Need a circuit that switches ON when a 5 volt source drops to 4 volts or less
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Re: Need a circuit that switches ON when a 5 volt source drops to 4 volts or less
    Use MC and relay with NC and NO contacts. The MC keeps the relay open, until the voltage threshold is reached. Not very elegant but you can set any threshold voltage and it will work. You need NEGATIVE logic.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Not exactly sure the TL431 can be perfectly used by itself, think that an op amp using the TL431 is still needed. TL431s don't drop their voltage to anode voltage, they work like zener diodes where the voltage will reach a plateau and stay there. This works fine for series connected LEDs which will only turn on when its voltage and the TL431 voltage is met - and the total drop will be the sum of the two.
      sounds like what's wanted is the voltage drop to be 0 or close to it when voltage reaches 4V, which would require another amplification device. A TL431 plus a transistor or op amp will do.
      Actually the 2.5V of the TL431 + 0.7V of a transistor = 3.2 V which may very well be close enough to do without any programming resistors. Current limit is still needed else 614 teraamps will flow...
        • 31218
        6 months from now when you actually make something, you will probably find that the sensor output is digital like i'v been saying!!
          • 31218
          that will make a great buzzer/RF jammer when amplifying a digital stream from a remote control - read the thread fully
          • televizora
            ghettomodmaster
            • Nov 2016
            • 957
            You can always use MC directly if you work with low power signals. Yes, I haven't read the whole topic. The relay was only if you need high current switching capabilities, for example use MC indirectly to switch a high power circuit, for which you cannot use the micro controller directly.
            There is a difference between using a low power signal to switch a high power circuit and to amplify a low power signal. If you have 5V source that can drop to 4 or less volts for example 2.5V, then you have a point that has 2.5V voltage difference from both GND and 5V. It's interesting if you can use it as a reference point, measure and use this difference to switch the circuit.
            If we had the schematic, I think that we can do much better.
              • 31218
              he has an IR reciever and thinks he can boost the range by boosting it's output - it's that simple.
              • televizora
                ghettomodmaster
                • Nov 2016
                • 957
                #27
                I think that in this case the output of the receiver should be digital and I dont think that it would be easy to boost the range this way
                  So far OP refuses to provide the spec of the IR receiver, the actual schematic, the scope screenshot of the IR receiver output, etc.
                  See original thread here: https://www.badcaps.net/forum/showthread.php?t=81784
                  • Mcfeetroy
                    Fishing bite alarm drains battery
                    by Mcfeetroy
                    Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                    08-01-2025, 03:52 AM
                  • MisterAIL
                    PS5 digital / No Power / No Beep / Good power supply
                    by MisterAIL
                    Brought a non functionnal PS5. Apparently only a bad PSU...
                    No beep, nothing.
                    After some tests i found this :
                    - PSU is fine (12 volts stable)
                    - 12 volts line is shorted
                    - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                    - By the way, nothing change. No signal, no power, no beep.
                    Mesuring all rails with my workbench psu (12 volts input)
                    - 0.00 amp drawing
                    - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                    03-12-2024, 03:24 PM
                    12 volt switching power supply modification to 14.5 volts before blocking diode add
                    I saw this switching power supply on eBay and wanted to see if could be modified to run 14.5 volts before the blocking diode was add and this switching power supply seems to have no issues doing this
                    I did recap the switching power supply except the the main filtering capacitors and I managed to break the selector switch for the voltage setting but just jumped it
                    One note I used 25 volt capacitors on the output side of this power supply because they used 16 volt capacitors and because I am running the voltage up a little bit higher 12 volts to 14.5 volts there would...
                    04-11-2021, 11:01 AM
                  • Mark R
                    The Overseas Only Kenwood Model KR 790
                    by Mark R
                    I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                    The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                    09-23-2025, 08:27 PM
                  • qayyum786
                    DELL 3521 LA-9104P getting 5 volts on VIN SECTION instead 19 volt
                    by qayyum786
                    Dell 3521 la-9104p getting 5 volts on vin section instead of 19 volt
                    dell 3521 La-9104p getting 5 volts on VIN SECTION on the ACP ACN
                    But when i remove IO getting 19 volt on VIN ( ACP ACN )
                    what is the problem
                    Without IO 19 volt is ok
                    WITH IO getting 5 volt on VIN
                    05-18-2020, 09:03 PM
