Hello,can you still obtain ribbon to connect technics seperates,i have the connectors but the wires/ribbon have been cut,can you use similar what are in pc towers,
technics ch770
Re: technics ch770
https://www.moddiy.com/products/USB3...WG-Black).html
Found this not sure how many pin the technics is though,I do have three connectors but missing one,Comment
Re: technics ch770
i think there 19 after looking at some images on google etchttps://www.moddiy.com/products/USB3...WG-Black).html
Re: technics ch770
can you count the pins where there cut on the cable? are all the connectors the same size.Comment
Re: technics ch770
SC-CH770
The manual lists 3 system cables 1 -(15P) 1 -(19P) 1 -(20P)
REX0661 - long cable
REX0660 - middle cable
REX0608 - short cableAttached Filesif you find these attachements useful please consider making a small donation to the site
by zeskoHello,
I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
There is 2 models, idk which one is needed on my laptop.
0xkvng
00vpr2
Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
thanks...-
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by CapLeakerI’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?!
Channel: Troubleshooting & Designing Networks
by RubenlilyHey,
So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines... -
by EniaroI have a number of laptops with damaged USB-C connectors.
I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh). - Loading...
