Hello,can you still obtain ribbon to connect technics seperates,i have the connectors but the wires/ribbon have been cut,can you use similar what are in pc towers,
technics ch770
Re: technics ch770
https://www.moddiy.com/products/USB3...WG-Black).html
Found this not sure how many pin the technics is though,I do have three connectors but missing one,Comment
Re: technics ch770
Re: technics ch770
can you count the pins where there cut on the cable? are all the connectors the same size.Comment
Re: technics ch770
SC-CH770
The manual lists 3 system cables 1 -(15P) 1 -(19P) 1 -(20P)
REX0661 - long cable
REX0660 - middle cable
REX0608 - short cableLast edited by R_J; 10-29-2016, 01:55 PM.Comment
by Tr0llHi guys! I realized you have a lot of knowledge here so i am hoping you could point me in right direction with my odd issue.
Original T-con:
First replacement T-con:
I thought it might be t-con and ordered new t-con from china(supposedly tested)... -
by CapLeakerI’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?!...
Channel: Troubleshooting & Designing Networks
by RubenlilyHey,
So I have horizontal lines on my TV and I'm trying to trouble shoot. My question about the ribbon is:
When I disconnect one ribbon from the t-con I should get half picture working and other half black or something like that correct? But when I disconnect the ribbon on one side I just get a dark screen and it doesn't matter what side I disconnect. I just get the dark screen. No half working, no one half black and the other one left. Sound is playing from the TV so it's obviously on and when both sides are connected I have the picture with the horizontal lines... -
by EniaroI have a number of laptops with damaged USB-C connectors.
I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh). -
by ScincidaeI recently was given a UN70NU6900FXZA that would only boot loop once plugged in (auto powers on when plugged in). I found that disconnecting the lower (right side) LVDS ribbon, then plugging the TV in, followed by reconnecting the lower LVDS ribbon will allow the TV to work 100% normal as far as I can tell (no lines, no discoloration, no dimming or anything like that).
I tried the tape method on the lower LVDS ribbon and found that if I cover pins 10 and 11 (counting from the bottom up) allows the TV to boot normal but 25% screen all the way to the right side is discolored. While... - Loading...
