Fixing a multimeter based on VC9805 schematic
  • poker
    • Dec 2021
    • 28
    • Türkiye
    #41
    Re: Fixing a multimeter based on VC9805 schematic
    Thank you for your reply. The m6 smd I marked in the photo and diagram was a short circuit. I don't have an m6 transistor right now. What should I do to operate the multimeter?
    • redwire
      • 3912
      Ok, that transistor matches the schematic for Tp2, controlling battery power to the multimeter, for the auto-power off.
      If it was shorted, the multimeter would stay powered on, it would not auto-shut off. The on/off switch would still work.
      It would be rare for that transistor to fail short-circuit. It seems strange. Unless there is another shorted part on the board, like a C2 or an IC.
      You can just short C-E with a jumper and the multimeter would power up and work, just no auto-shutoff feature.
        • 31182
        auto-off is a pain in the ass anyway.
        • poker
          • Dec 2021
          • 28
          • Türkiye
          #44
          Yes, it doesn't turn off automatically. you guys are great. thank you. good people like you will save the world... so why can't I measure voltage and current? only ohm and diode (buzzer) are working. I couldn't find any other short circuit, contactor wires are in place. Could you please give an idea for this as well?
          • poker
            • Dec 2021
            • 28
            • Türkiye
            #45
            Now the multimeter is working but it doesn't measure voltage and current. Do you have any idea about it?
            • poker
              • Dec 2021
              • 28
              • Türkiye
              #46
              vc9805 multimetre arızası
              hello, I have the same vc9805 multimeter, whose photos and schematic I have attached below. After replacing the battery only ohm and diode (buzzer) measurements work, other measurements do not work voltage, current ... none. Only the number 1 remains on the screen. When I measured the components, I couldn't find any problem parts. If anyone has any idea, what should I do?
                • 31182
                Re: vc9805 multimetre arızası
                check all the transistors for shorts - some are used for input protection.
                • poker
                  • Dec 2021
                  • 28
                  • Türkiye
                  #48
                  I checked all of them, unfortunately I can't find it, I don't understand where am I doing wrong?
                    • 31182
                    did you move any of the contacts in the rotary switch?
                    • redwire
                      • 3912
                      Post #28 I said to use a multimeter and measure some voltages "On DCV 20V range, measure the A/D voltages: IN HI, IN LO, REF HI+, REF LO-, COM wrt V-"
                      That is 5 readings to take.
                      • poker
                        • Dec 2021
                        • 28
                        • Türkiye
                        #51
                        I will measure and reply immediately. Sorry, I missed your message.
                        • poker
                          • Dec 2021
                          • 28
                          • Türkiye
                          #52
                          sir,
                          buzzer = 2.90 v
                          temperature = 38.1 millivolts
                          in low- in hi= 0.00
                          vref+-vref- =1
                          v- v+ = battery voltage 9.0
                          v- and com varies 179 mv, 190, 110
                          • redwire
                            • 3912
                            Display shows 1___ with those readings?
                            Pin 40 COM voltage is too low, it needs to be at least 1V above V-. On the schematic it would be QC4,QC3 to check- that would short COM below 1V. On your board check whichever two are the same transistors as those. 9Q1 maybe?
                            There should be two protection transistors between COM and V-. If your meter does not have them, the IC can get damaged on pin 40.
                            • poker
                              • Dec 2021
                              • 28
                              • Türkiye
                              #54
                              sir, If the multimeter will measure the battery at 20 volts dc, which ways do the contactor wires touch in this diagram?
                              • poker
                                • Dec 2021
                                • 28
                                • Türkiye
                                #55
                                I solve the problem. I change the u2 integrated diagnostic tl062 in the diagram and the multimetrem started working as it old. If anyone experiences the same problem with me, remember this and benefit from this information. Thank you so much to the good people who answered my questions here...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  So does the transistor test and temperature ranges are working?
                                  Originally posted by poker
                                  vref+-vref- =1
                                  So you mean both these two pins are 1V WRT GND or is the difference between the two 1V? If it's the former, we need to look at how these voltages are being generated. If it's the latter, throw away the meter and buy another one...
                                  Ah okay looks like you fixed it, excellent. If it's easier just to replace parts until it works, it's still much faster than doing systemic debug... hence replacing whole meters is sometimes easier.
                                  • poker
                                    • Dec 2021
                                    • 28
                                    • Türkiye
                                    #57
                                    I couldn't find a fault anywhere, then I wanted to replace this part and yes it works as before now, temperature, voltage, all... thank you very much for your help...
                                    • poker
                                      • Dec 2021
                                      • 28
                                      • Türkiye
                                      #58
                                      Originally posted by madan1
                                      Hi there, recently I got a not that cheap chinese multimeter based on VC9805 schematic.
                                      Unfortunately it doesn't measure correctly.
                                      Here is an example:
                                      Range | ~33mv | ~100mv | ~503mv | ~2V | ~3V | ~10V
                                      200mv | 33------ | 101-------| - ---------| -------| ----- | -
                                      2v------| 0.030---| 0.98------ | 504----- | 1.94 | - ---- | -
                                      20v----| 0.01-----| 0.08 ----- | 0.48----- | 1.7-- | 3 ---| 10
                                      200v---| 0 --------| 0 -------- | 0.03 ----- | 0 --- | 2.8 | 9.8
                                      1000v-| 0---------| 0 -------- | 0 --------| 0---- | 1 --- | 8
                                      range ohms
                                      200---- | ---------| --------| ------- | ---------| 1.2
                                      2k------ | --------| --------| ------- | 0.981 | 0
                                      20k---- | 4.89---| --------| 2.15 | 0.96----| 0
                                      200k-- | 4.7-----| 29.5--| 1.9-- | 0.8------| 0
                                      2m---- | 003--- | 0.027 | 0------| 0-------- | 0
                                      20m-- | 0------ | 0.01-- | 0------| 0-------- | 0
                                      Both V and Ohm measures go through RS2 RS3 RS4 and RS5. All that resistors measure as shown on the schematic - 1k, 9k, 90k and 900k. RS6-9 are 1.75m, 2.95m, 1.75m and 2.95m or total of 9m ( while it should be 10m, but even with added 1M resistor, the measure pattern still stays the same ).
                                      I also have measured the resistance of the paths for all V ranges between Rin and the corresponding resistor ( for instance range 20V - Rin <-> RS5xRS4 ) and all paths have almost the same resistance ( +/- 0.2 ohm ). These are the paths which go through the range selector knob. Also, the multimeter is almost brand new and no damage is visible on the contacting surfaces.
                                      Rin is 1M
                                      Any ideas what else to check?
                                      p.s.
                                      range | 1uf | 22uf | 10- | 1 ----| 0.47 | 10
                                      200u--| 1.1 | 23.4 | 10.9| 1.1 --| 0.5 -| 0
                                      20u---| 0.94| 19.3 | 8.52| 0.93--| 0.44 | 0.01
                                      2u----| 0.95| ---- | ----| 0.945 | 0.448| 0.009
                                      200nf-| ----| ---- | --- | ----- | -----| 9.1
                                      20n---| ----| ---- | --- | ----- | -----| 9.15
                                      The current measurements seem fine ( of course need calibration ).
                                      Dude, I have the same multimeter. I confused the wires around the position selector switch. Can you send me your photo?
                                      • poker
                                        • Dec 2021
                                        • 28
                                        • Türkiye
                                        #59
                                        Sorry guys, I didn't have the time to work on this. Probably tomorrow will be able thoroughly check your replies and do some more tests.
                                        Meanwhile here are some photos to get an idea about the particular DMM.
                                        p.s. 6R3 = Rin
                                        • max_smart
                                          T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                                          by max_smart
                                          First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                                          Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                                          06-01-2024, 03:27 PM
                                        • PanicMechanic
                                          Extech EX330 multimeter current range offset fault
                                          by PanicMechanic
                                          My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
                                          The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
                                          As you can see from the pics, the offser is the same (just multiplied for other rages):
                                          -4.9 uA
                                          -0.49 mA
                                          -0.49 A
                                          I don't know what exactlly caused the fault.
                                          The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
                                          05-11-2021, 11:13 PM
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                        • yayayee
                                          ASUS GU502GV not powering on - 1285A hot
                                          by yayayee
                                          I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
                                          So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
                                          I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
                                          01-08-2024, 11:04 PM
                                        • Geeker007
                                          Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
                                          by Geeker007
                                          I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
                                          To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
                                          However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
                                          I am using below components:
                                          • Buck Converter: TPS562201 (12V → 5V regulated)
                                          • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
                                          • LED Strip: WS2815 (12V digital LED strip)
                                          • Switching
                                          06-29-2025, 05:20 PM
