How hard can I drive an IR Blaster?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    So I have one of these from a 2012 Samsung 3D TV ...
    And what I wanna find out SAFELY ... is how hard can I drive this thing? I have a use for it in mind and if I could get it to invisibly light up my living room it could be useful to me .... muwhahahahahahaaaaa
    sigpic
    • 30952
    Re: How hard can I drive an IR Blaster?
    forget it, those are just regular leds.
    if your after secret lighting for camera's you need the IR version of the leds used in flashlights.
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      No I'm just wanting long reach for electronic equipment for IR repeating... Sorry if I was misleading in my initial post.
      sigpic
        • 30952
        well most of the problem is going to be losses from filters & stuff like that, is this related to 3d glasses??
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8682
          Most of the time the manufacturers are already driving it as hard as they can barring two thing: battery life (if applicable) and the LED must last longer than any possible warranty claim. So usually if you want to sacrifice one or the other, it usually is going as bright as it can without replacing the LED.
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            No, it's an arduino project that relays IR codes to different equipment (TV, cable box, Roku etc.)
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              I took it apart, and discovered it has 5 LEDs in it... they are a little bit larger than a standard LED, and they are translucent with a blue-ish tint to them. They are attached to a small circuit board which connects them in parallel ... which means if one of them can handle say ... 200ma, then 5 of them in parallel can handle a full amp, right?
              sigpic
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                Only if they are perfectly matched.
                The better way to drive multiple LEDs (for greater luminous intensity) is to drive them in series. In that way, the output from each may vary (based on their individual characteristics) but you're sure that each will see the same "drive".
                [The BEST way, of course, is to drive them individually to optimize output per device -- but, that's needlessly expensive]
                Unfortunately, this means you need more voltage compliance in your (current-mode) driver. E.g., for 5 in a string, you're in the 15V range (losses in the driver).
                So, you'd need 15V at 200mA (in your hypothetical example) instead of 3V @ 1A.
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  I'm driving this project with 19V because it also uses a stepper motor for volume knob control and i didn't have a 12v supply laying around ... but i've got several 19v laptop power supples in the drawer ... ive got it breadboarded and fully functional ... im driving the 5 parallel leds with 5v ... the Arduino Nano hits a NPN transistor base through a low value resistor, then the emitter straight to ground, and the collector feeds the cathode and the annode is connected straight to the output from a 7805 which is driven from the 19v supply ... no pullup reisistor at all. Its been running for a couple weeks and so far so good.
                  sigpic
                    So you have all 5 LED connected in parallel with 5V power supply with one switched Transistor on the low side without out any current limiting resistors at all?
                    What is the current draw for EACH LED when you check?
                    • redwire
                      • 3900
                      You always use resistors to limit LED current
                      The current-limiting is likely from the NPN switching transistor or 7805 or both having a large voltage drop. TX is only for a short burst.
                      So the LED's are getting unknown power. If they are 5mm LED's you can't push 200mA through them.
                      It would be better with the IR LED's in series (5*1.5V) to 7.5V and a resistor, or constant-current NPN switching transistor (add resistor), to the 19V rail.
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        I guess that would require that I actually check ... I would have to desolder to check just one ... would you settle for total current draw from all 5 and we can just divide the result?
                        sigpic
                        • EasyGoing1
                          Shock Therapist
                          • Sep 2016
                          • 977
                          Once I discovered that these LEDs are slightly larger than "normal" leds and that they clear with a blue tint, I googled around and saw that they were basically standard high output IR LEDs, which are typically rated at 1.2 volts at 100 ma. With a 5v supply and a sum total of 500ma, it would call for a pull up resistor of about 7 or 8 ohms ... I figured with the transistor offering SOME resistance and the fact that they will be switched on and off so quickly ... I didn't need to mess with the resistor.
                          So if I sourced the IR LEDs from 19 volts through a switching transistor, Id need about 35 ohms or whatever I have thats close to that value ... I could actually eliminate that 7805 if I did that because the only thing that regulator does is power those LEDs.... hmmmm... thats a good idea I havent ordered the PCB yet so I still have time to change the design.
                          sigpic
                            When putting LED in parallel and they do not have matching VF, so they will not conduct with same amount of current, the one with the lower VF will conduct the most, the one with higher VF may conduct little or not conduct at all, and when the one with lower Vf is conducting as it is heated up it will lower the Vf so it will conduct even more and get into thermal runaway, that is why you do not simply put semiconductor in parallel unless you match them and also the thermal management has to be done correctly.
                            Current limiting resistor for each LED for parallel connection, that is why you are better off connecting LED's in series and drive them with PWM constant current.
                            https://www.arrow.com/en/research-an...ds-in-parallel
                            https://www.edn.com/design/led/44245...el-LED-strings
                            Using 7805 to drop 19V to 5V at 500mA, that means the 7805 will be dissipating 19V - 5V = 14V of Vdrops on the 7805. 14V x 0.5A = 7W of power dissipation on the 7805.
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              These 5 LEDs in parallel are a commercial product, manufactured by Samsung. There are no resistors, just a circuit board with five of these LEDs connected in parallel. When I send an IR signal into the LEDs with a 5 volt source with the configuration previously stated, and I look at the LEDs using a cell phone camera, all 5 light up fairly brightly...
                              sigpic
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                Interesting. I picked a few cameras from the tip that have IR rings. Do they run in the same bands? Can i make an IR blaster from them for.. Say... A TV be gone?
                                Follow the white rabbit.
                                  How about showing us good clear pictures of the whole top and bottom side of this Samsung board?
                                  • federalhouse
                                    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                    by federalhouse
                                    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                    **Background:**
                                    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                    **What I've Tried So Far:**
                                    1. I accessed
                                    08-01-2024, 07:03 PM
                                  • tmcw
                                    PC case - Hard drive rails
                                    by tmcw
                                    A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                                    So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                                    I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                                    Now, the case is a CiT Gaming Case, and...
                                    05-22-2022, 12:04 PM
                                  • madura2010
                                    DAY11AM6E0 hard disk drive and optical disk drive not detected
                                    by madura2010
                                    Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                    i checked the connectivity of ribbon=good communication with hard and motherboard
                                    changed hard disk and checked=3f0 error persist
                                    sata power=+5v available
                                    Then checked data capacitors=all good
                                    Then checked data lines path connectivity to pch=all good
                                    reflashed...
                                    03-12-2023, 09:09 AM
                                  • ash91
                                    Hp pavilion 15 not detect hard drive
                                    by ash91
                                    Hello gentelmen .... this is my first post and sorry for my bad english,
                                    so my proplem is my laptop keep losing hard drive even if i but the
                                    hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                    when i turn the laptop on the massage that said no boot media found pop on
                                    the hard disk is fine and to be sure i try another hard
                                    i also update my bios to the last update
                                    the 5 volt is present on the hard connector on the motherboard
                                    the dvd rom work fine when i but a windows dvd in it
                                    also when i boot from flash...
                                    06-07-2023, 01:45 PM
                                  • ChaosLegionnaire
                                    bug of the month: write caching setting for the hard drive in device manager
                                    by ChaosLegionnaire
                                    i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                                    so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                                    10-06-2019, 01:39 PM
