TS100 or t12 ?
Both are Hakko clone T12 tips. TS100 tip is short version of T12 tip.
TS100 and other soldering irons for when you're away from the bench
https://www.youtube.com/watch?v=sDMhh3p2nuM
Trial on the AI-controlled TS100 Soldering Iron
https://forum.sparkfun.com/viewtopic.php?f=5&t=41990
Highlight:
With a 6-cell lithium battery as its power supply, the mini soldering iron could reach a power of 70W. It only takes 7 seconds to heat the iron from normal temperature to 300 degrees Celsius.
The soldering tip is built in with a thermocouple with both the anode and the cathode.*
As the temperature rises, the resistance of either direction measures inconsistent. The measurement results indicate that the tail part s electrode is positive, which is consistent with the polarity of Hakko T12 tip.
Now the ohmmeter probe s short circuit resistance value is 0.42 ohm. Then the resistance value of the soldering tip, based on the measurement result, should be (8.64+8.26)/2-0.42=8.03 ohm, which is equal to that of Hakko T12 tip.
Charger rated output voltage is 19V and current 2.1A.
TS100 Soldering Iron test ?
http://www.eevblog.com/forum/reviews...ing-iron-test/
Ts100 on sale for $45.55 not bad. Ive ordered one.
http://www.banggood.com/TS100-Digita...tml?rmmds=cart
T12 solder iron same as TS100, but longer and no STM32 professor. Ive ordered one.
https://www.aliexpress.com/item/T12-...608.0.0.kXrCPd
Qne is digital temperature control, other is analog temperature control.
Highlight:
