What is this device these guys jam into their PSU's??
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8326
    Enjoying the afternoon on the couch doing nuttn & watching youtube, I came across this device. I've seen this thing now as a 2 wire, a 3 wire and a 4 wire.
    So far I couldn't find it on Ali. These guys jam that oscillator on the primary negative capacitor and to the mosfet (depending on what wire configuration), adjust voltage and off they go!
    I can't imagine it working on complicated power supplies, but it got my interest in the moment.
    https://www.youtube.com/watch?v=Ku8Y0U8MZS8
    https://www.youtube.com/watch?v=dGEFUEHxLYc
    https://www.youtube.com/watch?v=ijS25rMuH0M
    https://www.youtube.com/watch?v=BX0Cu0DmCP8
    a different one: https://www.youtube.com/watch?v=6nktZW9czM8
    found this on Ali:
    https://www.aliexpress.com/item/3296...archweb201603_
    https://www.aliexpress.com/item/3297...888%233325%231
    • 31191
    Re: What is this device these guys jam into their PSU's??
    it's a slave switching psu that needs DC input.
    only good for the u.s. unless you want a big bang with 300v input limit
    i suspect it's designed to fit into psu's that have a dead output.
      https://www.aliexpress.com/i/33043556341.html
      for the 29-3 module.
      The problem using these modules is that the drive frequency that drives the power supply is not matched to the transformer/circuit requirement, also the issue with regulation and protection shutdown.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8326
        That is in line with with what I said earlier. It's for simple power supplies. I am aware of the 300VDC input limitation, but for a simple PSU who cares. Maybe I should be trying one of these in the Avaya or Nortel PSU's (just kidding).
        Now budm went right to the cheese: not matched to the transformer, regulation and protection.
        The most critical video of these was the one using only 2 wire hookup, having no feedback at all looks kind of dangerous.
          • 31191
          not sure what you mean, the one at ali had an opto-isolator on it.
            That Opto shown on the diagram on the unit is the existing Opto of the power supply you are trying to mod if it has one in the power supply you are trying to fit this Transformer driver into. That module is just a power transformer driver.
            I wonder what the drive frequency is and what the minimum operating Voltage is.
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8326
              watch this one. Only 2 wires are hooked up on the primary. One on the primary negative, the other on the gate of the mosfet, that's it.
              Me too... kind of curious buying one to try to find out. Problem is that I have to find something to stick it in. That department is empty at the moment.
              "Social distancing" and only essential business took it's toll on the "fix later pile". Dang!
              • redwire
                • Dec 2010
                • 3912
                I thought it could be used to replace STK-730 linear regulators which are for the 130VDC rail in CRT TV's. It looks like 300VDC in, 110VDC out SMPS.
                The transformer is way too small for the LCD TV "5-24V" version to have more than say 10W output. Weird some pictures show huge TO-264 mosfet but tiny tranny.
                Maybe it's easier to plop one of these in instead of troubleshooting the TV's power supply?
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8326
                  I don't think it is a troubleshooting issue, rather being a parts availability issue.
                    • Jul 2011
                    • 6063
                    This is a little off topic but you might be interested in this project that this person has done
                    I have seen this person a few time before in the past
                    https://www.youtube.com/watch?v=-mnhPGpyZ5U
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8326
                      Interesting guy... gives me something to watch for the afternoon. Thanks Sam!
                      • wnlewis
                        New wire for my RDE3340 Whirlpool electric range
                        by wnlewis
                        OK. I got the rocker switch figured out thanks to the good advice on this forum.
                        Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                        This is a Whirlpool RDE3340 electric range.
                        The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                        Where may I find parts...
                        01-08-2025, 11:21 PM
                      • emeskay
                        Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                        by emeskay
                        We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                        08-06-2024, 07:13 AM
                      • technicalspecialist
                        Vintage fan repair, copper wire question
                        by technicalspecialist
                        I currently have a customer's vintage fan on the work bench to repair.
                        It uses an induction motor with 4 poles. One of the poles is open.
                        I couldn't find the break so i cut off the original wire.
                        I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                        I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                        The enamelled copper...
                        03-16-2023, 12:54 PM
                        Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                        I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                        I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                        12-16-2023, 08:39 PM
                      • kalemaroni
                        Dell DC Brown wire
                        by kalemaroni
                        There are 3 pins on the back of this DC jack. Centre both left and right edges are the grounds for the black wires and a centre bottom is for the red wire. Where does the brown wire solder to? ...
                        08-26-2025, 10:10 AM
