59 ohm resistor required..
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    I am trying to repair a alarm system i own but i need to replace a resister thats gone off value due to getting hot. Its a 59 ohm - 1 watt - 5%. I have looked everywhere on the net and found nothing better than 250ma in 59 ohm's or minimum order quantities in the 1000's. Can anyone help with a small quantitry of either a 1 or 2w resister of this value please.
    cheers
    Jon
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8288
    Re: 59 ohm resister required..
    If push comes to shove, then get a bunch of 56 ohm 5%. Take the one that comes closest to 59 ohm. In what circuit is it in and what does it do? Maybe post a pic of it. Is it through hole or smd? I checked Mouser and they have some 59 ohm 1w resistors.
    • Sparkey55
      • Jan 2010
      • 1523
      cheers
      Jon
      The first question asked is why is the resistor over heating? If you replace the resistor with a new one it will get hot too. You need more troubleshooting to find the cause of the hot resistor.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Seconded. While it is possible that the designer underspecced the wattage of the old resistor (this happens once in a while, especially when designs are rushed to market), there probably is something that is overloading the circuit. Or perhaps a voltage/current supply that is forcing too much power through the circuit.
        sigpic
        (Insert witty quote here)
          Upload good clear pictures both sides of the board so we see what the function of that 59 Ohms resistor is.
          • Longbow
            • Jun 2011
            • 623
            Good suggestions. Also, if the resistor is burned, maybe the color bands (if there are any) are burned and not readable. In any case, there is no reason to hunt down a non-standard value since you can make the needed value very easily with 2 common values. The main thing is to fix the unit first.
            Is it plugged in?
            • steveanddawn
              • Mar 2016
              • England
              Re: 59 ohm resistor required..
              Personally I would just put 60 ohms in, tolerances will allow for the difference. Also, how many detectors are on the system? The internal PSU's on alarm panels are not very highly rated. I more often than not have to fit an extra PSU just to take the extra load.
              • jinu_j
                by jinu_j
                Hi
                05-03-2025, 10:51 PM
              • mikey5791
                by mikey5791
                Hi to all forum members,
                12-26-2024, 04:55 AM
              • artvandalai
                What resistor ohm will work better to repair this waterpik?
                by artvandalai
                The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                01-05-2025, 04:10 PM
              • chth96
                Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                by chth96
                I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                Since then, This AC/DC adaptor have been out of order.
                But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                And Is there any possibility that it will suddenly explode as well as to be out...
                12-03-2023, 04:40 AM
              • badcap111
                Xiaomi mi 9T missing resistor
                by badcap111
                Hi, while trying to replace a broken screen connector on the motherboard, I knocked off a resistor next to the connector, and the resistor vanished. I have tried to find out the value of the resistor by looking at the schematics, but I cannot find the value. The ID of the resistor, or what you should call it, is R6400.
                I don't know if the resistor is necessary for the phone to function, and the connector is still not soldered on to motherboard. I have contacted Xiaomi and asked them if they know the value, but they want a proof of purchase, which I don't have.
                Is...
                08-07-2023, 10:42 AM
