Re: attempt to clone LED TV Backlight Tester
i think at that price £21.79 shipped too the uk i will take a chance.
Edit i have just payed for it so when it comes we can run some tests.
I would like to have one myself to really test how it react without load and with load. It is a good as long as it has good protection and no blowing up good LED when testing it afetr the unit is turned on and not connected to the load, that is what I am trying to understand how fast the circuit reacts as posted in post 59..Last edited by budm; 03-31-2017, 10:45 AM.Leave a comment:
thats what i was thinking thanks for conformation and budm do you think that tester in the link is worth buying? ive just had a email back saying they will ship to the uk as i dont mind waiting a few weeks for it and i think the uk price will be a little cheaper than the ones shown on the web pageLeave a comment:
budm is it true that a shorted led can still light up? im sure ive read somewhere they can.Leave a comment:
https://www.hklrf.com/0-300V-Smart-F...pair_1948.html
Notice:
Please, if you are used to the LED lamps finished, unplug the power supply before!
Because it is likely to form a loop, which in Abnormal test!
Additional application:
The capacitance voltage
The voltage regulator
worth 3 lamp drive voltage test!
Examination skills:
Plug IN POWER, it can be used after 5 to 10 seconds (first time, the machine needs to warm up!).
Soft Start mode make the backlight brighter always slow.
No burning, if you can not make the "+" and "-", do not connect the probes to the LED will be tested for a long time.
Open ciruit protection: Do not touch the output terminal of probes for a long time. It is safe for Touch the probes in the shortest time.
Double isolate design makes our testers safety with high strength and flame retardant materials.
Safe / smart / precise / highly efficient
Double isolated safe protection no burning, no electric shock, voltage and current intellgent setting,
High brightness disassemble no need.
Single LED light bar backlight check:
make sure the anode and acthode.
connect the probes to the anode and the cathode.
light up the single LED light bar backlight.
light up the double LED light bar backlight.
So these testers have the so called SOFTSTART circuit that ramp up the Output Voltage, so if you turn it on and not connected to any load (LED) then I expect the output Voltage will reach 300VDC (unless it has open circuit protection) then if you connect the output probe to ONE LED, I wonder if the circuit will react fast enough to drop that output Voltage down to 3V and not damaging the LED since if there is filter cap at the output then that cap will have to be discharged to drop the Voltage down. Any one out there has one to try out.
BTW, I wonder what this means "Because it is likely to form a loop, which in Abnormal test!"Last edited by budm; 03-31-2017, 10:06 AM.Leave a comment:
I have just tried to create a account it says a extra 10.10 postage to the ukLeave a comment:
"18.1v / (20 / 2) = 1.81v " are they two strings of 10-LED per string connected in parallel?
Yes it is.
pic1 : Clone LED tester for sale $14.90 but shipping and payment ? Be careful.Attached Filesif you find these attachements useful please consider making a small donation to the site
" it shows 20 LEDs, but the Voltage reading is showing 18.1V" ............18.1v / (20 / 2) = 1.81v The color of LEDs are amber because they are cheaper than white one. http://www.torchstar.us/5m-5050-ambe...ip-lights.htmlAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/forum/attach...9&d=1490803893
The section you marked as 'CURRENT MODE BOOST' is the hot primary side SMPS showing the SMD power MOSFET driving the primary winding of the power transformer, you can see the Drian pin connected to one pin of the transformer and the RCD Snubber network (R2, C3, VD8).Leave a comment:
https://www.badcaps.net/forum/attach...5&d=1490812596
Hmm something is not right, it shows 20 LEDs, but the Voltage reading is showing 18.1VLeave a comment:
More LED testers, they copy each other's circuit.............
I bet yu. Next generation LED tester will be battery power, V & A adjustable, OLED or LCD V And A display, Microcontroller shows what type LED and how many of LEDs in one or total strip, LEDs brightness(LUX) and and lifetime span.
With WiFi add -on the tester will reach the Database and finds out what kind screen youre testing and who made that LEDs or LED strips by reference current, voltage, LUX, and wattage parameters. By that time, we don't need LED tester (as CCFL tester anymore), we will need is OLED tester.Attached Filesif you find these attachements useful please consider making a small donation to the site
May be some voltage comparator.
Nothing connected SMPS is driven by optocoupler D1
Some LED's connected depending on voltage resulted D2 or D3 override somehow D1 as result SMPS output could be 50V or 150V or 300V
That decrease power disipated by series regulator.
But maybe I'm wrong.Who knows.Leave a comment:
SID GJ2C's competitor. it Looks like a AC Adapter, LED voltage meter + current mode boost converter of which is for higher current purpose.
Who knows in the picture (pic4) the question mark aera circuit is for?Attached Filesif you find these attachements useful please consider making a small donation to the site
i never heard.... Switchable Current Regulators IXCP 10M45S...People used for Tube Asylum(tube current source). Thank you, I've learned from you.
Why can we use junk LED power board from manufacturer, Modify it to A variable current and variable voltage power source.........From the feedback of the driver IC maybe it just needs two Potentiometers for voltage divider. .......... as A LED tester and LEDs strips (screen) power supply? This gonna be my next homework.Attached Filesif you find these attachements useful please consider making a small donation to the site
I whip together a HV constant-current source using depletion mode MOSFET. It needs a heatsink because it is in linear mode. It's a couple resistors and a diode, good to 400-1,000V. Then I use any HV DC power supply.
See:
IXYS 10M45S and Supertex DN2540
IXYS IXTP08N100D2 depletion mode MOSFET 1,000V
Resistor calculator hereAttached Filesif you find these attachements useful please consider making a small donation to the site
Using some boost converter may be done.
Looking for something like that I see this
https://www.amazon.com/Qianson-Volta.../dp/B01J2T48L6
but not clear what say
We need 300V at 20-30-40mAOutput current: 2-20mA.( if you want to add current, pls put insurance below the transformer replaced the 0ohm resistor, maximum 50mA, but does not recommend increased.)
It may be enough even at 20mA if description is for real.
Or better this
https://www.amazon.com/gp/aw/d/B01JL...ID=61guzKBeQpL
But seems to powerfull for that.Last edited by gabiz_ro; 03-28-2017, 09:33 AM.Leave a comment:
rievax_60 Thank you for the fotos. This one do has a MOSFET, Maybe they designed similar to this circuit.
gabiz_ro Would you please try to design A battery powered LED tester? If you have time.Attached Filesif you find these attachements useful please consider making a small donation to the site
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by canadaboy25Hi all,
I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...-
by gabrielA7Hey guys!!
I’ve got a question here!
I have a MacBook Pro A1706 that needs the backlight cable replacement — the well-known issue — but the problem is that the code on my original cable is 821-00571-A, and the one I have on hand to install is 821-01229-A.
Well, I asked ChatGPT about it, and the guy told me they’re not compatible and it could even burn the backlight circuit!!
Here’s what the bot told me:
I said to him: “I’m going to install the 821-01229-A.”
ChatGPT replied:Understood — but before you solder or install the 821-01229-A,...11-11-2025, 03:26 PM - Loading...
