TS100 or t12 ?
  • capwizard
    • Jun 2016
    • 1991
    TS100 or t12 ?
    TS100 or t12 ?
    Both are Hakko clone T12 tips. TS100 tip is short version of T12 tip.
    TS100 and other soldering irons for when you're away from the bench
    https://www.youtube.com/watch?v=sDMhh3p2nuM
    Trial on the AI-controlled TS100 Soldering Iron
    https://forum.sparkfun.com/viewtopic.php?f=5&t=41990
    Highlight:
    With a 6-cell lithium battery as its power supply, the mini soldering iron could reach a power of 70W. It only takes 7 seconds to heat the iron from normal temperature to 300 degrees Celsius.
    The soldering tip is built in with a thermocouple with both the anode and the cathode.*
    As the temperature rises, the resistance of either direction measures inconsistent. The measurement results indicate that the tail part s electrode is positive, which is consistent with the polarity of Hakko T12 tip.
    Now the ohmmeter probe s short circuit resistance value is 0.42 ohm. Then the resistance value of the soldering tip, based on the measurement result, should be (8.64+8.26)/2-0.42=8.03 ohm, which is equal to that of Hakko T12 tip.
    Charger rated output voltage is 19V and current 2.1A.
    TS100 Soldering Iron test ?
    http://www.eevblog.com/forum/reviews...ing-iron-test/
    Ts100 on sale for $45.55 not bad. Ive ordered one.
    http://www.banggood.com/TS100-Digita...tml?rmmds=cart
    T12 solder iron same as TS100, but longer and no STM32 professor. Ive ordered one.
    https://www.aliexpress.com/item/T12-...608.0.0.kXrCPd
    Qne is digital temperature control, other is analog temperature control.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: TS100 or t12 ?
    The end of the tip seems quite a way from the handle but I guess it depends on the type of work you do.
    I just bought one of these that takes the T12 tips. https://www.aliexpress.com/item/EU-p...714184325.html
    • capwizard
      • Jun 2016
      • 1991
      Re: TS100 or t12 ?
      How do you like it...?
      • diif
        • Feb 2014
        • 6978
        • England
        Re: TS100 or t12 ?
        I think it's great. The handle is smaller than my old one, the tips hold their heat and I can solder things I couldn't before. The handle has a slightly soft rubber feel to it rather than hard plastic which provides some grip and is nice to hold.
        The power supply is smaller than I was expecting. 120mm x 60mm x 35mm. It heats up quick.
          Great Sage éœŠć€©ć€§è–
          • 31277
          Re: TS100 or t12 ?
          i was going to get one but my budget just got fucked up and hour ago,
          my hot air unit died!
          so expect a review of the Kaleep 858D soon i guess, because now i have to order one on monday.
          (with the money i put aside for the Bakon 950d )
          • capwizard
            • Jun 2016
            • 1991
            Re: TS100 or t12 ?
            The two solder irons I bought are for experiment. Really, I try to do is DIY. Buy the tips and use a 18650 with step up boost converter or junk AC adapter or ATmega328 power it up. Good for whom on a tight budget.
            a Hakko Tip T12 Series Soldering Iron Tips Hakko 951 T12-ILS
            https://www.aliexpress.com/item/Hakk...4-939ee96bed89
            2016 Replacement Soldering Solder Tip For TS100 Digital LCD Soldering Iron Educational Equipment TS-D24
            https://www.aliexpress.com/item/2016...999.305.L7q7Kx
            10PCS/LOT T12 Series Solder Iron Tips For Hakko Soldering Rework Station FX-951 FX-952 FREE SHIPPING
            https://www.aliexpress.com/item/10PC...999.264.lgouyx
            Zero 1pc Replacement Soldering Iron Tip for USB Powered 5V 8W Electric Soldering Iron
            https://www.aliexpress.com/item/Zero...e-60220b1d4a89
              • Jul 2011
              • 6070
              Re: TS100 or t12 ?
              Originally posted by
              B
              Highlight:
              With a 6-cell lithium battery as its power supply, the mini soldering iron could reach a power of 70W. It only takes [COLOR="DarkRed"
              7 seconds[/COLOR] to heat the iron from normal temperature to 300 degrees Celsius.
              Where do you get the one that is battery powered
              • capwizard
                • Jun 2016
                • 1991
                Re: TS100 or t12 ?
                I try to use a 18650 battery power up those tips.
                kinda like this guy doing, but mine will have step up converter.
                https://www.youtube.com/watch?v=-9a5z3s4Lsg
                • capwizard
                  • Jun 2016
                  • 1991
                  Re: TS100 or t12 ?
                  T12 bits DIY solder iron. (same asTS100 tip)
