Ender 3D Printer but I am having problems with software help need
    • Jul 2011
    • 6057
    I bought this Ender 3 I have the slicer program installed but only a 1/4 of it is in English the rest of it is in Chinese there certain things I have not figured out how to use it correctly
    I tried to down load Microsoft 3D Windows Builder this is some real stupid shit to try to down load it
    You need a Microsoft email account and the activation of your account almost can not get it to work correctly because the activation your phone or other email account can not seem to get together
    Are there any alternative to this situation
    Before I go mad
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: Ender 3D Printer but I am having problems with software help need
    If it runs under windows, can you cut and paste the text into google's "translate"?
      • 31150
      take photo's or screen-caps of the menu's and put them in a translator.
      and forget m$ - they are currently suiciding themselves with this account + store crap!
        • Jul 2011
        • 6057
        Well is there a good free 3D printer creator software out that will work with the Ender 3 3D printer
          • 31150
          what file formats can you print?
          • diif
            • Feb 2014
            • 6978
            • England
            Cura for slicing and Tinkercad, Fusion 360 or Meshmixer for creating/manipulating 3D images.
            • clearchris
              • Dec 2013
              • 687
              I really like slic3r. Cura is overly complicated, somewhat undocumented and the features interact in surprising ways. Slic3r keeps it simple. None of it should be in chinese.
              If you are looking for design software, I like freecad and openscad. They are completely different, openscad is great if you are a programmer and you want to make parametric designs. Freecad is much better if you are desiging around existing objects (grabcad.com), but is harder to change designs. You should not expect to be functional in freecad without watching a few hours of youtube tutorials, especially freecad. For me, checking the openscad cheat sheet was good enough for me.
              If you don't have any experince and want a super basic, baby's first cad, a lot of people like tinkercad.
                • Jul 2011
                • 6057
                I did finally get the 3D printer put together and leveled
                I still have some tweeting to do before I will do a test print on this printer
                But all the axis run smoothly at this point
                The vendor that I bought it from has a installation video there is one item that he put a shim on the “Z” axis which was not need it just needs the plastic mount to be loosened and realigned the screw rod in the center of the rail and all bolts tighten evenly and now works correctly
                • clearchris
                  • Dec 2013
                  • 687
                  Do a 20mm calibration cube and make sure X, Y and Z are pretty close to what they should be. I printed a 100mm calibration rectangle yesterday on my printer (I thought something was up with my Y axis) and it came out to 100.04mm. Pretty good.
                  • Curious.George
                    • Nov 2011
                    • 2305
                    • Unknown
                    Have you ever printed anything "clear" (not "optical grade" but "clear enough to be used as an indicator lens")?
                    • clearchris
                      • Dec 2013
                      • 687
                      I haven't but I have seen people make small straight light pipes and they seem to work well. I just leave small peep holes.
                      Edit: You aren't talking about a fluid peep hole, are you? You know 3d printed objects aren't water tight, right?
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        No (to your second question).
                        I'm looking more for something akin to the lens/actuator on a lighted pushbutton.
                        So, it has to be reasonably clear -- to allow most of the light from the indicator to come through (otherwise, have to use a "brighter" indicator). It has to be reasonably "smooth" (as if made in an injection mold process) so it looks "professional" (I don't want to have to acetone wash to get the "ridges" out of the print). And, it can't be too brittle because I want to wedge something inside it (without having it snap like bakelite).
                        Most light-pipes tend to have small exposures so you wouldn't notice "manufacturing imperfections" in the visible end/edge. I'm looking for a larger surface -- like 3/8" round.
                          • Jul 2011
                          • 6057
                          Originally posted by Curious.George
                          light-pipes
                          Here something you might be interested in
                          https://www.goldmine-elec-products.c...?number=G23441
                          • clearchris
                            • Dec 2013
                            • 687
                            To get it smooth, you are going to have to sand it. We call that "post-processing". You can buy tumblers pretty cheap too. If you have expertise, you could make a tumbler also.
                            You could have success doing something like that with an SLA printer, but that's a whole different (and messy) process, and the printers are markedly smaller. Here is an example, not endorsing, I don't know much about SLA, except that I don't want one. https://www.monoprice.com/product?p_id=35435
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              Yeah, that just moves the "light" from one place to another. I also need the piece to HOLD a component and ACTUATE a switch (i.e., it must "float"). I'll design something that fits my needs -- I'm just not sure if it is worth printing a prototype or going straight to an injection mold...
                              Thanks, though.
                              • Curious.George
                                • Nov 2011
                                • 2305
                                • Unknown
                                I would think that would conflict with wanting to keep it "clear" (?). Wouldn't you end up with a "scuffed" surface (opaque) instead of "clear plastic"?
                                I know you can actually print optical grade lenses. But, that's pricey and not what I need. I just want to be able to quickly/cheaply prototype a "clear piece of plastic having a particular, odd shape" in quantities of a few hundred. The number of pieces is too low to make going to a (injection) mold economical; but, if it works, it would be silly to do anything OTHER than molded parts!
                                I will have to research materials, on-line, and probably contact a professional printer to get the best parts/samples -- rather than trying to print it locally.
                                • clearchris
                                  • Dec 2013
                                  • 687
                                  You could get "frosted". I don't think you could get clear with FDM printing.
                                  SLA is an entirely different story.
                                  https://formlabs.com/blog/3d-printin...g-clear-resin/
                                  IMHO, I did pay for a print before I bought a printer. I wasn't terribly impressed, and it wasn't cheap either. If you are doing prototyping, a small printer isn't a bad investment. You just need to make sure the printer you buy is capable of producing what you want to make. Because, let's face it, you aren't going to get it right on your first shot. So you are going to have to make another order, etc.
                                  The worst I have done is seven prints to get it right, but that was a smallish gear, and it had to be perfect. It's really nice to be able to turn around a few prints a day if you need.
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    That suggests I could get something printed that would meet my needs. But, I'm not sure that I would want to go to all that effort to DIY. (pay someone who already has the skillset rather than developing it, myself)
                                    I'd opt for leveraging something available at a local makerhouse, etc. I know one of the places, in town, has Wanhao Duplicator i3, Wanhao Duplicator 4, Printbot JR., an Ultimaker 3D Printer, and a Big Builder 3D. But, their tools change regularly so no idea what's "current".
                                    I was hoping to "get close" with a local print -- i.e., to be able to test for fit/form/function -- and then "order out" to a firm that could make a few hundred (they're small parts). I can do some testing (fit/form/function) just by playing with 3D CAD models. But, there are always little things that you only discover with REAL parts (like maybe some dimension needs to be increased to make something stronger... or, move to a different material, etc.)
                                    I'd rather let someone else muck with "getting it right" (i.e., meeting my specification) and spend my time sorting out how I can change my spec to make it easier to produce, etc.
                                    This is especially true when you consider that I'll have to repeat this process when I move to "production parts" (printing isn't economical in big quantities).
                                    • clearchris
                                      • Dec 2013
                                      • 687
                                      It wasn't the printer (entirely) that was wrong 7 times, it was mostly my design. Can't say I knew much about involute gears, and getting the size and shape exactly right was fun.
                                      You would think that sending it out would result in someone who knew what they were doing and had good equipment, but it wasn't the case with mine. I suspect you might be able to get a decent print these days, the technology has advanced quite a bit since I put my order in. I was kind of embarrased for the print house, I bought my printer for $160 a few months later and within a month of buying it, I was getting better quality prints than they sold me.
                                      Also keep in mind that you have to design for 3d printing. You can't just print any design, many will fail spectacularly. SLA is a bit more forgiving though. Anyway, if you want me to take a look, shoot me a PM. You probably don't want to post your design...
                                      • Curious.George
                                        • Nov 2011
                                        • 2305
                                        • Unknown
                                        There are tools that will "design" gears for you.
                                        My approach (to my problem) is to build 3D models of the various bits and pieces involved and then "assemble" them to check for fit, clearance, etc.
                                        What this won't tell me is if some portion of the printed part will be too weak to bear up to the forced deformation required to assemble the parts ("snap in"). It's nothing I've any first-hand experience with so its a crap shoot.
                                        Likewise, if there's enough mechanical strength in places that need it to hold up, over time. E.g., the battery compartment doors on all of my PSP's break... coincidence?
                                        I suspect I could do a finite element analysis but probably stanad a greater chance of screwing that up vs. just making some physical parts and "abusing them".
                                        That's always a problem -- unless you have a trusted recommendation. I'm assuming the technology has matured enough that it's no longer garage-shops trying to make a quick buck.
                                        E.g., I wouldn't think twice about trusting someone to make an oversized (feet by feet) print of a photograph for me, today. A decaded ago, I'd want to be in on the process to ensure it all went as planned.
                                        I have to come up with a solution that will work for a printed prototype as well as an injection-molded run. E.g., injection molding requires attention to draft angles, material shrinkage, sprue placement, etc.
                                        I have tools that address both approaches. It will just be a matter of "doing my homework" to make sure the criteria for one approach don't undermine the other...
                                        • re-atari
                                          Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
                                          by re-atari
                                          Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
                                          Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
                                          02-03-2025, 06:49 PM
                                        • Curious808
                                          Brother HL-2140 laser printer: printer error (solved)
                                          by Curious808
                                          SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
                                          Windows 10
                                          Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
                                          Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
                                          06-22-2023, 11:11 PM
                                        • Artefil
                                          HP officeJet 8012e ... A printer update will be installed to fix this problem
                                          by Artefil
                                          One of the partner I'm mostly working with, brought his Officejet 8012e, facing a problem I'm failing finding a solution.
                                          On the Officejet 8012e, there's only one USB connector on the back, for connecting the printer to a computer.
                                          The screen displays the following message :
                                          "a problem has occured with one of the printer's critical system files. A printer update will be installed to fix this problem"
                                          But even if the printer is connected through wifi to the network, nothings happen, and the printer stays idle for days.
                                          Have you ever...
                                          09-28-2023, 05:11 PM
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • прямо
                                          Need dump for 58mm Thermal Printer
                                          by прямо
                                          a friend gave me this printer because it's no longer working.
                                          It powers on, but won't do a self-test print and when connected via USB to Windows, Device Manager says No Printer Attached under USB Hubs tree.
                                          The red light doesn't blink either with no paper inside.
                                          I think the firmware maybe corrupted. If someone has a similar printer and can provide a firmware dump, I really appreciate it.
                                          Printer model: Panda PRJ-58U
                                          Flash memory: Boyamicro BY25D16ASSIG
                                          03-15-2024, 09:12 PM
