Test old MFM hard drive
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    I have a ancient hard drive out of a just as ancient portable computer that I need to test on the bench because its stopped spinning up in the computer.
    I managed to find a pinout for the 26 pin ribbon connection but I am unsure which connections to make from my bench psu to test if it spins up.
    The power and motor connections on the drive that I can see should allow me to test it are: GND, +12v, +5v, Motor on and drive ready. I am just unsure which to connect to make the motor spin.
    As well as the GND and +12v connections, which on there own do nothing, do I need to also take +5v or +12v to the motor on or drive ready at the same time to make the motor start spinning?
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Test old MFM hard drive
    Well, measure the voltage of the motor on and drive ready pins. If they have 3.3/5v on them then ground them through a 100ohm resistor and see if it works. If they don't have voltage, connect them through a 100 ohm resistor to 3.3v. If no response, 5v.
    Follow the white rabbit.
      • 31033
      nooooo.
      hardrives use multipole motors driven by sequenced pulses!
      that's how the speed is regulated.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        ^ Not all of them. What drive do you have OP?
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          If I remember correctly and I had many MFM and RLL HDDs in the dark ages of computing, these disks should start spinning up immediately when power is applied. It would be exceedingly rare to find a MFM (ST506-interface) HDD that does not spin up right away when power is applied.
          Also note that both +5 and +12 need to be applied. If you apply one but not the other, it may not spin.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            26 pin? wait a minute...
            I thought there were two cables (three including power) for ST506 interfaces.
            The 34-pin very-much-like-but-not-same-as floppy disk cable ("Control") and the 20-pin well shielded data cable ("data") which is serial from the head. MFM disks also predate 3.3V signaling though I don't recall what level the data comes out from the disk...
            And I believe all HDD spindle motors are indeed multi pole motors that require multiphase signals to drive -- all except those really old ones that use AC power to synchronously rotate the platter. The head actuators, those have changed over the years. The oldest ones (and probably most of them in general) use stepper motors for the head.
            It would be curious as to the model of the disk indeed.
              • 31033
              yea, there should be 2 ribbon cables and a standard 4pin power plug.
              • roadrash
                • Oct 2015
                • 490
                • U.K.
                My mistake its a Old conner 3.5" and its not MFM but IDE.
                You are right eccerr0r it should spin as soon as its connected especially these old ones as it takes a while for them to spin up to speed.
                I have a goos idea whats happened no though and I dont think ts worth trying to sort out now. The first time I had this drive spinning I had to help it by moving the spindle with long nose pliers because it was stuck. I had to do this a few times whenever I tried to use the computer. Ive just read that some of these old drives do get stuck when the heads get stuck to the magnetic covering on the disk platters and this is not something t;hat can be rectified so the drive is no use now. I am going to use a Ide CFcard adaptor to emulate a 40mb hard drive instead. Thanks for your help.
                  • 31033
                  before you do, remove the drive pcb and look at the pads that connect to the motor & heads.
                  some are silver plated and get tarnished.
                  if it's not shiny, clean the pads.
                    • 31033
                    btw, cf adapters arent worth the cost now - or the cards arent i should say.
                    look at these instead.
                    http://www.ebay.co.uk/itm/332247062499
                    and
                    http://www.ebay.co.uk/itm/351131265761
                    • goontron
                      5000!
                      • Dec 2011
                      • 4108
                      • US
                      ^ Not to mention if you get the right SD card you can blow those slow CF cards out the water!
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Yeah "sticktion" is a problem in older drives, though I don't recall Conner being one of them (Quantum was notorious). I suppose both of these companies have been absorbed and gone now...
                        Conner CP3000 was a very popular drive IIRC.
                        And I still am very gunshy with SD cards. I have yet to see an SD card that gets my stamp of approval for use as a general purpose OS disk drive replacement (whereas CF and even one Flash USB have). Perhaps with just running MSDOS it might not be such a problem however, but not for Windows, not for Linux, not for any modern multitasking OS.
                        • MeepsterNotchy
                          • Jun 2017
                          All the old Connor's I have spin up and seek test fine, but nothing more after that, not sure what causes it as it's quite annoying because I feel like it's something so simplistic! They sort of die a silent death, you could put it.
                          • goontron
                            5000!
                            • Dec 2011
                            • 4108
                            • US
                            ^ Jumpers?
                            • roadrash
                              • Oct 2015
                              • 490
                              • U.K.
                              Further research revealed the model of Zenith portable computer I have has a unique JVC designed 26 pin MFM/Rll type interface that is made especially for this type of computer and is incompatible with any thing else. Turns out the hard drive is not a conner, as I though it was was its a JVC JD3824R00-1. I replaced all the caps on the computers motherboard but still the drive is dead. Apparently the drive only spins up after the interface has initialised so it wouldn't spin up anyway just putting 12v to it on the bench. I can turn the drive spindle so its not stuck anymore. Here are pictures of the controller and the hard drive pcb side.
                                • 31033
                                does the computer have isa slots?
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  No nothing like that. or i could have use another controller and drive. They have been trying to work this interface out with the intention of making a cf/sd card emulator but nothing yet finished so its get this drive working or its a floppy only computer now
                                    • 31033
                                    so about the connector, is the pinout known?
                                    maybe its a subset of isa on a smaller connector.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      dark ages of computing where custom hardware is customer lock-in
                                      Curiosity, what model computer is this?
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        here are some info on this drive. The computer it comes off is a Zenith Supersport I repaired & re-capped
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • tmcw
                                          PC case - Hard drive rails
                                          by tmcw
                                          A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                                          So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                                          I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                                          Now, the case is a CiT Gaming Case, and...
                                          05-22-2022, 12:04 PM
                                        • madura2010
                                          DAY11AM6E0 hard disk drive and optical disk drive not detected
                                          by madura2010
                                          Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                                          i checked the connectivity of ribbon=good communication with hard and motherboard
                                          changed hard disk and checked=3f0 error persist
                                          sata power=+5v available
                                          Then checked data capacitors=all good
                                          Then checked data lines path connectivity to pch=all good
                                          reflashed...
                                          03-12-2023, 09:09 AM
                                        • ash91
                                          Hp pavilion 15 not detect hard drive
                                          by ash91
                                          Hello gentelmen .... this is my first post and sorry for my bad english,
                                          so my proplem is my laptop keep losing hard drive even if i but the
                                          hard disk in the cady (the box that can replace the dvd rom with hard disk)
                                          when i turn the laptop on the massage that said no boot media found pop on
                                          the hard disk is fine and to be sure i try another hard
                                          i also update my bios to the last update
                                          the 5 volt is present on the hard connector on the motherboard
                                          the dvd rom work fine when i but a windows dvd in it
                                          also when i boot from flash...
                                          06-07-2023, 01:45 PM
                                        • ChaosLegionnaire
                                          bug of the month: write caching setting for the hard drive in device manager
                                          by ChaosLegionnaire
                                          i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                                          so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                                          10-06-2019, 01:39 PM
