What makes high speed hdmi cables different in construction?
  • caphair
    • Nov 2011
    • 1249
    Everywhere I look for this answer I just keep running into the same thing about whether you can use standard hdmi cables with 4K TVs or not.
    What I know:
    Standard hdmi cables support up to 1080i and could probably handle more
    High speed hdmi cables support up to 1080p
    But how do they differ to have different standards? Are the pinouts different or is it merely the construction internally? ie thicker cables to support more bandwidth?
    • 31137
    Re: What makes high speed hdmi cables different in construction?
    i think they have more parallel channels in use - not actually faster.
    http://pinouts.ru/Video/hdmi_pinout.shtml
    look at references to "type-b" ?
      https://www.cnet.com/news/4k-hdmi-cables-are-nonsense/
      • caphair
        • Nov 2011
        • 1249
        Read same article but it doesn't say what makes the high speed cables different than the standard ones that might have issues with 4K content. Curious about the construction internally
          • 31137
          look at the link, do the 4k ones have the same number of pins?
            https://www.hdmi.org/learningcenter/faq.aspx#48
            • caphair
              • Nov 2011
              • 1249
              In that link is type B the “high speed” cables used for 4K or another type? If so it looks to have more pins than the standard cable. Guess that would be the difference?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                It's the same as a CAT5 vs CAT5e vs CAT6 vs CAT6A ethernet cables.
                They are tested at higher frequencies, and to achieve those they are built better with each revision.
                • caphair
                  • Nov 2011
                  • 1249
                  But how are they built better? Thicker wires than previous models or?
                    • 31137
                    you dont need thickness, it's not current-drive.
                    shielding from external noise and crosstalk is the main difference-maker.
                    just like 13W3 is better than most modern "digital" crap.
                    • japlytic
                      Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                      by japlytic
                      With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                      An examination of the HDMI CEC wiring...
                      07-10-2022, 09:48 PM
                    • japlytic
                      Certain "Class 2" HDMI cables can be marginal at 4K 60 Hz
                      by japlytic
                      For some time, a "Class 2" HDMI cable (part number BN39-01583B) supplied with a Samsung 4K 60 Hz display sometimes causes the display to overlay a few horizontal lines of flickering pixels of random colours and sometimes drops out, particularly on content requring HDCP.
                      Since changing the cable to a thicker Class 2 unit, this problem has not occured again - do you know of other marginal "Class 2" HDMI cables supplied with displays?
                      09-06-2023, 08:50 PM
                    • aliougm
                      Marantz SR4003 AVR HDMI board issue, seeking for help
                      by aliougm
                      I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                      Connection as below:
                      Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                      If I bypassed AVR then HDTV screen color be good.
                      I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                      3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                      I replaced all...
                      04-30-2022, 12:21 PM
                    • RossMoodley1967
                      LG LCD TV HDMI PORT FAULTY
                      by RossMoodley1967
                      LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
                      02-28-2024, 08:38 AM
                    • budwich
                      ESD Diode on HDMI output of Yamaha a1050 RCVR
                      by budwich
                      I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
                      I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
                      09-11-2023, 12:21 PM
