Mechanical Relay Quality
  • evilkitty
    • Nov 2017
    • 299
    Re: Mechanical Relay Quality
    I have ~600 state changes in my logs 11/26/21 - 1/31/22
    this include both relays, i have sanity checks to detect bad data to prevent random state changes, eg if the temp sensor goes from reporting say 20c to 80C in 2 seconds i call bs and read the senor again
    edit: just updated the git repo with my current script reversion
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      600 seems quite low before failure. So it did only ~10 states per day, i.e. 5 on and 5 off per day, for 2 months?
      Hmm...
      how are you driving your coil? DC? Full rated current?
        • 31278
        maybe it's time to think about cheap SSR's or triacs, but i dont know if triacs will work at that low voltage.
        • evilkitty
          • Nov 2017
          • 299
          Hmm...
          the contact failed on the coil powered off state 1st, so i am not sure that the could voltage it the issue, but it is running with 5v -transistor vdrop, but you can see how it was done in this image
          "600 seems quite low before failure. So it did only ~10 states per day, i.e. 5 on and 5 off per day, for 2 months?"
          yes, though we need to extrapolate time cause it was close to 4 or 4.5 years IRC, but that would be under 15k changes or 7500 full cycles and that includes cycles for both relays
          also worth noting that this relay did not have the snubber for probably a week while i wanted on parts
          the bottom relay has around 6 years on it, 2 years without a snubber and is still working, but only has 1 side of the relay (coil powered on) that does anything and it gets far less yearly cycles as it does not get used with the AC is active
          • evilkitty
            • Nov 2017
            • 299
            @stj, are double throw SSRs a thing?
              • 31278
              no - atleast i dont think so.
              using 2 and inverting the control signal on the second will work though.
              • evilkitty
                • Nov 2017
                • 299
                i guess i could use a NPN and a PNP transistor and control them both with the same gpio pin each getting there own resistor, guess i should make use new pcb for this design, id need to take some parts off the old pcb, but they are easy ones to remove
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8706
                  Actually using a TIP120?! This might explain the failure.
                  How much drive current can a rpi source/sink? If it can drive more, you're better off not using a Darlington there, at least for 5V. Maybe a 2N4401 would be better.
                  • redwire
                    • 3912
                    The old relay contacts are not pitted from arcing, but the plating has vanished and gone somewhere. There is no black soot so I'm puzzled what is going on. It might be chinesium plating.
                    Songle SRD-05VDC-SL-C coil is 70R or 71mA and they offer three different contact platings and current ratings 7,10,15A 250VAC as well as basic 10,000 cycle lifetime into resistive loads.
                    UL/CSA rate them only 3A 125VAC inductive loads, and there is a secret long life 100,000 cycle model. Thne specs are a bit deceptive and I've seen plenty of Songle knockoffs too.
                    Driving the relay with a TIP120, the base resistor is large 6k8 so the TIP120 sees about 0.2mA drive with hFE 500 so it is on a bit weak.
                    Changing to 2k gives 1mA drive from the RPi. The TIP120 loses at least a volt so the relay at best will see 4V.
                    If you drive the relay "weak" it pulls in slow and wimpy which would wear the N.O. contact only. The N.C. relies on the spring for force.
                    This is why I think the software might extra pulse the relay, or the snubber is simply too small for whatever the load is, or the relay quality is poor.
                      • 31278
                      you dont need a transistor for an ssr, they use an optoisolator and take under 5mA usually.
                      • evilkitty
                        • Nov 2017
                        • 299
                        if it uses a 5v control i do need a transistor, my GPIO pins run at 3.3v
                        • evilkitty
                          • Nov 2017
                          • 299
                          i got 10 of these relays in 2015 for $3.92 on ebay, so about 0.40 each, not sure if that is a realistic price for them
                          I have some 2N2222A NPN and 2N3906 PNP transistors on hand and a wide assortment of 1% 0.25W metal film resistors
                          rpi gpio is specked at 16ma max, however there is also a shared total max as well, i think that is 50ma, not sure if sinking and outputting both count towards this total
                          my LCD panel uses alot of pins, but the total ma should be silly low as i was trying to make the led a bit dim
                          front panel:
                          edit: i checked the voltage across the coil and got 4.14v on the bottom relay and 4.13 on the top relay
                          EDIT: took some pictures of the labels on the outdoor unit: https://imgur.com/a/809clTp they are not in great shape, but here they are
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8706
                            The NO contacts get a weak make but the break works fine due to the spring.
                            The NC contacts get a weak break but the make works fine due to the spring.
                            Well it's something to consider in any case. You could use 2/6 of a 74HCT04 to make a buffer so the RPi output isn't as loaded to drive something you can use as a saturated switch. Or even drive a logic level MOSFET,... Would be nice to direct drive a MOSFET but a 3.3V signal limits the number of MOSFETs available without some sort of buffer.
                            I really think that TIP120 is a bad idea for this situation, if you were using a 12V relay and supply then the TIP120 may do much better.
                            • evilkitty
                              • Nov 2017
                              • 299
                              What about using this relay, it calls for 4.5v and says it will work as low as 3.2v
                              https://www.mouser.com/ProductDetail/817-SY-4.5-K
                              If this issue is the TIP120 would you expect both sides to wear like this? the NC (coil on state) wouldn't that one not look like this assuming the spring was not worn out, this contact does not look good, but it was not dead
                              i do not know for sure how much voltage the contacts are dealing with, i just know it is low amps based on wire gauge
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8706
                                404
                                  • Jul 2011
                                  • 6070
                                  Those relays ( if they are 24 ac ones ) are cheaply made in the first place and if your thermostat cycle to many times will wear them out in 3 to 5 years of use any way unless you get the heavy duty ones ( cost a lot more money ) which are hard to find only some Air Conditioning Supply House carry them and most of them require a journeymen license to buy from in the first place
                                  These relays are mostly used to control fan speed between heating and cooling and sometimes used for heating element relays that are made for switching the heating element on and off if there is more than one heating element bank
                                  • evilkitty
                                    • Nov 2017
                                    • 299
                                      • Jul 2011
                                      • 6070
                                      You can buy 3.3 volt solid state relays that run at this low of voltage you just have to search for them and if I was doing this I would highly recommend going this route
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8706
                                        Well, it seems a full amp can be passed through the circuit, so a 1A relay is pushing it.
                                        Hmm... have to see what my thermostat is using now... I'm surprised it's not using a SSR, it too uses 3V logic (uses two AA batteries and probably residual power from the 24V control line)...
                                        • evilkitty
                                          • Nov 2017
                                          • 299
                                          Using my meter it showed ~32ma at ~27v AC
                                          if i were to use 3 SSRs i would have to redo the pcb layout, but if i can sick with 2 relays it i can just swap them out and garage some wires at the relay for a new pin out/location
                                          maybe i could use this relay: https://www.digikey.com/en/products/...1Z-4-5V/648227
                                          • valvashon
                                            Repair Success! Middle Atlantic UPS2200R-IP
                                            by valvashon
                                            Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                                            Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                                            02-06-2024, 12:54 PM
                                          • CoinCoin88
                                            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                                            by CoinCoin88
                                            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                                            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                                            09-15-2025, 03:36 AM
                                          • DXseekerMO
                                            Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                                            by DXseekerMO
                                            Hello everyone!
                                            Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                                            I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                                            Yes
                                            0%
                                            1
                                            All backlight strips are the same quality
                                            0%
                                            1
                                            No
                                            0%
                                            0
                                            12-16-2021, 03:58 PM
                                          • CuriousJohn
                                            Burco boiler power problem
                                            by CuriousJohn
                                            Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                                            Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                                            This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                                            12-22-2024, 10:25 AM
                                          • SluggerB
                                            Help making a switch work the opposite way with a relay
                                            by SluggerB
                                            I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                            I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                            It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                            02-07-2025, 07:57 PM
