks like 30 years or older. Very early quartz clock.
                                    Cheers, Wizard
                                    • Radio Fox
                                      • Jan 2010
                                      • 281
                                      ...If the trimmer is meant to fine tune the crystal, would a fault in that cause a drift of 48 hours out of 72 hours? Doesn't sound like a fine tune...
                                      You're right. With the kind of inaccuracy you're getting, it's way beyond the fine tuning of that trimmer.
                                      I am wondering about the supply to the chip on that board. I assume there is a zener diode somewhere on the board, probably between the unknown component, and (what looks like) the battery. If it is a rechargable NiCad and is no longer holding a charge, then there's a good chance that one or more cells have shorted. This may be pulling the supply volts down, causing the chip to operate erratically. Just a thought.
                                      EDIT...btw, as Krankshaft has pointed out, this clock uses a transformerless mains supply. Be very careful if you take any readings while it is powered up!
                                      • sofTest
                                        • Aug 2008
                                        • 361
                                        I just noticed a faint stamp of E80 on the board, so maybe the clock is older than I thought.
                                        I don't have a scope or a crystal checker, so I can't do any tests on the crystal. Since a new crystal is only USD 0.58-0.75 at DigiKey, I'll probably just chance it, and order a new one next time I order in something. Do anyone know how to choose Load Capacitance in a crystal, when the original is unknown. Is it important?
                                        Be a mensch
                                        • shelby5041
                                          clock radio / radio lifespan?
                                          by shelby5041
                                          hi
                                          ive got a modern digital clock radio approx 15yrs old
                                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                          it uses very little power just a few watts i would imagine that may have something...
                                          09-14-2024, 03:30 AM
                                        • pc_okay
                                          Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                                          by pc_okay
                                          Hello friends,
                                          Its been a while, i wish you an happy new year 2025 !
                                          I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                                          Laptop take 0.11A.
                                          All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                                          I get no oscilation on XTAL 32.768 KHZ
                                          Battery is not charging but charging led is here.
                                          PCH heat at 30° approximatively. (with no heatsink)
                                          I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                                          It's a 2 pins Crystal.
                                          01-13-2025, 09:26 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • Fontana
                                          71R-H14BW6-T830, clock stops when shutdown
                                          by Fontana
                                          Hi!
                                          Funny problem. I have a board, model 71r-h14bw6-t830, it's a shuttle board used commonly on a lot of cheap laptops/AIOs.
                                          The clock (RTC) is not working when the machine is turned off. Doesn't matter if it is connected to dc power or not. When the PC is powered on, the clock works fine.
                                          I tried replacing Y6 and Y7 (picture below), but it doesn't seem to be an oscillator problem.
                                          I don't have the exact schematic for this board, but I'll provide one that is similar (a variation of the same board).
                                          Any suggestions?
                                          OBS: when the pc is off,...
                                          09-28-2022, 09:57 AM
