Car LED Headlights dimmer?
  • capwizard
    • Jun 2016
    • 1991
    Re: Car LED Headlights dimmer?
    My wife laughed and said... people in Africa have more money than us and their diamonds are big than mine.
    Nano has PWM output but can it do TPMS check out? My other idea was when the car closed to mine, like high low beam automatic switch to half brightness.
      Can you just switch in and out the Rsensing resistors so you can do HI-LO?
      • capwizard
        • Jun 2016
        • 1991
        That was a brilliant idea...This (Rcs) can omit the cumbersome current limit resistor. all you need are switching with SMD resistors. It costs $0.
          Higher Rs = Lower LED current.
          • capwizard
            • Jun 2016
            • 1991
            Red wire said...R2 R3 R4 (25ohm) are current limiters.
              I cannot tell from the pictures to see how those resistors (they are supposed to be 0.25 Ohm) are connected an what pin of the IC they are connected to, you should verify first.
              The IC is QX9920 for sure? Can you see the power MOSFET? see the spec. sheet of the IC on how they are all connected together.
              • capwizard
                • Jun 2016
                • 1991
                This one shows R220 is 0.22ohm. They are parallel for higher wattage.
                The different car has different inside circuits construction. I have two sets.
                  There has to be power MOSFET some where.
                  • capwizard
                    • Jun 2016
                    • 1991
                    U2 I can't see the no. But it is mosfet. (N5280?)
                    U1 is OC5011
                      It may be similar to something like this: https://cdn.badcaps-static.com/pdfs/...0f19c2bfce.pdf
                      IC OC5011:
                      • capwizard
                        • Jun 2016
                        • 1991
                        OC5011 already has PWM input brightness control which sti highly recommended, We can use CMOS 555 as a simple PWM Generator to efficiently control brightness of the headlight.
                        H8 H9 H11 Led Car Headlight Conversion Kit, Maso Auto RGB Headlight Bulbs 6000K-10000K 80W 8000LM Adjustable Brightness High/Low Beam Super White COB Chips with APP Control IOS Android Pack of 2 pcs
                        by MASO Price: $59.99
                        Adjusted Brightness and Mutil-Colors:
                        With multi colors (at least 8 colors) combined in freestyle into 16 million colors. Musical activated control / Echo Control by bluetooth APP. Music sync with your phone music but you must follow the setting from instruction.Then flashing, fade, smooth, bright-adjusted functions and so on. Attention: If the App control does not work you can exchange from us anytime.
                        Smartphone Control:
                        Control the Color Combinations and Music Modes all on the Free Bluetooth App. It is same APP as MIHAZ underdash light. Easy Installation. But please open your bluetooth of your cell phone when you found it can not work.
                        I can't believe this................... RGB Bluetooth LED Headlight
                        if you need PWM here
                        Signal Generator PWM Pulse Frequency Duty Cycle Adjustable Module LCD Display 1Hz-150Khz 3.3V-30V PWM Board Module US $1.63 pic 4
                          According to the spec of QX9920, you can apply PWM to EN pin also.
                          • capwizard
                            • Jun 2016
                            • 1991
                            thank you, I have seen QX9920 data but did not notice this.
                            luminescence and brightness are the same?
                            ps: in United States not allow to have lights outside or underneath the car and change the color of the headlights.
                            Can I have underbody neon lights if they are shatterproof?
                            To date none of the manufacturers of neon lamps have certified the color and intensity of their product. If they were to become certified then the color would be limited by the location but white, amber or yellow, and red is the only allowable colors to be displayed while operated on the road in accordance with DMV Regulation 14-137-101.
                            Can I have in addition to my headlights, neon bars that don't go on with the headlights, but are hooked up separately?
                            None of the manufacturers of neon lamps have certified the color and intensity of their product. The addition of not more than two auxiliary driving lamps, passing lamps, or fog lamps producing white or amber light is allowed provided that they are mounted at a height in accordance with Connecticut State Law Title 14 Sec. 14-96o. In addition, in accordance with Connecticut State Law Title 14 Sec. 14-96y there may be no more than four lamps exceeding 300 candlepower illuminated at the front at any one time. This means that if the headlamp system has two lamps on each side illuminated at any time then the auxiliary lamps must extinguish automatically. Furthermore, any auxiliary lamps of over 300 candlepower must only illuminate with the tail lamps and may not be independent for use on the road. Any additional lamps of less than 300 candlepower must produce amber or yellow or white light.
                            • capwizard
                              • Jun 2016
                              • 1991
                              I have a question!
                              QX9920 EN pin and OC5011 pwm pin. I know they are digital pwm , but can we use analog signal input? For example, some IC have both functions. i gonna try it.
                                https://www.embedded.com/electronics...dth-Modulation
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  Thank you.
                                  I'm gonna use TL494 to built a PWM and inject a signal into OC5011. see what will happen?
                                  This PWM has two channels, Working frequency and period can be adjusted.
                                  The hard part is LED headlight PCB is too small to work on.
                                  Pic4. I adjusted the P2 duty cycle.
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    #57
                                    The statutes referenced apply to vehicles in CT. You would have to examine each state's statutes to determine the legality of underbody lights, there.
                                    E.g., one of my neighbors has underbody lights on at least one of his vehicles.
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      My friend has a very loud car audio system, I installed for him, the entire car would shake, was issued a ticket by the cop.
                                      I wanted to import underbody lights to sell,10 years ago, but state laws legally not allow them. Maybe LED signs, lighting advertising billboards for business are good.
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        PWM (Pulse Width Modulation) "chops" a DC into many "pulsed packets" or "sections". Comparable with a turn signal circuit on the car, the consumer (eg a light bulb) does not get a "full" current, but just "packages". Now, the PWM is not specifically for flashing, but for "power control". Therefore, the "flashing frequency", so the output frequency of the packet sequence is usually so high that it would not be visible, you would connect a lamp. For example, 300 hertz for solenoid valves or motors or even 20 kilohertz and more for other applications.
                                        Pulse width modulation with TL494
                                        The TL494 is a very convenient pulse width modulation IC and has been on the market for a long time. That's why he is relatively cheap. (Reichelt 43 cents). An IC with many features, and there's no reason for hobbyists to use any of the other, newer types that may be hard to come by or cost 10 to 20 times.
                                        A few features of the TL494:
                                        2 separate NPN outputs, load different according to manufacturer (Texas 200 mA, Motorola 500 mA per output)
                                        internal 5 V reference voltage source, load capacity up to 10 mA
                                        6 to 40 Volt operating voltage (depending on the product also 7 - 42 Volt)
                                        adjustable frequency over a wide range
                                        simple control of the clock ratio
                                        Adjustable in the break times, the cycle times and the frequency. Far more comfortable than any of the NE555 IC.
                                        TL494 Pulse Width Modulation Control Circuit
                                        https://www.youtube.com/watch?v=bErcY_iDxlQ
                                        • marce002
                                          Replacement for LED DIMMER chip
                                          by marce002
                                          Hello I have a led lamp with 3 TP8005S chips. one is shorted but cant find a replace part around.
                                          .. is it easy to replace with another option? it is just on /off led lamp for scooter... low beam and high beam are working just fine...
                                          11-16-2024, 04:17 PM
                                        • CG2
                                          LED uplighter dimmer burnt resistor
                                          by CG2
                                          I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                                          02-14-2024, 09:23 AM
                                        • Hairspring
                                          Screen dimmer in recent months, weird symptom: EPG screen goes bright! LG 19LD350
                                          by Hairspring
                                          In recent months the screen has been getting more and more dim. If that was all, I'd suppose the problem would be the backlight (LED? LCD?). But I've noticed this really weird symptom: switching to the EPG screen restores normal brightness! And then, even weirder, when I go back to the programme, for a moment the programme is at normal brightness and over the next 1-2 seconds it gradually dims down again.
                                          Last time I looked in a TV it had EHT flyback, so I'm no expert. I do sometimes repair computer monitors and power supplies, most often when there's bad caps.
                                          Anyhow,...
                                          12-04-2022, 11:18 AM
                                        • MrCreosote
                                          2 Belkin KVM switches have dim VGA output
                                          by MrCreosote
                                          When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
                                          4-port Omniview Pro2 f1dz104t
                                          8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
                                          The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
                                          AD ADAPTER:
                                          There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
                                          08-15-2023, 08:26 PM
                                        • Storyteller12
                                          Sony XBR-65X850E No Power
                                          by Storyteller12
                                          Tv won't turn on. Not sure if there is a standby light on this TV but I'm not seeing any.
                                          Checked the usual diodes that go bad and all test good. When plugged in 2 show 100v and the other 2 50v when plugged in.
                                          Below is reading for CN6401
                                          1) 0v - blinking
                                          2) 0v - pwm1 dimmer
                                          3) 0v - DC dimmer
                                          4) 0v - 0wm2 dimmer
                                          5) 3.5v - Standby
                                          6) 0v - pwm3 dimmer
                                          7) 0v - BL On
                                          8) 2.6v BL Error
                                          9) 3.5v PWR On
                                          10-12,19-24) 0v - ground
                                          13-18) 12v all pins - 12v reg
                                          07-26-2023, 12:15 PM
