Can anyone help me identify this transformer?
  • WHaThEFLuX
    • Feb 2015
    • 277
    I've scoured the internet with the hopes of finding a replacement for this thing, but the more I search and the less I find has me thinking that it must be a custom piece.
    If someone could shed some light on how I might be able to figure out it's specs(inductance, type of winding, etc.) that'd be a great start. I can't even seem to find one with a similar pin layout. All I know is that the relays on the board it came from are all 18V.
    As always any help would be greatly appreciated, I know someone out there can point me in the right direction!
    "You can only learn so much doing simple recapping and fixes. Ideally you want a really hard one to fix where you end up with a lot of dead ends and frustration. Then, and only then, do you learn how things really work."
    -retiredcaps
    • Jul 2011
    • 6070
    Re: Can anyone help me identify this transformer?
    Does it have a bridge rectifier or does it use two diodes
    And what is the cap voltages near the transformer because I
    Thinking that it might be a 15 volt transformer
    You might be able to use a 12 volts one
      • Jul 2011
      • 6070
      When looked at again I noticed that it has three rows of pins that is a special transformer
      You might have to use two transformers if you have space
      Can you please take a picture of the board this transformer came off of
        Definitely need to see the board and how all the pins are connected.
        What is bad about it? it can be that not ALL the pins are being used.
        The more details the better.
        • WHaThEFLuX
          • Feb 2015
          • 277
          Thanks for your interest guys, the problem is that the transformer shown is fine, but the transformers in two other panels are blown and need to be replaced.
          Here's some shots of the board:
          -retiredcaps
          • dskall
            • Oct 2016
            • 2905
            • usa
            Are they physically burnt up or open. Some transformers have thermal fuses under the wrapping.
            • WHaThEFLuX
              • Feb 2015
              • 277
              Yes sir, definitely no chance of resurrecting them!
              -retiredcaps
                • Jul 2011
                • 6070
                Do you know what the voltage of each winding is you do
                Do you have enough room in cabinet to use two transformers
                If you can give us the voltages on each windings I will try find some transformer or transformers for you
                Could you rewind the ones you have just thought
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  The problem is you can't use a transformer in place of a flux capacitor. Do the math
                  • WHaThEFLuX
                    • Feb 2015
                    • 277
                    Great Scott dskall, you're right!
                    My apologies for not getting back to you guys, I tore my bicep tendon last week so I wasn't able to power up the panel to test, when I do I'll let you know the specs!
                    -retiredcaps
                    • WHaThEFLuX
                      • Feb 2015
                      • 277
                      I've given up on trying to source a transformer for the time being, mainly because I was able to find an identical working one.
                      But of course nothing can truly be that easy........the transformer works in the panel, but the second it's powered on it slowly but steadily gets warmer and warmer until it becomes dangerously hot.
                      I suspect this is the issue that led the original transformer to its toasty demise, but the reason why is eluding me......
                      -retiredcaps
                        • 31277
                        maybe a bad cap on the output
                        • WHaThEFLuX
                          • Feb 2015
                          • 277
                          Interesting, the only cap I can think of is the big one in the picture above, any way to check without a scope or should I just replace?
                          -retiredcaps
                            • 31277
                            i dont see any pics
                            • WHaThEFLuX
                              • Feb 2015
                              • 277
                              They should be back up now...
                              -retiredcaps
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                pictures are showing up and always have been for me.
                                • WHaThEFLuX
                                  • Feb 2015
                                  • 277
                                  Thanks for the clarification vince, any idea why a functioning transformer would be gradually getting hotter?
                                  -retiredcaps
                                    • 31277
                                    no pics - i suspect they arent on this site.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      There on photobucket i think
                                        • 31277
                                        like i said - there are no pictures here!
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • juntmeako
                                          identify torroidal transformer amperage
                                          by juntmeako
                                          hello, i recycled a torroidal transformer from a speaker, i want to know how much amps of this transformer, olease help me identify, i will be using this to build my bench psu...
                                          05-12-2022, 06:12 AM
                                        • robyb
                                          help identify Imac transformer
                                          by robyb
                                          i managed to break off a transformer from my Imac a1418 logic board when i was mounting it back.
                                          it's this one and i cannot identify it so i can order a new one.
                                          Also it would help if someone can tell me if it could be the reason why my Imac will not start.
                                          The green led is "on " on the motherboard , but when i hit " power on" nothing happens.
                                          i will attach the schematics here.
                                          11-16-2022, 04:17 AM
                                        • ohren
                                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                          by ohren
                                          Hello!
                                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                          Measured voltages with no load:
                                          After rectifier diodes
                                          12V: 6.17 V
                                          5V: 5.67 V
                                          Secondary transformer pins AC measurement (really don't know if this says anything)
                                          12V: 2-2.5 V
                                          5V: 1.04 V
                                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                          03-18-2023, 10:33 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
