2sb649a
  • ChaosFlower
    • Jun 2019
    • 10
    • England
    2sb649a
    This transistor is no longer available and most all on the net (ebay etc) are fakes. I think NTE 374 is the closest equivalent. Can someone experienced please confirm this is a good choice?
  • petehall347
    • Jan 2015
    • 4448
    Re: 2sb649a
    180V, 1,5A, 140MHz
    whats its job ?
    p.s i wouldn't use nte unless desperate
    • petehall347
      • Jan 2015
      • 4448
      Re: 2sb649a
      2SB649: KSA1220A or KSB546Y or TTA004B.
      • R_J
        • Jun 2012
        • 9623
        Re: 2sb649a
        • redwire
          • Dec 2010
          • 3912
          Re: 2sb649a
          I second Toshiba 2SA1220 (Fairchild KSA1220) with a mid-range hFE. 2SA1209 is the NTE374 original.
          2SA1381 is the higher voltage 300V AF driver but less current and power 7W.
          • petehall347
            • Jan 2015
            • 4448
            Re: 2sb649a
            it all depends on the circuit really .
            • ChaosFlower
              • Jun 2019
              • 10
              • England
              Re: 2sb649a
              Well.. that's the problem.. I don't have the experience to know which parameters don't matter and which do. Some of the parameters of the KSA1220A are spot on, others vary.
              The service manual is on this very site..
              Transistor Q712
              https://www.badcaps.net/forum/attach...2&d=1407703892
              https://www.badcaps.net/forum/showth...light=NAD+C370
              • petehall347
                • Jan 2015
                • 4448
                Re: 2sb649a
                regulator for -68v . is it shorted ?
                • petehall347
                  • Jan 2015
                  • 4448
                  Re: 2sb649a
                  check out tip32a . haven't time to look right now
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8707
                    Re: 2sb649a
                    Yeah looks like regulator, circuit seems to imply that you only need to match physical constraints, voltage differential constraints, and current flow capacity; most transistors should work fine. I'd agree a very inexpensive tip32 series would be an "overkill" if it will fit there (TO-220 is bigger than TO-126) but probably would be more comfortable with a TIP32C with its 100V rating to get a bit more voltage margin.
                    Also keep in mind that the pinout is "backwards" so if you need to attach to a heatsink, TIP32C won't work unless you face it in the "wrong" direction. I personally would try to jury rig it to fit at least, not sure about others
                    • ChaosFlower
                      • Jun 2019
                      • 10
                      • England
                      Re: 2sb649a
                      yeah! that's the one! your eyes are good..
                      • ChaosFlower
                        • Jun 2019
                        • 10
                        • England
                        Re: 2sb649a
                        Thank you to you both.
                        I have looked at datasheets for NTE374 and 2SB649A. Unless I am missing something they look identical. The only downside is it means an extra 15 quid delivery with farnell because it is special order (from US).
                        I guess I would rather replace like with like. But I am interested in knowing what parameters I can ignore.
                        Why does everyone seemingly hate NTE?
                        • petehall347
                          • Jan 2015
                          • 4448
                          Re: 2sb649a
                          order from RS next day free delivery
                          • petehall347
                            • Jan 2015
                            • 4448
                            Re: 2sb649a
                            NTE are rebadged transistors .
                              Re: 2sb649a
                              Did you verify that Q713 and Fusible resistor R723 are still OK?
                              So is the 2SB349A shorted out or what?
                              • petehall347
                                • Jan 2015
                                • 4448
                                Re: 2sb649a
                                q713 d707 should be checked as well
                                • ChaosFlower
                                  • Jun 2019
                                  • 10
                                  • England
                                  Re: 2sb649a
                                  I am going to go through this thread again. Look at all things recommended. All trannys recommended. And test. I'll be back.
                                  Suffice to say yes, so far Q713 is shorted. R717 is cooked.
                                  • petehall347
                                    • Jan 2015
                                    • 4448
                                    Re: 2sb649a
                                    keep looking and testing . looks like there will be more faults .
