attempt to clone LED TV Backlight Tester
  • NeedsMoreFlux
    replied
    Re: attempt to clone LED TV Backlight Tester
    What about just buying a cheap buck/boost converter off ebay with an amp/volt display.
    You could get a voltage reading feeding the LEDs from the tv board, and feed that voltage to it.
  • madhu
    replied
    https://www.youtube.com/watch?v=DHj-UnG-qQU , is it usefull ?
  • Lorañep
    replied
    Well, then what is the best leds strip tester we can build that is the most similar to gj2c? In my country we use 220v ac
  • vinceroger69
    replied
    The led tester has just turned up 12 days delivery to the uk not bad at all i will strip the tester down shortly and take some pictures.
    replied
    "it is exactly the same principle as the light bulb in series to test power supply or any circuit that has a short." Really?
  • rickou
    replied
    I know what you are saying but when running this test I have 0.01A that is passing in the circuit is harmless, it is exactly the same principle as the light bulb in series to test power supply or any circuit that has a short.
    replied
    We are talking the reverse Voltage breakdown of the LED or any diode.
    I know your setup, no need for pictures. Just look up what reverse breakdown Voltage of the diode is.
    What do you think what the reverse Voltage is aplied across the LED when it is in reverse bias during the half cycle of the applied AC?
    There is reason why minimum diode break down Voltage is chosen to be used in the circuits.
  • rickou
    replied
    I can test only one led or more led's there is no problem. I don't need to see the polarity cause I'm applying AC voltage and this voltage will be rectified directly by the same leds that I'm testing. So I'm having half wave in the led thats why is irrelevant the polarity. The only thing is that the led will blin will blink 50times a sec here I live is 230v 50Hz but I can barely see this. I will post some pics if you want.
    replied
    That is why I said it is also dangerous (to human and device) and good LED can be damaged, at least put 1n4007 in series and have to test with correct polarity. You can be lucky for so long.
    https://www.digikey.com/en/articles/...ial-protection
  • rievax_60
    replied
    Originally posted by rickou
    So I will tell how I test my LED strip from TV all strip at once without any tester. I have a old outlet cable that I took from a radio and I have cut and put 10kohm/2w resistor in series then I make one probe, in the other able i only have put one probe.
    When I need to test LED from a TV I put the cable in a 230V outlet and test directly the strip not even have bother in see the plus and minus..
    Here you have the most cheap, free of electronic waste, and reliable I use this for more then 4 years now
    How do you test single or smaller groups of LEDs? Many LEDs do not have reverse protection diodes.
    replied
    Yep, cheap, works, and dangerous. Max current worst case is 23mA.
  • rievax_60
    replied
    That is too risky even for experienced people. It is not uncommon to find outlets with Active and Neutral transposed.
    Have you tried using back to back transformers for isolation?
  • rickou
    replied
  • rievax_60
    replied
    I have traced some of the circuitry, it makes better sense now.
    With the test leads open, the Source of Q1 rises to the point where the G-S drops to threshold voltage of about 2.5v. Q1's channel resistance will be very high.
    When the leads are connected to a load, very little current first flows through Q1, the current increases as C8 charges. Q1 eventually ends up with about 3v drop across it.
    The current limiting is done by an unidentified SMPS IC that I have represented by Q2.
  • vinceroger69
    replied
    Originally posted by capwizard
    vinceroger69 : After you get it , Please let us know it is good or bad. Open it and take some pictures. Thank you.
    yes of course i will.
  • capwizard
    replied
  • vinceroger69
    replied
    yes paypal charged me £1.00 i think but still a cheap tester at that price.
    replied
    Any tricks in the payment because all the prices are too good to be true(some of items are $0.01)? Why dont they accept VISA?
    Western Union (No Bank Fee) , but it is bank to bank transfers maybe charge $50
    PayPal (PayPal Fee 5%) * Shippment address must match with PayPal register address
    MoneyGram (No Bank Fee) ???
    HSBC Bank (Bank Fee $25.00)
    Alipay.com (Need to contact us) ???
    Where do you see the fees?
    https://www.hklrf.com/Payment_1.html
    I use PAYPAL, so LRF will charge 5% fee and added that to the price?
    It also show accept credit card on the right side of the page.
    https://www.hklrf.com/0-300V-Smart-F...pair_1948.html
  • vinceroger69
    replied
    How about Payment? They doesnt accept VISA?
    I used paypal but he replied to my email within 10 minutes which was good when i asked about uk postage.
  • capwizard
    replied
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • cheebster
    iPad Pro 12.9 5th Gen Backlight Issue
    by cheebster
    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
    Anyone...
    05-20-2025, 09:17 AM
  • canadaboy25
    LG Flatron 24EN33TA No Backlight When Cold
    by canadaboy25
    I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
    I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
    03-07-2023, 12:23 AM
  • gabrielA7
    Macbook pro A1706 / Backlight flex cable compatibility
    by gabrielA7
    Hey guys!!
    I’ve got a question here!
    I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
    Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
    Here’s what the bot told me:
    I said to him: “I’m going to install the 821-01229-A.”
    ChatGPT replied:
    Understood — but before you solder or install the 821-01229-A,
    11-11-2025, 03:26 PM
