Chinese power supply LM317 overheating.
  • NeedsMoreFlux
    • Oct 2017
    • 121
    • California
    I have a 2 amp Chinese power supply with a LM317 on a heat sink.
    It's only running a 6(of the planned 10) 120mm CPU fans(all between 0.10-0.20-in parallel) on my home made solder filter.
    I don't know if it is over heating due to back EMF. I wrapped the output wire around a torroid a few time-no change.
    I'm thinking about upgrading the LM317 to a better transistor if anyone can recommend a better one(I have tons in my spares box).
    The KBL404 bridge rectifier gets pretty hot too. If anybody can recommend a higher amp alternative for that as well.
    If not; I'll have to hack some other power supply. I've got a few CPU supplies around. But I like the small size of this one, and the selector switch.
    Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
    I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
    Some of the things I've fixed:
    60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Chinese power supply LM317 overheating.
    What specific PSU do you have?
    LM317 is an IC. To upgrade it, you either have to go to a LM338 or LM350 or add a pass transistor. I'm not sure how well LM317s respond to being parallelized. Likely you'll get the same amount of heat, can't get around that.
    Depending on the voltage differential between input and output of the LM317 will determine how how it will get. It seems that you're drawing a significant amount of current. Most LM317 were design limited at 1 to 1.5 amps, which you're fairly close.
    The KBL404 should be enough for whatever you're drawing through the LM317. Unless there's some other problem, upgrade the LM317 first.
      • 31044
      6fans at 200-300ma each = 1.2 - 1.8a
      what's your input voltage and output voltage?
      • NeedsMoreFlux
        • Oct 2017
        • 121
        • California
        I have an MW122A
        https://www.ebay.com/itm/3-12-VDC-2-...IAAOSw3mdZci-Z
        • NeedsMoreFlux
          • Oct 2017
          • 121
          • California
          The voltage coming out of it is 11.98 volts.
          The fans are in parallel. Should I measure the voltage with the fans running, is that what you mean?
          • NeedsMoreFlux
            • Oct 2017
            • 121
            • California
            Awe, so it is a cheap under powered unit. I figured. well, I'll still look at the numbers you recommended, because it is smaller and cleaner looking onmy desk.
            I pulled another CPU PS out of another old comp I was throwing away. So much dust that I had to clean it with water, lol!
            I'll let it dry for a few days in front of the heater. While I figure out the connector I want to use.
            I'll try to get some pictures of my filter up.
              So what is the input Voltage feeding the LM317?
              The Voltage drops between the input and output pins of the LM317 x the load current = Power dissipation for the LM317.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Yes you should measure the input and output voltage of the LM317 with the load connected. The "input" you can measure the voltage across the KBL404 bridge rectifier DC output (two outer pins).
                Note that cheap chinese transformers may also generate a significant amount of heat and was never meant to run 24/7. See how hot the PSU gets when you have no load.
                • NeedsMoreFlux
                  • Oct 2017
                  • 121
                  • California
                  Oh, doy!
                  I thought you mean what voltage the output of 12v dropped to when under load.
                  I'm working on a tv, but I'll get to that a little later today.
                  Thank you for your time guys. It's an interesting puzzle(to me atleast).
                  • NeedsMoreFlux
                    • Oct 2017
                    • 121
                    • California
                    Under no/light load it stays pretty much room temp(I believe). I'll have to check it with my finger again.
                      Oh, doy!
                      No puzzel, basic Power calculation: E x I = Power, so all you have to do is to measure the Voltage between Input pin and Output pin and multiply that by the current draw by the load, no load = no current draw = no heat.
                      • NeedsMoreFlux
                        • Oct 2017
                        • 121
                        • California
                        True. I was more referring to the problem solving on this tv and the problem solving of hacking to fix the over heating on the power supply. as I assume I will have to do alot more than just replace the under rated lm317 and rectifier.
                        Though I hated math in high school, I did enjoy it MUCH more in college and went much further than I thought I could when in college it was of my own free will.
                        And thank you for the calculation formula.
                        (BTW: running on no sleep. I try to flip the negative into a positive.)
                          • 31044
                          the difference between the input voltage and output voltage is converted into heat.
                          pretty crude - but simple.
                          i suspect you really need a buck convertor from ebay.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            The LM350 and LM338 should mostly be drop-in replacements; though you still need to remove that heat away. The main difference with the LM350 (3A) and LM338 (5A) is that they have beefier internal pass transistors than the LM317 (1.5A). Reading the datasheet for the LM317, it looks like at 12V output and you're close to minimum dropout, you can get 2.2A or possibly more safely.
                            Remember you will still produce the same amount of heat - there's no way to get around it without a different circuit topology. However, the IC will last longer.
                            • PeteS in CA
                              • Aug 2005
                              • 3581
                              • USA, Unsure of Planet
                              1. Fans draw current in pulses. The label gives the average current.
                              2. In power electronics heavy metal is usually your friend.
                              3. Maybe next time take a really dusty PSU to a gas station and use their air hose. Wear a dust mask.
                              PeteS in CA
                              • NeedsMoreFlux
                                • Oct 2017
                                • 121
                                • California
                                Right. I assume youre referring to back emf? Oh, I reread it. How much higher could it spike on each pulse?
                                By heavy metal do you mean for the heat sink? it has a pretty decent one.
                                I blew it out with a compressor, but it still had alot caked on from years of neglect-NOT BY ME! lol.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  BTW what do you mean when you say "hot"? Warm is expected, as long as the metal part of the LM317 isn't uncomfortably hot, it shouldn't be a problem.
                                  If it is uncomfortably hot, then that means the thermal interface material is bad or the heatsink is too small. Both these problems apply to the LM350/LM338 even if you replace the IC but not the heatsink solution.
                                  You need a switching power supply if you don't want to deal with the heat.
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3581
                                    NMF, it's been a long time since I last looked at the current waveform for a DC fan, so I'm afraid I can't be helpful.
                                    Yes, I do mean a hefty heatsink is usually a good thing, in proportion to the device(s) mounted on the heatsink.
                                    Maybe the dust from the past drought years got a little moisture from last winter's rains.
                                    IIRC, older ATX PSUs had ~6A 12V outputs. A ~2A load on the 5V output might be enough to have the 12V output close to in regulation. Got any ancient junker ATX PSUs packratted away?
                                    PeteS in CA
                                    • Relayer
                                      • Nov 2017
                                      • 35
                                      • Earth
                                      Hello NeedsMoreFlux,
                                      When the LM317 is fairly hot, how hot is the transformer?
                                      Regards,
                                      Relayer
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        This is what one fan looks like...
                                        Dammit. I need to get screen capture working someday, alas, need to do it over GPIB...
                                        BTW, 1mV=1mA for this fan as the current sense resistor is 1 ohm.
                                        Also I tried a couple of computer fans. They all drop to zero during part of the cycle but never goes below 0. Just this one significantly shoots up. I suspect the circuitry inside the fan is snubbing the kickback that people would expect from motors/inductive devices.
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • rabsonnjala
                                          LENOVO IDEAPAD 100 works only on bench power supply
                                          by rabsonnjala
                                          Hie I have a Lenovo laptop
                                          Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                                          it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                                          below are my readings
                                          with the original charger only
                                          JBATT1
                                          PIN1 0.22V
                                          PIN2 0.22V
                                          PIN3 0.45V
                                          PIN4 0.45V
                                          PIN5 O.43V
                                          PIN6 0V
                                          PIN7 GND
                                          PIN8...
                                          11-20-2021, 08:32 AM
                                          DVR camera recorder switching power supply capacitor failure really
                                          by sam_sam_sam
                                          These cheap non brand capacitors at it again
                                          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                                          Well at least I have the cameras back on line I to try the...
                                          01-22-2022, 06:28 PM
                                          DVR recorder Switching power supply Failure
                                          by sam_sam_sam
                                          When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
                                          Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
                                          This...
                                          05-27-2023, 03:03 AM
                                        • Cookybaby
                                          Samsung UN60ES6500FXZA Power Supply Issue
                                          by Cookybaby
                                          Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                                          I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                                          Make: Samsung
                                          Model: UN60ES6500FXZA
                                          Power Supply P/N: BN44-00525A
                                          Symptoms: The TV was...
                                          08-20-2023, 12:26 PM
