Looking for resistor
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Looking for resistor
    So the link to the pictures bring one back to one post. I notice in the upper right hand corner the link to the whole post. I click on that and go to the whole post, look at where you supposedly post pictures and there are none. I do see the diagram in one post but on pictures post of the actual set up as you have them it is not there. Usually one brings both wires from the door bell to the chime. One of those wires are gets cut. That wire goes to the chime the other wire on the chime goes to one side of the transformer. The other solid wire that is not cut at the chime goes to the other side of the transformer this then completes the circuit. So it is best if you draw out what I said on a piece of paper and then look at the wires to chime and see if they are connected it in this way.
    • mxslick
      Motocross Racer
      • Oct 2010
      • 19
      Originally posted by Almighty1
      Not when the cost is over $10k as all the walls will need to be torn down. I will already be spending $650k+ in the remodeling process alone, licensed electricians and even contractors had looked at the issue as this was even part of the home inspection process before the home was purchased 7+ years ago. They basically all said that to fix the problem, all the walls need to be taken down and demolished as that will require a permit on it's own since everything is in sealed walls now which is why they all suggested to just have it done during the remodeling process since everything will be taken down at that point anyways. I am not planning to use the resistor on the existing wiring as I want to avoid that due to what was mentioned by you and others about the safety hazard. This is why I will just have a plug-in transformer to the wall directly to the doorbell which is about 10 feet away and the reason for the resistor.
      Do I understand this right, you are going to spend close to 3/4 of a million dollars on a renovation, and you feel that $10k (roughly 1.6% more) is too much to add to ensure your (and your family's) safety and keep from losing that $650k+ investment in renovation costs?
      Or, is the question in this thread just a (very) temporary setup until the renovations are being done?
      I am concerned as with over 30 years as an electrician and LV/AV installer the pics (Post #7 in this thread here: https://www.badcaps.net/forum/showthread.php?t=52762 ) revealed some very dangerous issues..I have seen way too many close calls and serious fires over my career caused by things like this.
      Please be careful and make sure you have working smoke alarms.
      • Almighty1
        • Apr 2014
        • 222
        That's weird because I know budm and others have seen the pictures which is easier to explain so it has to be your internet connection or you have something that is blocking imgur.com from showing you pictures as it works fine for me and everyone else. I suck at drawing anything so my drawing for diagrams would not work. I know what usually people do but the only thing visible is two wires at where the doorbell is supposed to be and two wires at where the door chime is supposed to be, I can also see the transformer end with a white and red wire. You're missing the point that I don't have a door bell or door chime yet and I don't need the door bell because the whole reason for the door chime is so I don't have to get the resistor to use with another transformer so my question is really how do I determine which of the two wires sticking out at the place where the door chime is supposed to be is connected to the transformer or not since remember I cannot see anything after the 6" exposed wires goes into the wall. and just to remind you, I do not have a chime yet so what would be the best way to check if one of those wires is connected as that is all I want to know.
        • Almighty1
          • Apr 2014
          • 222
          The $650k is sitting in investments right now so when it's needed, it will be taken out. You do realize that the longer someone takes to answer my question about the resistor which is what this thread is really about, the more I have to unmount the $200 ring.com doorbell which I need to do once a week as the screws will strip sooner or later if I keep mounting and unmounting once a week. I know my smoke alarms are working since I have both wired alarms that are monitored by nextalarm.com and also have nest protect alarms. As for renovations, like I said before, everything will only be temporary since I am not doing remodeling but the entire house will be completely demolished and then rebuilt so it is both longer and taller so what is the point of spending the $10k which will take atleast 6 months to get approved since San Francisco is both a city and a county and it's not that easy to demolish things and by demolishing things, that is when there is both safety and liability as there is a problem with the foundation of the house. Besides that, it's not like I will spend $10k and that $10k will be there since remember once the remodeling starts in 7-12 months, everything will be torn down so that $10k basically just went down the toilet or forcing money to hell. Besides that, as I mentioned before, I will be going on vacation for a month in less than 2 months and the whole point of the ring.com doorbell is not just for someone to ring the doorbell but it acts as a security camera which logs all events that are motion detected based on heat which is why it's important to hard wire the ring.com doorbell so that it does not require unmounting to charge and then mounting it back again once a week when no one will even be here. It's a security and safety issue since if someone breaks in while I am gone, atleast there will be security video footage. That is the reason for the resistor which I have been asking about for the last few weeks. Not sure why it is so hard to answer a simple question but instead, everyone seems to be more interested in the garage and it burning down. There is always risks in everything and then benefits as well. You can walk out the street and get run over by a car so does that mean you'll just stay home all day? My trip is in May and I need to get this done before tax season starts when I won't have much time which was the reason I was asking for suitable resistors that meet that specification. I will not be using the existing transformer and I have way more important things to figure out like the mouse and rats in the garage that has been chewing things up in the house the past few months. Having a electrician will not only cost that $10k but also let the mouses and rats in as they are now locked inside the garage. So let's treat the two threads as two different things because they are. The garage and existing transformer is one option without using the resistor and I could care less if the chime makes a sound or not as I have the Ring Wireless plug-in chime for that purpose while this thread is using a new transformer near the doorbell with a resistor and no chime and the whole purpose of it is just to hardwire to the ring.com doorbell which is not just a doorbell but rather a security monitoring system to prevent bad things happening before it does versus security systems that alert after the break-in. Besides that, the mortgage company who still actually owns the home until it is paid off is aware of everything and the liability is on the insurance company if it does burn, etc. and should it burn down, I will actually be saving money as in 3/4 of a million since the insurance will pay for building the new house. I never said the house was in good condition to begin with so if it burns down, it will actually be better for everyone except the insurance company. Besides that, as I said over and over again, no electrician or contractor will touch it regardless what you paid them as there is lots of liability involved since we live on a hill, last thing they want to be liable for is the house sliding on neighbors properties and then be liable for that.
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            Greetings everyone:
            I have a ring.com doorbell and it seems like to hardwire the doorbell so I don't have to take it off the wall to charge it weekly, I need a transformer and a resistor as seen here:
            https://support.ring.com/hc/en-us/ar...a-doorbell-kit
            So basically I need a 25 to 33 Ohm/20 to 50 Watt wirewound resistor, does anyone have any recommendations on what brands/parts are suitable for this and also for the doorbell wire, can I just use 18 or 20 guage speaker wire? Also, is there a reason to use a wirewound resistor instead of a film resistor? Since this will be outside, what can I use to cover up the wires?
            Thanks!
            so the doorbell you are using at moment is battery powered? what battery/batterys does it use?
            My pc
            CPU : AMD PHENOM II x4 @ 3.5Ghz
            MB : ASUS M4A89TD PRO USB3
            RAM : Kingston ValueRAM 16gb DDR3
            PSU : Cooler Master 850W Silent Pro
            GPU : ATI Radeon HD 6850
              BTW, the Ring.com provided the link to Digikey as to what type of the resistors to use so they already tried and used them in their lab otherwise they would not have come up with those two recommended resistors.
              So I do not see why you are trying to use something else that they did not recommend.
                https://ring.com/setup
                https://ring.com/faq
                It does have battery inside.
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  #28
                  ok.
                  are you putting a chime on wall where old one was?
                  My pc
                    • 31214
                    the information on that site is useless, i would never buy one.
                    contact them and ask the current-draw of the charging circuit at 12v.
                    without that info you risk burning up your transformer.
                    frankly the design should have allowed for a 5v dc supply using the battery as a backup incase of power failure - not that your net will work in that situation anyway!!!
                      'the information on that site is useless'
                      Really?
                      It has internal battery so when power failed it will still function and the battery can be charged through the USB port.
                      DOES RING REQUIRE POWER WIRES TO WORK?
                      Ring Doorbell can operate wirelessly using its built-in battery. You also have the option of connecting your Ring Doorbell to your home’s existing doorbell wiring.
                      HOW LONG DOES IT TAKE THE BATTERY TO RECHARGE?
                      When connected to a 2.1 amp charger, Ring will fully charge in approximately 4-5 hours. When connected to a 1 amp charger, Ring will fully charge in approximately 9-10 hours.
                      WHAT DOORBELL TRANSFORMERS ARE COMPATIBLE WITH RING DOORBELL?
                      Ring Doorbells may be connected to low voltage transformers that power home doorbell kits. You can connect Ring in series with a transformer operating between 8V and 24V AC only. Intercom systems and DC transformers are not compatible. If you would like to wire your Ring Doorbell to a compatible low voltage AC transformer without a doorbell kit, you must use a resistor. See this article for information on connecting to a transformer without a doorbell kit: https://support.ring.com/hc/en-us/ar...t-a-door-chime
                      WHAT TYPE OF DOORBELL CAN BE CONNECTED TO RING DOORBELL?
                      You will only be able to connect Ring Doorbell to a (hard)wired doorbell. The doorbell must have a transformer with a voltage of 8 VAC – 24 VAC. Wireless intercom systems, and doorbells using a DC transformer are not supported.
                      https://support.ring.com/hc/en-us/ar...-Ring-Doorbell
                      When connected to a 2.1 amp charger, Ring Doorbells can take up to 5 hours to fully charge. Connected to a 1 amp charger, Ring Doorbells may take up to 10 hours to fully charge. Check the print on your charger to determine the amp reading (usually listed as 1.0a or 2.1a).
                      With normal use, Ring's battery can last between 6 and 12 months. If your Ring is capturing large numbers of events each day the battery will deplete faster. You will receive notifications when the battery in your Ring is getting low.
                      To charge your Ring Doorbell:
                      Remove your Ring Doorbell from the mounting bracket.
                      Connect any micro USB charging cable to the charging port.
                      Verify blue and white lights spin on the front of your Ring Doorbell. If no spinning lights, see below for next steps.
                      Allow your Ring Doorbell to fully charge (may take up to 10 hours). When the lights stop spinning and glow blue the unit is charged.
                      https://support.ring.com/hc/en-us/ar...attery-Powered
                      The Ring Doorbell has dual power, which means you can choose to run it off of the internal Lithium battery, or connect it to your existing doorbell wires.
                      Battery Operated (i.e. wireless)
                      If you choose to operate it wirelessly, the Ring Doorbell could last for up to a year before needing another charge. Battery life, however, depends on a variety of factors–the most important being usage. Frequent motion alerts or dings will play in role in how long your device will function before needing another charge. You can plug the included micro-USB charging cord into a USB power wall adapter (e.g. the square that Apple or Samsung provides with your phone) and your Ring Doorbell should only take 4-5 hours to go from empty to full. If you plug the USB charging chord directly into devices that don't support fast charging (such as laptops) it will take closer to 8-10 hours.
                      Hardwired (i.e. connected to your existing door chime)
                      The Ring Doorbell can be connected to your existing door chime–mechanical or electronic–so long as it's between 8-24VAC. Simply remove your door chime and connect the existing wires to the designated terminals on the Ring Doorbell mounting bracket.
                      Once successfully connected, the Ring Doorbell will ring your existing door chime. In addition, your legacy doorbell wires will trickle charge your Ring Doorbell. It's important to note that trickle charging is slightly different than plugging Ring directly into a power source. It's possible that your battery percentage could drop over time depending on usage and temperature.
                      https://support.ring.com/hc/en-us/se...l-Installation
                      https://support.ring.com/hc/en-us/ar...Video-Doorbell
                      Spending $200, that is another question.
                        • 31214
                        yes, it can charge in 5hours, or maybe overcharge if left connected,
                        but if it draws enough current to charge in 5 hours from a 2a transformer, how does it know to limit the current if you can only provide a 1a supply?
                        transformers dont limit current, they just get very hot and fail.
                        critical info is missing,
                        i hope that's not the purpose of the ballast resistor!!
                          Trickle charge:
                          Fast charge when use USB.
                          Charging circuit is inside the unit.
                            • 31214
                            and still no current figure - maybe someone wants to buy a small transformer for one - too bad i suppose.
                            if it's so smart and current is so low - why the high current resistor!
                              Well, what do you think the VAC on the resistor or the chime solenoid will be when the button is pushed to activate the Chime (or if the resistor is used) for let say using 24VAC Transformer?
                              24 Ohms resistor with 24VAC applied = 1A = 24 Watts. Using 24 Ohms resistor will limit the current to 1A if the unit is shorted out.
                              If the charging circuit tries to draw more current then more Vdrops will be on the resistor thus Trickle charge is used to not draw lots of power.
                              How do I know about this typical setup? The company I work for also makes similar products.
                                • 31214
                                well i hope your company gives the optimum charging voltage and current to the customer.
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  That's weird because I know budm and others have seen the pictures ...
                                  Yea this is a public computer. They have stupid security trying to prevent outer tenants from watching pornography. The only thing is it also prevent me from going to General Electrics site because according to this security it is an illicit site. Any rough draw of what you have will work.
                                  I guess I was not clear about the door bell. To me the door bell is the switch one pushes to make the door chime sound.
                                  So you see two wire on the transformer red and white. So where is the transformer at and what voltage do you measure on those wires? Next, you see two wires at the door bell. Is there any voltage across those wires? If not then twist them together, go back to the door chime and see if you measure voltage across those two wires and what is that voltage? It should be the voltage of the transformer. If it is not then something is not connected correctly. Caution, make sure the wires where the door chime is suppose to be are not touching before you measure or twist the wires at the door bell together. If you do not measure any voltage on the transformer There are two possibilities 1 The transformer is burnt out, in this case one can ohm out the wires. 2 You have one lead on the 120 AC line and the other lead on the the 16 volt line, in this case take one lead and move it to the other transformer contacts until you either measure primary 120VAC or the secondary 16VAC.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    Perhaps it is an American Company, in this case it will not matter as we Americans like thing sloppy. We like to abuse the device way beyond what it should endure and we expect that it should still be running at optimum performance. Kind of like a figure 8 stock car race.
                                    • jinu_j
                                      by jinu_j
                                      Hi
                                      05-03-2025, 10:51 PM
                                    • mikey5791
                                      by mikey5791
                                      Hi to all forum members,
                                      12-26-2024, 04:55 AM
                                    • MidnightRoller
                                      Can a resistor lose resistance after hot air?
                                      by MidnightRoller
                                      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                      02-02-2022, 11:46 PM
                                    • artvandalai
                                      What resistor ohm will work better to repair this waterpik?
                                      by artvandalai
                                      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                      01-05-2025, 04:10 PM
                                    • chth96
                                      Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                      by chth96
                                      I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                      Since then, This AC/DC adaptor have been out of order.
                                      But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                      After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                      And Is there any possibility that it will suddenly explode as well as to be out...
                                      12-03-2023, 04:40 AM
