Different Kind Of 3 Way Light Bulb Switch
+ More Options
Posts
  • 999999999
    • Sep 2006
    • 774
    Fixing a lamp, I have a strange light bulb socket, at least strange to me.
    It's a 3 way but not to a 3 way bulb. Way one, primary bulb on. Way two, second base bulb lights up but not primary. Way three, all off.
    It needs to fit standard (1/4"?) lamp post pole threading and take an E27 bulb. Am I just not using the right search terms? This is replacing a failed (worn out and severely corroded) socket that does not have more than a two way bulb contacts in the socket.
    • 31063
    Re: Different Kind Of 3 Way Light Bulb Switch
    can you still get multi-way bulbs with the constant push to cfl or led lamps?
    • 999999999
      • Sep 2006
      • 774
      Not relevant. I am asking about 3 way where the 3rd way is a separate bulb ( circuit ) instead of a separate ring on the same bulb socket. Whether it is LED or not is irrelevant, but yeah, it makes sense to make both bulbs LED.
        • 31063
        so actually a cluster of 3 holders?
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Is this what you have??
          • 999999999
            • Sep 2006
            • 774
            ^ Yes. I need it to do that, and have a rotating side stem switch like this:
            https://www.amazon.com/gp/product/B002DN4LX4
            If it comes with the exterior shell like that one at amazon, it'll have the (1/4"?) threaded mount on the bottom that is needed, or I could reuse the old exterior shell if I found the interior switch/socket assembly sold separately.
            Previously I wrote E27 but I meant E26, need E26 socket.
            Did some more searching, found a lamp repair site that stated I have a "3 terminal" socket. Think I found what I need with this:
            https://www.amazon.com/Brass-Light-S.../dp/B0097E3LN8
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Is this what you want??
              • 999999999
                • Sep 2006
                • 774
                ^ No you had it right the first time. I bought the PLT 90-421 that I linked on Amazon. Oddly 1000Bulbs sells it with $2.29 shipping on Amazon but wants $10 shipping if ordered direct from their website.
                https://admin.1000bulbs.com/category...light-sockets/
                Leviton also makes one that looks right as # 07070-0PG
                http://www.acehardware.com/product/i...ductId=1294832
                https://www.amazon.com/Leviton-7070-.../dp/B000BQ88CU
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  OK...when you receive it and connect it up let us know how it works out. Thanks.
                    • 31063
                    what was in the first sketch used to be sold for photography darkrooms.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      3 way switches have so many different connotations.
                      One is the typical light fixture that uses a 3 way bulb with two filaments and the 3 way switch can select either one or both of the filaments. "Rotary Encoder" HAHAHAHAHA
                      It also can refer to a SP3T switch, which is what the OP wants.
                      It also can refer to the XOR house lighting dual SPDT switches that can turn on and off a lamp from two locations...
                      I think the SP3T switch or "SPDT with off position" is non-ambiguous here... though finding them can be tricky.
                        You can get ON-OFF-ON Toggle switch: I.E.
                        https://www.delcity.net/store/Heavy!...88975.h_788978
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          but how about one that...
                            I am not referring to the OP requirement since the one he needs is available.
                            • 999999999
                              • Sep 2006
                              • 774
                              Yeah but this is a fancy antique lamp with its own matching stem handle that screws onto the switch shaft in place of the original plastic one. I thought about converting it to a capacitive touch lamp but decided cheap, quick, and easy would result in me more likely getting it back to the owner soon instead of shelving the project and forgetting about it. Besides it still needs a new socket even if it had capacitive switching. I tore the old one open to see if it was refurbish-able but it was just too worn out.
                              This is how little I know about lamps. The lamp has a standard 1/8 threaded IPS (internal pipe size), 3/8" O.D. pipe, what practically all modern lamps have so I'm good there. Previously I was just guessing 1/4" without giving it much thought because I knew it looked standard.
                              • 999999999
                                • Sep 2006
                                • 774
                                Received socket today and replaced it... took longer to post these pics than to do it, lol.
                                Nothing special involved, screws, middle terminal is socket for each bulb, AC neutral, and the two opposing side terminals, one is AC hot and the other goes to the other bulb socket center conductor.
                                  Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                  by sam_sam_sam
                                  This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                  I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                  I am comparing them to a brand new one that I installed
                                  The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                  I going to let it run for several days before I remount back on the wall next to the...
                                  09-05-2024, 06:48 PM
                                • CapLeaker
                                  Poly VVX-250 VOIP POE problem not booting fix
                                  by CapLeaker
                                  I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
                                  Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
                                  11-25-2023, 10:46 AM
                                • Natob82
                                  Micro Momentary Push Switch?
                                  by Natob82
                                  Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                                  12-21-2022, 05:22 AM
                                • SluggerB
                                  Help making a switch work the opposite way with a relay
                                  by SluggerB
                                  I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                                  I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                                  It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                                  02-07-2025, 07:57 PM
                                • repair-it
                                  TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                  by repair-it
                                  I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                  Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                  10-11-2023, 07:18 PM
