What is the official name for this connector so that I can buy the male end. I know I've seen similar ones on thinkpad LCDs.
Lets play name this connector...
Re: Lets play name this connector...
You lost me. :LMy Computer.
AMD APU A4-3300 2.5ghz 1mb cache
Motherboard GigaByte GA-A75M-S2V
Kingston HyperX Blue DDR3 8GB (2x4GB)
SB Audigy 2 ZS [B800] Sound Card
500GB WD Caviar® Blue™
1 Terabyte WD Caviar® Black™
2 Terabyte WD Caviar® Black™ -
oh oh i know Domo kun.My Computer.
2 Terabyte WD Caviar® Black™Comment
What type/make board is that on?
Dimensions? Width Height ?
Contact pitch (center to center)?
Brand/manufacturer marks or numbers anywhere?
What does it mate to?
Can you show the matching connector?
Toastveritas odium paritComment
http://www.jst-mfg.com/product/detail_e.php?series=147
they're the only mfg i found that makes right-angle connectors of that type.
don't know if the pitch is right."Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. MenckenComment
well at least we have a connector type. search around some. you moght find it elsewhere.sigpic
(Insert witty quote here)Comment
These connectors are so small that they typically may only have a graphic symbol on it that's all. I'd say Kikkoman has found it for you.
Here is from Digikey catalog:
http://search.digikey.com/scripts/Dk...MCS-G-TF(N)-NDComment
They only have the 60 position in the JMC series. (non-stocked)
Do a DigiKey search on: JMDSS
Then check mark the "In Stock" box and select 20 in the "Number of Positions" below that.
Perusing those results yields this as a possible candidate:
http://search.digikey.com/scripts/Dk...=455-1894-1-ND
Review the JMD datasheet info to verify the size.
https://cdn.badcaps-static.com/pdfs/...f4dedcf781.pdf
Minimum quantity is 10 @ $1.31100 or $13.11
by TomyleeHi everyone,
Sorry for the person who’s going to read all this !
I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the... -
by 5mall5nail5Hi All -
I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching... -
by bussincapsHello All,
tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),... -
by michhakHi guys,
i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
- Loading...
