Curve tracer question ?
  • bianchi77
    • Jun 2016
    • 1121
    Everyone,
    Does anyone ever use curve tracer for component test?
    I'm wondering...
    http://www.changpuak.ch/electronics/Curve_Tracer.php
    Cheers
    Re: Curve tracer question ?
    I use this at work:
    • bianchi77
      • Jun 2016
      • 1121
      Originally posted by budm
      I use this at work:
      Is it expensive for home use ?
      • bianchi77
        • Jun 2016
        • 1121
        I think this one is suitable for my home budget :
        http://www.ebay.com.au/itm/Transisto...IAAOSweW5VNSXF
        • diif
          • Feb 2014
          • 6978
          • England
          You have an oscilloscope ?
            • 31247
            IMO a curve tracer is something for museums.
            • bianchi77
              • Jun 2016
              • 1121
              yes I have scope....is it similar only some kind a module for supporting scope ?
                • 31247
                this may clarify things
                • Vanillaboard
                  Hantek 6022BE USB Port pulled out
                  by Vanillaboard
                  I'm currently working on a Hantek 6022BE where the USB port and vias have been ripped off the PCB. Here are the steps I've taken so far:
                  1. Power Supply: I've tapped the power supply next to the via from the tracer.
                  2. GND: I've successfully connected the GND as well.
                  3. Data Lines: I soldered the D+ and D- lines directly to the USB controller (CY7C68013A-100AXC) at pins 17 and 18.
                  Now I'm wondering if I need pull-up resistors. According to my observation, the tracer goes directly from D+ and D- to the USB Port. Could that be right?
                  Despite these steps,...
                  09-22-2024, 06:41 AM
                • ronaldo17
                  Need schematic for this board (cyberpowerpc tracer 2)
                  by ronaldo17
                  I need schematic for this board.
                  Spec:
                  I7 7700HQ
                  GTX 1070
                  This is just my second topic on this forum,so if i do anything wrong,please forgive me(I even dont know how to reply)
                  Thank you very much beacause helped me...
                  07-23-2025, 02:32 AM
                • spleenharvester
                  QNAP TS-469L NAS shutting down randomly
                  by spleenharvester
                  I bought this NAS as "turns on then straight back off again". When I received it it had no trouble staying on, just the RAM stick was in the wrong slot so it wouldn't POST. I was hoping that was all that was wrong with it, but it's now started randomly shutting off once a week. When I find it off it will fire straight back up again if I hit power, no need to power cycle. Nothing ever in the logs aside from "the last shutdown was unsafe".
                  It's got an internal PSU, an FSP250-50LC (which is wildly overkill for the hardware really). The electrolytic caps in the PSU...
                  08-31-2024, 08:04 AM
                • Shakeel Baig
                  Schematic of Tracer 4215BN
                  by Shakeel Baig
                  My 4215BN mppt charge controller broke. I need schematic for it's repair.
                  06-18-2024, 11:16 AM
                • k24a1
                  TongFang GK5CN5Z (CyberPowerPC Tracer III Xtreme) LCD backlight flickering
                  by k24a1
                  Hello, I have a strange issue with a laptop that I'm working on fixing up for a friend of mine, and it appears as though the LCD backlight control is not reliable. The LCD backlight flickers sometimes with inconsistent brightness. The controls are no better.. when I go 1/3 of the way in the brightness controls it will get bright but flicker quite obviously, and when I go all the way to what SHOULD be full brightness, it becomes darker. The flickering is less severe at lower brightness, but more severe at higher. the backlight will literally flicker on and off when I set it to the lowest brightness...
                  06-11-2024, 05:45 PM
