Looking for SMPS flyback tranformer TAM TO-5622 or equivalent?
  • peter_wheat
    • Aug 2025
    Hi All,
    I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing some of the primary winding, so don't have a proper turns count for it. Any help gratefully received.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5040
    • New Zealand
    You might get lucky and they will tell you something, but who knows.
    I did get some useful information from an inductor manufacturer (Litai if I remember right)
    About a coil that was in an LCD monitor (one was broken, needed another)
    They gave me enough information I was able to find a replacement that worked
    But for transformers they are usually custom for each design
    Rewinding it would be the only real way to go, but if you lost count of the turns then... not much you can do except buy another one probably.
    -David VanHorn
    • tony359
      Faulty CRT AKF12/Philips CM8500: bad flyback?
      by tony359
      I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
      What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
      There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
      Can it be a short somewhere...
      08-22-2023, 04:39 PM
    • dkneyle
      Onkyo DX-V500 Laser Disc Player - weird SMPS fault
      by dkneyle
      This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
      Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
      02-01-2022, 02:08 AM
    • shamsudeen
      Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
      by shamsudeen
      Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
      I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
      i know that in linear power supply the noise will be very low comparing to SMPS supply....
      07-19-2025, 07:14 AM
    • abhishekkumar1902
      Huntkey HK340-72FP SMPS shut on load above 2 amps
      by abhishekkumar1902
      I have this Huntkey HK340-72FP PC SMPS where I am facing a strange problem where the SMPS shuts down when the load on any of its 12v output rails goes above 2 amps while the rating of each 12v rail is above 10amps capable.
      I have checked the following:
      1. All output caps are OK, and all output rails read correct voltages at no load
      2. All output diodes are OK
      3. NTC is ok
      4. Hi voltage cap on input correctly reads 150uF on LCR meter per the spec, also the bridge rectifier is OK
      5. No short in main switching MOSFET
      6. All other components...
      12-18-2022, 09:52 AM
    • madan1
      Mackie Th15 SMPS low Vout
      by madan1
      I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
      It is basically a smps with amp and some dsp.
      The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
      Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
      By the way, the ferrite core of L10 is broken,...
      02-16-2025, 04:15 PM
