lighting circuit modification
+ More Options
Posts
  • maxslo
    • Nov 2013
    • 64
    • Slovenia
    Hello, it's been a long time since my last post and i'm here again seeking advice from more experienced guys
    I have a night light that had it's incandescent 10W bulb die recently, and i've bought a 2.3W LED to replace it, but i've immediately noticed that when it should turn on, instead it's flickering. There was only ~130ish Volt AC across the leads for the bulb so i've thought that this must be some sort of dimming mechanism for the incandescent bulb. I've since taken it apart and drawn a schematics to the best of my ability.
    No here is the question. What would be the easiest thing to change in the circuit, to maintain the night/light sensing and be able to run the LED off it properly?
    Here's the schematic:
    Thanks in advance for any input
    • 30979
    Re: lighting circuit modification
    you need a resistor in parallel with the led lamp.
    i dont know what value, but that circuit uses the lamp as a source of power to the light sensor.
    led lights are not resistive, they are inductive.
    • maxslo
      • Nov 2013
      • 64
      • Slovenia
      Ok thanks, i can measure the resistance across LED's circuit, would that help in determining the required resistance?
      • redwire
        • 3906
        MCR100 is an SCR, so when it is turned on it outputs only 1/2 wave pulsing DC to the light bulb.
        Your LED lamp probably does not like this and may not work if it uses a capacitive dropper- then it really wants AC, not pulsing DC coming in.
        If you post a pic of the LED lamp's circuit, you can figure it out if it will work.
        • maxslo
          • Nov 2013
          • 64
          • Slovenia
          Ok i'll check if i can take it apart without breaking it.
          Just a thought would it be possibile to change the MCR100 out for another element (if it exists), that would output entire sine wave to the lamp.
          Edit: I have been able to remove the plastic cover over the LED's, but the circuitry is inside the bulb's base and is not accessible unless i destroy the base :/
          • redwire
            • 3906
            I did find the same night light circuit but using a CR02AM-8A triac which should give full-wave to the lamp. It is hard to find very sensitive gate (100uA) thyristors.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8696
              Duplicate the circuit in reverse ...
              • maxslo
                • Nov 2013
                • 64
                • Slovenia
                Thanks, this might be just what i was looking for, i'm just a bit confused about the information i read from the spec sheeet.
                namely this:
                why does it say half sine wave?
                • redwire
                  • 3906
                  The I2t (amp squared seconds) value is based on the time for a fuse blowing 10-16msec, or 1/2 cycle.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    i might add a capacitor if led flickers too much
                    • maxslo
                      • Nov 2013
                      • 64
                      • Slovenia
                      Ok thanks, i've ordered the relay. I'll update the thread once i install it
                        Relay? The schematic on your post 1 using the SCR which means the 10W lamp is only be using 5W of power due to half wave action of the SCR, so when you use your meter the Voltage you test is the pulsing DC so it will not show 230VAC.
                          Half wave recitification.
                          https://www.physics-and-radio-electr...rectifier.html
                          • maybe
                            • Apr 2017
                            • China
                            Your project remind me a electronic project I have tried before about Electric Car Lamp, it's here: https://3celectrons.com/2019/07/25/d...-power-supply/
                            • redwire
                              • 3906
                              This is a night light- how does it remind you of a bicycle light? Nothing in common unless you are trying to sell something.
                              • maxslo
                                • Nov 2013
                                • 64
                                • Slovenia
                                Sorry my bad, I meant the triac.. I've just seen that it was rejected to ship out of china due to security issue??? never had that happen before, so i've just ordered one from UK to avoid extra 1-2 months of wait time
                                I'll post back with results when i receive and intall it.
                                • maxslo
                                  • Nov 2013
                                  • 64
                                  • Slovenia
                                  The triac arrived an i've installed it. The light now doesn't flicker anymore, however the light also doesn't turn off when it's daytime xD.. i'll give it another go tomorrow
                                  • JimBanville
                                    Replacing incandescent bulb on Pioneer LD player with led. Need help :)
                                    by JimBanville
                                    I have a pioneer dvl-909 LD/dvd player from 1998. It has a light on the front panel that lights up when you play a dvd. I removed the bulb and it appears to be a tiny incandescent bulb. Its measures "open"/dead and the bulb is black like it's blown. The socket it fits into measures 5v. I've looked up the schematics and there's no indication of the amperage. I don't want to spend any money on new parts, but I have a pack of like 100, 3v, 20ma LEDs and I have various resistors.
                                    Is there a way for me to determine the amperage going to the old dead bulb with my multimeter?
                                    01-24-2023, 07:49 AM
                                  • repair-it
                                    TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                    by repair-it
                                    I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                    Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                    10-11-2023, 07:18 PM
                                  • Astonished
                                    Fixing the Charge Circuit of the Batteries of the DC Motor
                                    by Astonished
                                    Hi friends of electronics
                                    What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                    The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                    Please help me fix this circuit.
                                    (the datasheet of the IC: https://pdf.datasheet.live/28...
                                    01-28-2025, 06:24 AM
                                    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                    by sam_sam_sam
                                    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                    12-14-2023, 07:45 PM
                                  • rddube
                                    Lenovo L490 Ram voltage circuit malfunction
                                    by rddube
                                    Hello friends,
                                    Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                    I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                    07-15-2025, 04:41 PM
