Help identify component
  • madan1
    • Nov 2016
    • 682
    • Bulgaria
    Can anyone identify the yellow component S1. It has two legs, one of which is connected to the component's body and has no writings on it.
    When the board is shaken, something in the component rattles.
    The board is RTI t2-c smart remote control ( I could not find a service manual ).
    The component is in what seems to be the "power supply" part of the board.
    Re: Help identify component
    Tilt ball switch.
    https://www.adafruit.com/product/173...BoC4UAQAvD_BwE
    • madan1
      • Nov 2016
      • 682
      • Bulgaria
      Helpful as always! Thanks budm!
      "The "poor man's" accelerometer!" in a $800 smart remote control... fu%k logic.
      • Retro-Hipster
        Tinkerer
        • Apr 2019
        • 125
        I think the logic is pretty sound on their part...
        cheaper parts = moar profit. lol Joking aside, if we are just talking something to register simple movement so that the remote lights up/turns on, then that is probably a pretty smart choice on their part..
        “Men always seem to think about their
        past before they die, as though they were
        frantically searching for proof that they
        truly lived.”
        – Jet (Cowboy Bebop) -
        • madan1
          • Nov 2016
          • 682
          • Bulgaria
          Here is another one - the thingy in the red circle.
          It measures ~7700 ohms resistance.
          It is on the main battery voltage rail and when shunted, the device starts fine.
          Don't mind the lousy solder job above the thingy.. it was just for testing purposes and already has been fixed.
          p.s. the thingy was measured out of the circuit.
          • R_J
            • 9535
            It is likely a fuse, any letters on the ends (ie: bel) or maybe a number under it. digikey etc. carry them
            • madan1
              • Nov 2016
              • 682
              • Bulgaria
              Originally posted by R_J
              It looks like it could be a fuse
              That was my first thought... but don't the fuses fail by breaking the internal connection?
              This one still has some resistance.. that's why I'm confused.
              For now I have installed a 0 ohm smd resistor and the device works works fine ( kinda... looks like it needs a professional calibration or/and new sensors ). I do not see any excessive current drain or hot components.
              edit: no markings at all - not on the component, not on the board.
              • R_J
                • 9535
                It depends on what the fuse element is made from, since there is no short on the board, it might just be fuse fatigue, the fuse element over time got weak and finally opened, but there is still a small amount of resistance 7.7k
                  • 30979
                  not a fuse, not one i'v ever seen.
                  it may be a ptc or polyfuse of some type.
                  • madan1
                    • Nov 2016
                    • 682
                    • Bulgaria
                    Can anyone tell me something about the Q1 component?
                    It looks like a transistor, but what the bleep is that black part on its top?
                    P.S. I do not need any part number or something.. just some basic info about the part
                      Q1? Where?
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        Originally posted by budm
                        Q1? Where?
                        next to q3
                        • madan1
                          • Nov 2016
                          • 682
                          • Bulgaria
                          Q1? Where?
                          Good question... really forgot to check the images I uploaded
                          Here is the same image but brightened and with circled Q1 ( my office monitor has crappy brightness, thus I'm not sure how "visible" are the images ).
                            • 30979
                            looks like a pyroelectric sensor.
                            same thing you find in a PIR switch.
                            the real question is what the hell is it doing in a button assembly?
                            • madan1
                              • Nov 2016
                              • 682
                              • Bulgaria
                              I believe you are totally correct!
                              If I remember correctly, the board came out from a scrapped bluetooth speaker ( "sharkk true wireless speaker" ) and I have absolutely no idea what a PIR sensor has to do with such an item... I guess it's time for a tin-foil hat...
                                • 30979
                                not a wireless one, you need the type with an earth wire!
                                • redwire
                                  • 3906
                                  It's a PIR motion sensor, IC is BISS0001. Shark: "Thermal heat sensor automatically activates frosted LED backlighting for the buttons on the speaker"
                                    • 30979
                                    LOL
                                    thermoelectric sensor and i.c. probably consume more mA than the leds!
                                    • thesame
                                      DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                                      by thesame
                                      Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                                      The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                                      02-27-2024, 04:31 AM
                                    • silver60618
                                      Lenovo Legion 7 - Help Identify IC
                                      by silver60618
                                      Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                                      I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                                      Any help would be appreciated...
                                      07-02-2025, 12:16 PM
                                    • chth96
                                      How can I identify varistor which have been blew up?
                                      by chth96
                                      I mistakely pluged 100v japanese retro game console to 220v outlet.
                                      So It seems that glass fuse and varistor have been blew up.
                                      I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                      Is there any way to identify varistor type in my sega saturn PSU?
                                      Any reply would be appreciated.
                                      EDIT:
                                      It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                      11-26-2023, 08:52 AM
                                    • freakorio
                                      Need Help To Identify Component on Ymain LJ41-05120A
                                      by freakorio
                                      Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                                      05-21-2024, 02:32 AM
                                    • baiceanu_stefan
                                      nm-f251 Schematic, boardview or help identify componente
                                      by baiceanu_stefan
                                      Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                                      04-24-2024, 12:49 AM
