Why?
  • capwizard
    • Jun 2016
    • 1991
    Why?
    This Hitachi LB55061 I changed LED, when I took pictures show the dark bars but not in my vision? Is something does with LED PWM blinking frequency? How can I calculate it out (camera at 1080p)?
    Last pic: Took with no backlight. I dont thing so, because is in the pic..
    Is something do with this?
    Re: Why?
    Its your camera shutter speed and PWM.
    http://www.tftcentral.co.uk/articles...modulation.htm
    http://laptopmedia.com/highlights/wh...o-our-reviews/
    • capwizard
      • Jun 2016
      • 1991
      Re: Why?
      "We can infer that the phosphor involved in producing blue can switch both on and off faster than the other colours. the backlight will continue to emit light for a few milliseconds after the backlight power is switched off at the end of a duty cycle, "
      I saw this phenomenon, I don't think anybody can answer my question, No one will pay attention to it. budm, Thank you. Your correct answer is really surprised me!.............
      PS: For 20 minutes I can't find my (T-mobile LG stylo 2 plus) shutter speed, so I use Meter test the frequency of the PWM to LED, found is 20 kHz. 20.000/5 bars = 4000
      "Multiply this count by the inverse of the shutter speed. For example, if using a shutter speed of 1/25 of a second and 7 cycles are counted, then the number of cycles per second is 25 * 7 = 175Hz. This is the backlight cycle frequency."
      4000 * 5= 20000 =20 kHz ...........So, 1/4000s that is the shutter speed of my phone. ........
      • madan1
        • Nov 2016
        • 726
        • Bulgaria
        Re: Why?
        check the metadata of the original photos.. there will find the shutter speed
        • capwizard
          • Jun 2016
          • 1991
          Re: Why?
          But ...but ...Before you say "Common on, get outta here!"...I have A question?... Why is horizontal bars instead of vertical?
          • madan1
            • Nov 2016
            • 726
            • Bulgaria
            Re: Why?
            try tilting the camera.. if the lines stay horizontal, then its because the camera sensor is scanned line by line.
            Check here similar effect https://www.youtube.com/watch?v=R-IVw8OKjvQ ( just to note that it's not like the russians have implemented some extraterrestrial technology in their choppers )
            • capwizard
              • Jun 2016
              • 1991
              Re: Why?
              AH-64 Apache or Mi-24 is better? Why I ask this? I tell you a big military secret, Apache is build over here, Mesa, Arizona.
              • Dadiuskilius
                Dead inside
                • Jun 2017
                Smd led
                Will you please share type/ratings of LED you had success with on the LB55061 strip?
                  • 31278
                  Re: Why?
                  mi24 was better - now discontinued though.
                  bigger, faster, stronger armor, larger payload.
                  replaced by 3 seperate models,
                  when you need something big & heavy that can take fire: MI-35
                  http://www.russianhelicopters.aero/e...ry/mi-35m.html
                  small attack: MI-28
                  http://www.russianhelicopters.aero/e...ry/mi-28n.html
                  super fast nightmare class :KA-52
                  http://www.russianhelicopters.aero/e...ary/ka-52.html
                  • Akira81
                    LG 55LF652V-ZA flashing led bars despite their replacement
                    by Akira81
                    I have this 55" LG 55LF652V-ZA smart TV which suddenly started flashing intermittently every 2 seconds with the backlight.
                    If I aimed the light bulb of my cell phone I could see the underlying image even in those fractions of time when the LEDs were off and the audio instead came out continuously.
                    Armed with a lot of space and patience, I decided to open the TV, immediately noticing that a LED had flamed out and also burned a portion of that reflective white panel behind the transparent LED diffusers.
                    04-14-2023, 11:50 AM
                  • lilfarhad94
                    Fujifilm X-T20 Shutter Issue
                    by lilfarhad94
                    I have a Fujifilm X-T20, and the shutter is not working. The camera seems to think the aperture is stuck and gives me an error message asking me to turn it off and on again (Turn off the camera and turn on again).
                    I noticed that there are two optical sensors near the shutter. Each sensor has four pins, with two of them connected together, meaning there are only three wires per sensor going to the mainboard. None of these wires are connected to ground.
                    When measuring the voltages during operation, I found the following values:
                    - Sensor...
                    02-08-2025, 10:29 PM
                  • x_orange90_x
                    Samsung UN46C8000XFXZA vertical bars/horizontal lines
                    by x_orange90_x
                    I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                    The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                    09-04-2023, 12:09 PM
                  • CapLeaker
                    LG 65UQ70 horizontal bars jumping
                    by CapLeaker
                    So I bought this LG 65UQ70 today at Walliworld. Put the wall mount on, set it up, worked for 30 mins and then I get these jumping horizontal bars. Let the TV do updates and let it cool down for 5 mins. Worked perfect for 2 mins. As soon the TV is warm I get the jumping vertical bars again.
                    Keep the other TCL thread in mind. Now I am questioning are all COVID 2022 / 23 TV’s bad or what? That’s two 65” TV’s one from Amazon and this one from Walmart. What are the chances on that?
                    I guess this one goes back either later today or tomorrow morning, unless...
                    08-13-2024, 09:41 AM
                  • ninja_zx11
                    Sharp LC-70LE650U vertical black and red bars
                    by ninja_zx11
                    70" LED TV is Sharp LC-70LE650U.
                    Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
                    07-07-2023, 11:27 PM
