Fixing a multimeter based on VC9805 schematic
    • 31294
    Re: Fixing a multimeter
    how much is this worth??
    just asking because 6000, and 10,000 count meters are very cheap now.
    advancements in parts means they can make a good meter with only 2 chips and no calibration pots.
    • madan1
      • Nov 2016
      • 726
      I bought this in the local "Chinese market" for the equivalent of 20 USD. The same DMM in amazon is 60 USD ( https://www.amazon.com/AMZVASO-Multi.../dp/B07F5FC27N ).
      by the way... can anyone explain why a lithium 2032 battery would measure ~3V on that DMM and ~1.5 on another one? At least 5 other ( non-rechargeable ) batteries show exactly the same value on both DMMs
        • 31294
        no idea, but some meters have a battery-check mode where it puts a load across the battery.
        • madan1
          • Nov 2016
          • 726
          After the calibration I was able to get close enough readings b/n the ranges:
          ref.---200mv---2v---20v---200v---1000v
          33mv---36.4---.032---0.02----0---0
          130mv---142---.130---0.12---0---0
          .500---1---.501---.49---0.4---0
          1.005---1---1.010---.0.99---0.9---0
          1.505---1---1.515---1.50---1.4---1
          3.00---1---1---3.00---2.9---2
          3.71---1---1---3.71-3.6---3 <-- battery
          4.04---1---1---4.04-3.9---3 <--- battery
          5.00---1---1---5.00---4.9---4
          10.00---1---1---10.03---9.9---9
          15.00---1---1---15.05---15.0---14
          bench psu; ref is measured on another DMM
          What I've done is to remove/bypass 6R5.
          Do you think there is any point in changing all components in the BUF-A/Z-INT circuit to the recommended values?
          Also, will it be possible to increase the 200uF range to a higher value?
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8711
            not sure it really looks any better, again the values don't matter but the quality do.
            • poker
              • Dec 2021
              • 28
              • Türkiye
              #26
              hello, I have the same multimeter and the multimeter failed. only ohm and diode mode (Buzzer) measures, other voltage and current does not measure only 1 number on the screen can you help? what could be the problem?
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8711
                probably prescaler has a broken resistor?
                • redwire
                  • Dec 2010
                  • 3912
                  Re: Fixing a multimeter based on VC9805 schematic
                  First check the input-protection transistors for shorts. VC9805A+ there are 5 SOT-23 NPN types mainly, and a 2 for freq. counter and one for something else.
                  Never power a multimeter from a bench power supply, always use the battery. This is because the input COM(-) is NOT power GND and shorting those can cause damage.
                  On DCV 20V range, measure the A/D voltages: IN HI, IN LO, REF HI+, REF LO-, COM wrt V-.
                  I literally drove myself nuts fixing a similar multimeter that read -ve ohms. Leads shorted, reads -100 ohms. 1k resistor reads 900R.
                  It was not the protection transistors, PTC, A/D etc. - the crapola beeper comparator op-amp had a leaky input and was loading down the A/D input. That multimeter was 1" away from the garbage, I was so pissed before I found it.
                  • poker
                    • Dec 2021
                    • 28
                    • Türkiye
                    #29
                    thank you for your answers. I will check your suggestions and reply.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8711
                      Note that when measuring IN HI/IN LO pins, you need to use a meter with 1GΩ input impedance, else you will get significant error in the reading. If you only have a 10MΩ input impedance DMM it's still worth to report what you get, but it will contain significant measurement error.
                      Granted if it really is saying just "1" overload, it may not matter, though it would matter if the meter stopped displaying "1" when you connected the test equipment.
                      BTW does it report 0 when you short the probes together, even? How about with IN HI/IN LO shorted?
                      • poker
                        • Dec 2021
                        • 28
                        • Türkiye
                        #31
                        When I short-circuit the probes in the voltage section, -1 only becomes 1, only '' -'' disappears, only 1 remains.
                        • poker
                          • Dec 2021
                          • 28
                          • Türkiye
                          #32
                          Hello again, I detected a short circuit in the m6 (s9015) transistor in the multimeter. I can't find the same transistor, which transistor can I use instead? can't find the same transistor, which transistor can I use instead?
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8711
                            Not exact but a 2n3906 would probably will make a workable replacement...
                            • poker
                              • Dec 2021
                              • 28
                              • Türkiye
                              #34
                              sir, I think this transistor is responsible for short circuit protection at the input. Can I bypass this transistor, which is specified as m6 in the diagram of the friend who opened the topic, what do you think until I find the transistor?
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8711
                                M6 is a power switch transistor. I'd imagine it is used to shut off the meter if the battery is bad. If it's shorted and the battery is weak, then perhaps this is why you're getting strange readings.
                                • poker
                                  • Dec 2021
                                  • 28
                                  • Türkiye
                                  #36
                                  yes, the problem is that the m6 is short circuited, but now I don't have the m6 transistor. How can I bypass this transistor in the circuit? until i find the transistor?
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8711
                                    what I'm saying is even if it's shorted, it has no affect on the readings you're getting - unless if your battery is dead, so you do not have root cause and there's no need for bypassing.
                                    • poker
                                      • Dec 2021
                                      • 28
                                      • Türkiye
                                      #38
                                      you are right then we have another problem that i need to find ?
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8711
                                        Just to be thorough, you should measure the voltage at emitter and collector, if they're about the same or within a half a volt or so and both near the voltage of your battery, then it's not the rootcause of problems...
                                        Again as redwire suggests in post 28, check the protection devices Tt TF1 TF2 QC1 QC2 QC3 QC4 DI1 DI2 and then the input to the op amp pin 3. Also again as said, the voltages at the AME7106 pins would help pinpoint what's causing the problem.
                                        • redwire
                                          • Dec 2010
                                          • 3912
                                          Which transistor is shorted? poker, do not confuse the power-on transistors with the protection transistors.
                                          On OP schematic for VC9805+ Tp1, Tp2 are for battery power switch. SMT marking L6 (is KSC1623L6/C1623) NPN and M6 PNP is part number S9015.
                                          QC1/QC2, QC3/QC4, TR, Tt - are the protection transistors.
                                          The multimeter should work with no protection transistor, if that's what shorted and you have removed it. But you need a new one there.
                                          • max_smart
                                            T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                                            by max_smart
                                            First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                                            Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                                            06-01-2024, 03:27 PM
                                          • PanicMechanic
                                            Extech EX330 multimeter current range offset fault
                                            by PanicMechanic
                                            My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
                                            The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
                                            As you can see from the pics, the offser is the same (just multiplied for other rages):
                                            -4.9 uA
                                            -0.49 mA
                                            -0.49 A
                                            I don't know what exactlly caused the fault.
                                            The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked...
                                            05-11-2021, 11:13 PM
                                          • dj8452000
                                            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                            by dj8452000
                                            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                            02-18-2025, 08:28 AM
                                          • yayayee
                                            ASUS GU502GV not powering on - 1285A hot
                                            by yayayee
                                            I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
                                            So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
                                            I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...
                                            01-08-2024, 11:04 PM
                                          • Geeker007
                                            Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
                                            by Geeker007
                                            I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
                                            To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
                                            However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
                                            I am using below components:
                                            • Buck Converter: TPS562201 (12V → 5V regulated)
                                            • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
                                            • LED Strip: WS2815 (12V digital LED strip)
                                            • Switching
                                            06-29-2025, 05:20 PM
