Fixing a multimeter based on VC9805 schematic
Hi there, recently I got a not that cheap chinese multimeter based on VC9805 schematic.
Unfortunately it doesn't measure correctly.
Here is an example:
Range | ~33mv | ~100mv | ~503mv | ~2V | ~3V | ~10V
200mv | 33------ | 101-------| - ---------| -------| ----- | -
2v------| 0.030---| 0.98------ | 504----- | 1.94 | - ---- | -
20v----| 0.01-----| 0.08 ----- | 0.48----- | 1.7-- | 3 ---| 10
200v---| 0 --------| 0 -------- | 0.03 ----- | 0 --- | 2.8 | 9.8
1000v-| 0---------| 0 -------- | 0 --------| 0---- | 1 --- | 8
range ohms
200---- | ---------| --------| ------- | ---------| 1.2
2k------ | --------| --------| ------- | 0.981 | 0
20k---- | 4.89---| --------| 2.15 | 0.96----| 0
200k-- | 4.7-----| 29.5--| 1.9-- | 0.8------| 0
2m---- | 003--- | 0.027 | 0------| 0-------- | 0
20m-- | 0------ | 0.01-- | 0------| 0-------- | 0
Both V and Ohm measures go through RS2 RS3 RS4 and RS5. All that resistors measure as shown on the schematic - 1k, 9k, 90k and 900k. RS6-9 are 1.75m, 2.95m, 1.75m and 2.95m or total of 9m ( while it should be 10m, but even with added 1M resistor, the measure pattern still stays the same ).
I also have measured the resistance of the paths for all V ranges between Rin and the corresponding resistor ( for instance range 20V - Rin <-> RS5xRS4 ) and all paths have almost the same resistance ( +/- 0.2 ohm ). These are the paths which go through the range selector knob. Also, the multimeter is almost brand new and no damage is visible on the contacting surfaces.
Rin is 1M
Any ideas what else to check?
p.s.
range | 1uf | 22uf | 10- | 1 ----| 0.47 | 10
200u--| 1.1 | 23.4 | 10.9| 1.1 --| 0.5 -| 0
20u---| 0.94| 19.3 | 8.52| 0.93--| 0.44 | 0.01
2u----| 0.95| ---- | ----| 0.945 | 0.448| 0.009
200nf-| ----| ---- | --- | ----- | -----| 9.1
20n---| ----| ---- | --- | ----- | -----| 9.15
The current measurements seem fine ( of course need calibration ).Leave a comment:
Re: Fixing a multimeter based on VC9805 schematic
So does the transistor test and temperature ranges are working?
So you mean both these two pins are 1V WRT GND or is the difference between the two 1V? If it's the former, we need to look at how these voltages are being generated. If it's the latter, throw away the meter and buy another one...
Ah okay looks like you fixed it, excellent. If it's easier just to replace parts until it works, it's still much faster than doing systemic debug... hence replacing whole meters is sometimes easier.Leave a comment:
Ah okay looks like you fixed it, excellent. If it's easier just to replace parts until it works, it's still much faster than doing systemic debug... hence replacing whole meters is sometimes easier.Last edited by eccerr0r; 11-11-2022, 12:12 PM.Leave a comment:
I solve the problem. I change the u2 integrated diagnostic tl062 in the diagram and the multimetrem started working as it old. If anyone experiences the same problem with me, remember this and benefit from this information. Thank you so much to the good people who answered my questions here...Leave a comment:
Display shows 1___ with those readings?
Pin 40 COM voltage is too low, it needs to be at least 1V above V-. On the schematic it would be QC4,QC3 to check- that would short COM below 1V. On your board check whichever two are the same transistors as those. 9Q1 maybe?
There should be two protection transistors between COM and V-. If your meter does not have them, the IC can get damaged on pin 40.Leave a comment:
buzzer = 2.90 v
temperature = 38.1 millivolts
in low- in hi= 0.00
vref+-vref- =1
v- v+ = battery voltage 9.0
v- and com varies 179 mv, 190, 110Leave a comment:
I will measure and reply immediately. Sorry, I missed your message.Leave a comment:
Post #28 I said to use a multimeter and measure some voltages "On DCV 20V range, measure the A/D voltages: IN HI, IN LO, REF HI+, REF LO-, COM wrt V-"
That is 5 readings to take.Leave a comment:
did you move any of the contacts in the rotary switch?Leave a comment:
Re: vc9805 multimetre arızası
I checked all of them, unfortunately I can't find it, I don't understand where am I doing wrong?Leave a comment:
check all the transistors for shorts - some are used for input protection.Leave a comment:
hello, I have the same vc9805 multimeter, whose photos and schematic I have attached below. After replacing the battery only ohm and diode (buzzer) measurements work, other measurements do not work voltage, current ... none. Only the number 1 remains on the screen. When I measured the components, I couldn't find any problem parts. If anyone has any idea, what should I do?Last edited by poker; 06-24-2022, 10:24 AM.Leave a comment:
Now the multimeter is working but it doesn't measure voltage and current. Do you have any idea about it?Leave a comment:
Yes, it doesn't turn off automatically. you guys are great. thank you. good people like you will save the world... so why can't I measure voltage and current? only ohm and diode (buzzer) are working. I couldn't find any other short circuit, contactor wires are in place. Could you please give an idea for this as well?Leave a comment:
auto-off is a pain in the ass anyway.Leave a comment:
Ok, that transistor matches the schematic for Tp2, controlling battery power to the multimeter, for the auto-power off.
If it was shorted, the multimeter would stay powered on, it would not auto-shut off. The on/off switch would still work.
It would be rare for that transistor to fail short-circuit. It seems strange. Unless there is another shorted part on the board, like a C2 or an IC.
You can just short C-E with a jumper and the multimeter would power up and work, just no auto-shutoff feature.Leave a comment:
Which transistor is shorted? poker, do not confuse the power-on transistors with the protection transistors.
On OP schematic for VC9805+ Tp1, Tp2 are for battery power switch. SMT marking L6 (is KSC1623L6/C1623) NPN and M6 PNP is part number S9015.
QC1/QC2, QC3/QC4, TR, Tt - are the protection transistors.
The multimeter should work with no protection transistor, if that's what shorted and you have removed it. But you need a new one there.Leave a comment:
by max_smartHi all,
First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...3 Photos -
My multimeter has developed this fault, a few months ago. I tried to fix it, but had no success.
The fault is that on the current ranges it never shows 0. Does not matter if the probes are open or shorted.
As you can see from the pics, the offser is the same (just multiplied for other rages):
-4.9 uA
-0.49 mA
-0.49 A
I don't know what exactlly caused the fault.
The meter had a battery leak before I noticed the fault, but I am not sure if the fault was present before that happened. I just did not noticed. The battery leaked... -
by dj8452000I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
by yayayeeHello,
I have a laptop that isn't turning on. When I disassemble it and plug in the power connector with the pcb by itself, I can see with a thermal camera I bought that TPS51285A is the only thing getting hot.
So of course, the first thing I do is google the laptop model and the IC, and it just happens that I stumble upon a video by Northridgefix attempting to repair the exact same problem, only for it to catch on fire.
I thought that maybe I'd be lucky so I bought a 1285A, that came in as a 1285B. The only difference I can see between them is that the 1285B...2 Photos -
by Geeker007I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
I am using below components:- Buck Converter: TPS562201 (12V → 5V regulated)
- Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
- LED Strip: WS2815 (12V digital LED strip)
- Switching
- Loading...
