Need a circuit that switches ON when a 5 volt source drops to 4 volts or less
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I don't know the first thing about where to even start looking for the result I'm looking for ... but what I want, is a circuit ... or maybe a certain transistor ... that will remain "closed" when the voltage at the base is 5 volts, but when that voltage gets to 4 volts or less, I need that transistor to turn on - preferably with maximum saturation. I would prefer that it also does not even turn on a little as the voltage approaches 4 volts, but remains closed until that voltage hits 4 volts.
    Now, it would be OK if it had some kind of marginal transition from zero saturation to fully saturated once it hits that 4-volt threshold ... like say for example at 4 volts, it starts to turn on but is not fully saturated until it reaches 3.9 volts or whatever ... a 1-volt margin in that characteristic would be acceptable.
    I hope my question makes sense and that it's clear what I'm looking for. If not, please let me know.
    Thank you,
    See attachment for a simple visual.
    sigpic
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: Need a circuit that switches ON when a 5 volt source drops to 4 volts or less
    you could start with something like this then adapt it .. maybe long way round though . https://www.homemade-circuits.com/lo...uit-using-two/
      You need to study and understand how Transistor work and how to bias it. You will blow-up that E-B junction, if you understand Transistor then you would not have the BASE CONNECTED DIRECTLY TO 5V source like that. How did you come up with the connection like that?
      https://www.badcaps.net/forum/attach...5&d=1578528302
      You SHOULD to this thread: https://www.badcaps.net/forum/showthread.php?t=81784
      You lack basic understanding of electronics.
      Do the experiment by hooking up the high current 5V power supply directly to the E-B junction of that NPN Transistor and see what will happen.
        • 31094
        go back to your original thread,
        and learn about schmitt-triggers and the difference between transistors and mosfets.
        • brethin
          • Dec 2008
          • 1907
          Transistor Theory 101 from like the 1960?
            • 31094
            well the simple fact that transistors are current-driven and fet's are voltage driven is enough here.
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              Why don't you describe what you're trying to *do* instead of a particular circuit topology (that may or may not work, towards that goal)
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                I came here looking for help. I admitted my lack of knowledge while stating what I am trying to accomplish ... and you post a comment about 1960 transistor theory? Are you insulting me? Because I can't see any other purpose in your response other than sarcasm.
                sigpic
                  If you study the theory then you would not have made this kind of connections.
                  Heck, I study from books older than 1960 and I never stop learning.
                  How can you gain knowledge if you think it is insulting?
                  It is obvious that you did not do any studying.
                  • redwire
                    • 3910
                    Connecting a transistor as you have drawn will make smoke
                    People want help - but "give me the answer" instead of "I'm trying to learn more about electronics".
                    The difference is a person will learn the basics about a transistor, it only has 3 leads.
                    We can't do much if you withhold a part number or details etc. even after people ask for more info.
                      Originally posted by redwire
                      connecting a transistor as you have drawn will make smoke
                      People want help - but "give me the answer" instead of "i'm trying to learn more about electronics".
                      We can't do much if you withhold a part number or details etc. Even after people ask for more info.
                      +100
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        i like playing with this ...http://www.falstad.com/circuit/e-npn.html
                        • R_J
                          • 9559
                          What about using a STM1061 series (STM1061N38) to drive one transistor (which would turn OFF when under 3.8 volts) and it could turn ON the output transistor.
                          There are theres like the ON NCP304A
                          • barry wilkins
                            • Aug 2009
                            • 172
                            A LM311 with a resistor circuit will make a level sensor like a sync seperator .
                            Used one in my diode radiation detector I made last year.
                            Barry Wilkins
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              In the very early 1990's, I took two years of electronics, including electrical calculus. I even passed my CET ... but when you don't use the knowledge it tends to vacate the belfry... I understand transistor theory just fine, I simply didn't know how to design a circuit that is off at 5 volts, then turns on as the voltage gets lower ... I played with some circuit sims with pnp transistors and didn't get anywhere... I googled around for a while but didn't come up with anything ... so as per usual, I came in here as my last resort ... and it seems that some people would just rather make useless comments instead of answering a simple question, or even pointing me in the right direction... it's all too often like pulling teeth in forums...
                              sigpic
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                HEY - That's pretty nifty! Thank you.
                                sigpic
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  The cirucuit I drew was a pseudo-circuit to illustrate the general effect of what I was looking for ... it never was a literal circuit.
                                  sigpic
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    Try changing the voltage bounds of the base voltage and see why people are complaining that your circuit tends to generate magic smoke...
                                    I tried setting base voltage to 2VDC to see what the simulator does. When I do this, it starts printing weird things...
                                    Base current: 6149GA
                                    Collector current: 614897GA
                                    Emitter current: 621046GA
                                    What the... oh yeah SI units... G as in...giga...gigaamps.
                                    Okay, so 614 teraamps starts flowing through the collector. Ahhhhh.....
                                      1) So far you did not provide the spec of the IR receiver.
                                      2) The screen shot of wave form of the IR output.
                                      3) The real circuit that you actually made.
                                      4) Did you actually run the simulation of the circuit you made?
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        If you are working with voltage detections above 2.5V and need a quick and easy way to accomplish this use:
                                        431 current shunt
                                        (i.e. TL431, KA431, AS431... and etc.)
                                        It's the easiest (IMO) 3-terminal "voltage detection" device to use for that function. If you have Anode connected to ground (how these 431 shunts are often used in PSUs) and the voltage on the reference pin goes above 2.5V, then the Cathode pin will short to ground. You can use the Cathode pin to drive a transistor circuit or whatever it is you are trying to drive (just mind the limitations on maximum current you can drive through the 431 shunt.)
                                        Now, to detect a voltage that is different (and above) 2.5V, use a simple resistor divider between your threshold voltage and the reference pin.
                                        • Mcfeetroy
                                          Fishing bite alarm drains battery
                                          by Mcfeetroy
                                          Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                                          08-01-2025, 03:52 AM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                          12 volt switching power supply modification to 14.5 volts before blocking diode add
                                          by sam_sam_sam
                                          I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
                                          I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
                                          One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
                                          04-11-2021, 11:01 AM
                                        • qayyum786
                                          DELL 3521 LA-9104P getting 5 volts on VIN SECTION instead 19 volt
                                          by qayyum786
                                          Dell 3521 la-9104p getting 5 volts on vin section instead of 19 volt
                                          dell 3521 La-9104p getting 5 volts on VIN SECTION on the ACP ACN
                                          But when i remove IO getting 19 volt on VIN ( ACP ACN )
                                          what is the problem
                                          Without IO 19 volt is ok
                                          WITH IO getting 5 volt on VIN
                                          05-18-2020, 09:03 PM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
