technics ch770
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    technics ch770
    Hello,can you still obtain ribbon to connect technics seperates,i have the connectors but the wires/ribbon have been cut,can you use similar what are in pc towers,
    • 31277
    Re: technics ch770
    i had a setup once without the ribbons, i replaced the connectors with D connectors.
    btw, dont use pc ribbon cable - it's not thick enough to supply power to the slave units from the one with the psu.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Re: technics ch770
      https://www.moddiy.com/products/USB3...WG-Black).html
      Found this not sure how many pin the technics is though,I do have three connectors but missing one,
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Re: technics ch770
        Or if anyone could advise would scart lead ribbon work ?
        • vinceroger69
          • Mar 2012
          • 6714
          Re: technics ch770
          i think there 19 after looking at some images on google etc
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Re: technics ch770
            Mmm some are 15,
            • vinceroger69
              • Mar 2012
              • 6714
              Re: technics ch770
              can you count the pins where there cut on the cable? are all the connectors the same size.
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                Re: technics ch770
                There is 20 pins
                • R_J
                  • 9621
                  Re: technics ch770
                  SC-CH770
                  The manual lists 3 system cables 1 -(15P) 1 -(19P) 1 -(20P)
                  REX0661 - long cable
                  REX0660 - middle cable
                  REX0608 - short cable
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    Re: technics ch770
                    Thanks,now where can I obtain universal ribbon ?
                    • zesko
                      xps 9520 ribbon cable
                      by zesko
                      I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
                      There is 2 models, idk which one is needed on my laptop.
                      0xkvng
                      00vpr2
                      Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
                      Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
                      thanks...
                      10-23-2025, 05:03 PM
                    • Tr0ll
                      by Tr0ll
                      Original T-con:
                      First replacement T-con:
                      10-07-2023, 07:48 PM
                    • CapLeaker
                      Crimping CAT7 connectors high failure rates
                      by CapLeaker
                      I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
                      Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
                      11-09-2024, 04:11 PM
                    • Rubenlily
                      Quick question about the ribbon
                      by Rubenlily
                      Hey,
                      So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
                      When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines...
                      08-17-2023, 11:09 AM
                    • Eniaro
                      Are USB C connectors standard
                      by Eniaro
                      I have a number of laptops with damaged USB-C connectors.
                      I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
                      I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
                      I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
                      07-24-2023, 03:07 PM
