4.7 ohm fuse resistor?
  • stinger
    • Jan 2014
    • 57
    • usa
    I have a tv power board that had a few bad components on it that I replaced but still wouldn't power up so doing more checking, I found a 4.7 ohm resistor(fuse?) that was open. My question, does anyone know if a regular 4.7 ohm resistor can be used in its place until I can get the correct component just so I can try out the set?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: 4.7 ohm fuse resistor?
    If you want to possibly blow more components or start a fire, sure!
    • petehall347
      • Jan 2015
      • 4439
      • United Kingdom
      use metal film . they burn up gracefully
      • R_J
        • 9588
        It is likely the resistor IS acting as a fuse so simply replacing it without finding the problem is pointless, What is the power supply from? What is the power supply number? I would have no problem using it just to test the power supply.
        • stinger
          • Jan 2014
          • 57
          • usa
          It is the power supply board from a Vizio tv. I replaced the blown IC, a zener diode and a schottky diode the problems common in this set I guess. I will wait till I can get the right resistor so I don't do more damage.
          • petehall347
            • Jan 2015
            • 4439
            • United Kingdom
            makes me wonder why they blew in the first place . maybe just bad design or low grade parts .
            • stinger
              • Jan 2014
              • 57
              • usa
              Not sure why they blew but I am hoping they were defective and caused the resistor to blow also.
                Show us the board so we can see what we are dealing with, fusible resistor blow open circuit for reason: over current.
                • stinger
                  • Jan 2014
                  • 57
                  • usa
                  The power supply board and the probe points to the fusing resistor that's bad.
                  • stinger
                    • Jan 2014
                    • 57
                    • usa
                    other pic
                      The pictures are too out of focus for me to read the prints on the board, it looks like that fusible resistor is for the Standby power supply, so you need to look up the spec sheet of the 7-PIN SMPS IC and the check the pins to see if it has shorted out or has very low resistance between S and D pins of that IC.
                      You should also check the resistance between the negative leg of the main filter cap (big black cap laying on its side) against each solder pad of the blown fusible resistor.
                      • stinger
                        • Jan 2014
                        • 57
                        • usa
                        I replaced the 7-pin ic, the old one was blown. I also replaced one zener diode and the shottky diode. I get no reading between negative side of main filter cap to either side of blown resistor.
                          [QUOTE=stinger;1010157I replaced the 7-pin ic, the old one was blown. I also replaced one zener diode and the shottky diode. I get no reading between negative side of main filter cap to either side of blown resistor.[/QUOTE]
                          Ah the BIG missing information about that blown SMPS IC in post #1, now we know why that fusible resistor is blown since now we know what that fusible resistor being use for what section of the circuit using the requested pictures.
                          It always good to give us details info.
                          You can use flame proof MOX resistor for replacement, just match the Resistance/Wattage. For testing right now you can use 1/2W resistor and use the setup below to perform the test.
                          You can test the power supply board by itself to see if the standby power supply is working now or not by installing 75W incandescent in place of the main fuse, you should see the lamp comes on bright for second then it should dim down and then you can check the output of the standby power supply, if the lamp stays on bright then you still have issue on the board.
                          • stinger
                            • Jan 2014
                            • 57
                            • usa
                            Thank you
                            • magneh
                              Is this some kind of fuse resistor ?
                              by magneh
                              Hello guys
                              Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                              Seem to me like some kind of fuse resistor?
                              After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                              They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                              The red band is larger than the 4 others, but I dont have much experience with these components.
                              Also one of the orange...
                              02-10-2025, 07:54 AM
                            • corrize
                              Replacing resistor fuse in Sony DV charger
                              by corrize
                              Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                              So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                              It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                              06-30-2025, 06:59 PM
                            • corrize
                              A funny fuse story – Lumix LX100 II
                              by corrize
                              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                              10-19-2023, 09:58 AM
                            • MidnightRoller
                              Can a resistor lose resistance after hot air?
                              by MidnightRoller
                              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                              02-02-2022, 11:46 PM
                            • ttmi100x
                              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                              by ttmi100x
                              Greetings everyone,
                              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                              Upon closer inspection...
                              07-31-2024, 06:36 PM
