How much current goes through me when I touch 120VAC?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: How much current goes through me when I touch 120VAC?
    Technically speaking rings are a special case. When you wear a ring, that part of the skin underneath the ring will sweat. That sweat will increase conductivity between you and the ring, making it that much more dangerous. It also increases surface area as instead of just a point contact, it's all the way around your finger.
    The danger of electricity is that it can make you tighten your grip, increasing sweat, making it conduct even more electricity, until you're fried to a crisp. If you can get yourself to stop touching it, chances are good you'll survive, depending on what parts of the body got the electricity (like the documented lightning strike cases).
    Maybe with AC, "skin effect" actually plays a role. However it still will affect your muscle movement, likely making you unable to move the affected muscle away from the danger.
    In any case I'm not going to take bets until I know for certain capacitance = 0 (actually, reactance at whatever frequency the AC is at) and resistance = near infinity (for the DC cases). It needs to be a really bad cap
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      Thanks Eccerr0r! I usually work with my wedding ring on, but I think I'm going to start taking it off. It's made out of real gold.
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
        • 31199
        or get some cotton gloves.
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          Take all jewelry off. I reached into a box once and my watch shorted on a hot wire. I was already on edge reaching into a box like that so I got out instantly. Never again, carry a pocket watch if you get a job where you have to do that a lot.
          sigpicThe Sky Is Falling
            • 31199
            my phone tells me the time, not owned a watch for about 15years.
            i'm not sure of the reason for this thread though, this is not really worth worrying about with domestic wiring etc.
            • Spork Schivago
              • Mar 2012
              • 4734
              #26
              I saw how people can actually die from 120VAC. That reminded me it didn't take much amperage to kill a person. Seeing how I've been working with 30 amp breakers, that made me question why I don't die when I touch those hot wires. Budm pointed out that it's the resistance of my body.
              I still want some clarification here. Those 30 amp breakers, are they actually providing 30 amps of current? Or is it just when a device needs it, they can handle up to 30 amps of current? I'm still not very clear on that.
              • Spork Schivago
                • Mar 2012
                • 4734
                #27
                K. I saw some video of a guy's finger that had a ring on it. He was doing some work with a car. I don't know what. But something snagged his ring and took his ring off very quick like. It took his freaking skin off too! His finger was there, still attached, but it was all raw from where the ring was to where the fingertip was! They showed his actual skin and it looked like someone cut his finger off, but it was hollow inside. I'm not 100% sure it was real, but that has to be the nastiest thing I have ever seen in my whole life.
                • caphair
                  • Nov 2011
                  • 1249
                  #28
                  A breaker doesn't provide current, it's meant to be able to withstand 30 amps of current (or whatever the breaker is rated at) if the rated amps are exceeded it trips the breaker which cuts off power (essentially becomes an open circuit at the breaker) as to prevent overheating if wire insulation and potentially causing a fire
                    • 31199
                    a breaker is just a resetable fuse.
                    • caphair
                      • Nov 2011
                      • 1249
                      #30
                      There was a guy down in Florida (when we went on a mini-vacation / party spree) that bet me 5$ he could stick a screwdriver in the outlet, touch the metal part and not get shocked. I took the bet because I had done this and got shocked when I was a kid! Sure enough, he stuck it in each hole and didn't get shocked. He said it was because he wasn't grounded. Something about his shoes were acting as an insulator. So, is this true? From my understanding of electricity, it makes sense, but from what you're saying here, it's a bit of the opposite? Even if you're not grounded, AC can still flow through you?
                      Just curious as to why the guy didn't get shocked.
                      Insulation definitely reduces the amount of current through body and in some cases you may not even feel a shock. But depending on the quality of insulation you can feel something or feel a mild shock.
                      If you are say floating in air like a monk with some good distance from ground, like standing on a wooden chair, then you likely won't feel a thing. But on a bed with all those metal springs inside, you might feel it a bit.
                      The thing is that the circuit is not open and is complete. It is completed by human capacitance and surroundings.
                        • 31199
                        air has an electrical charge - that's why i have a negative ioniser.
                        your ascention monk theory is flawed
                        • fzabkar
                          • Mar 2009
                          • 772
                          I wonder how much voltage and current went through my head when I came into contact with the wrong end of an electric fence controller. (Please don't ask how I managed that.)
                            • 31199
                            um - is there a "right end" of a fence controller to come into contact with???
                            • fzabkar
                              • Mar 2009
                              • 772
                              It was one of the many stupid things I've done in my life. I'm very hazy on the details, but I recall returning the unit to the customer and telling him that I found nothing wrong with it. :-)
                              Actually it wasn't a typical electronics-in-a-box fence controller. The device had a heavy base which contained the electronics, plus a long arm (no, it wasn't a cattle prod). The end of the arm contacted my forehead while I was working on the base. It sure woke me up, I can tell you. I don't think I suffered any lasting damage, but, as I said, I'm hazy on the details. :-)
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                #35
                                Taking a wizz on one of those fences is not a good idea either.
                                • TechGeek
                                  Computer Geek
                                  • Jan 2015
                                  • 2254
                                  HAHAHAHAHA!!! I've gotten hit by 120VAC trying to set the time on an old Copal model 227 flip clock. Felt tingles, ripped my finger away, and saw a black mark where my finger had hit the wire. The clock was immediately unplugged and the cord wrapped in electrical tape. My arm felt weird... :P
                                  Permanently Retired Systems:
                                  Kooky and Kool Systems
                                  sigpic
                                  • TechGeek
                                    Computer Geek
                                    • Jan 2015
                                    • 2254
                                    440kV lines:
                                    sigpic
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #38
                                      Intro:
                                      https://youtu.be/tA9oBEHRLqQ
                                      H/V, helicopters, and explosives:
                                      https://www.youtube.com/watch?v=x94BH9TUiHM
                                      H/V, helicopters, and water:
                                      https://www.youtube.com/watch?v=lcjhjna9jZE
                                      What could possibly go wrong?
                                      • desert-rat
                                        • Mar 2014
                                        • 4103
                                        I don't know if this was covered, I did not read all the other comments. You need to get your ohm meter, measure your ohms ,then plug that into ohms law. E over I R .
                                        P.s. find a girl friend that is a nurse/e.m.t. first.
                                        • fzabkar
                                          • Mar 2009
                                          • 772
                                          It's not as simple as that. The resistance of the human body is not linear. It depends on several factors. One of budm's links explains it all.
                                          • trepachka
                                            Converting HP EliteBook 840 G7 non-touch to touch if possible
                                            by trepachka
                                            I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
                                            The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
                                            I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
                                            04-27-2024, 11:15 PM
                                          • Prott
                                            Surface Pro 4/5 - no touch after LCD change
                                            by Prott
                                            I have a question that's driving me a bit nuts recently.
                                            Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
                                            - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
                                            - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
                                            01-25-2023, 12:42 PM
                                            Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                            by sam_sam_sam
                                            I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                            I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                            I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                            02-04-2025, 08:08 PM
                                            Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
                                            The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
                                            All AP21X2SG-13 AP21X2MPG-13 devices are available...
                                            10-23-2024, 03:33 AM
                                          • DynaxSC
                                            Extreme High Current & Low Voltage Short Killer ??
                                            by DynaxSC
                                            Hi Folks
                                            I'm looking for a extreme high current short killer solution for a reasonable cost.
                                            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                            After taking off the socket, the shorts dissappear again.
                                            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                            10-15-2024, 10:13 AM
